Forum Index > Off-topic Talk > heat treatening Reply to topic
Etienne Hamel
PostPosted: Tue 26 Dec, 2006 8:42 am    Post subject: heat treatening         Reply with quote
how do i solidify my flanges and what oil to use to solidify it.
perhaps with some mineral oil or something like that.
can't wait for an answer.
Hugo Voisine
Reading list: 7 books
PostPosted: Wed 27 Dec, 2006 11:35 am    Post subject:         Reply with quote
Hi,
I'm certainly not the best person to answer questions concerning heat-tempering but I think you should take a look in this book : http://www.amazon.com/Complete-Bladesmith-For...0873644301. A nice introductory book on bladesmithing.
Johan S. Moen
PostPosted: Thu 28 Dec, 2006 2:49 am    Post subject: Re: heat treatening         Reply with quote
I'm not a blacksmith, but I do suspect that you will need to provide more info in order to get a decent answer.
What type of steel are you using, what hardness are you looking to achieve, what equipment do you have, etcetera? Mr. Voisine gave you a link to the Complete Bladesmith, and that is probably a good starter. I am sure that others can give you pointers towards other useful books and sources on the subject.
Johan Schubert Moen
Etienne Hamel
PostPosted: Thu 28 Dec, 2006 7:57 pm    Post subject:         Reply with quote
I just wanted to know about what oil to use on simple steel
if someone can help me it would be easier for me to do a good first flail...
Jeroen Zuiderwijk
PostPosted: Fri 29 Dec, 2006 7:56 am    Post subject:         Reply with quote
There are hundreds, if not thousands of different types of steel, which all look the same, but are totally different materials. You've got steel that can not be hardened, steel that can be hardened in water, steel that can be hardened in oil, steel that hardens by cooling in air. After hardening, most steels have to be tempered to reduce the brittleness, which again depends on the type of steel, and how hard or tough you want it to be. So it's impossible to answer your question, unless you know what steel you have. If you don't know what steel it is, it helps if you know where you took the steel from. If it's recycled steel, what it's from often gives a good guess which steel was used for it.
Etienne Hamel
PostPosted: Sat 30 Dec, 2006 5:19 pm    Post subject:         Reply with quote
it's from my school
Craig Johnson
Likes: 16 pages
Reading list: 20 books
PostPosted: Sat 30 Dec, 2006 6:23 pm    Post subject: Mace         Reply with quote
Dear Etienne
Am I assuming correctly that you are making a flail? and the flail has flanges as opposed to spikes?
If so, to be period it would not be hardened. There is really no evidence that these items would have been heat treated in the historical period.
Best Regards
Craig
Etienne Hamel
PostPosted: Sun 31 Dec, 2006 7:25 pm    Post subject:         Reply with quote
Thanks for your help it's more clear now. Big Grin
Bruno Giordan
PostPosted: Tue 02 Jan, 2007 11:40 am    Post subject: Re: Mace         Reply with quote
Craig Johnson wrote:
Dear Etienne
Best Regards
Craig
Especially for the fact that iron with just a fraction of carbon is not hardenable.
