Garth Thompson
Posted: Fri 03 Nov, 2006 10:12 pm Post subject: Rapier blade length |
Is the blade length on a rapier determined from tip to the edge of the grip, or from the tip to the edge of the guard? The examples I have seen can make up to a 2 inch difference.
Let the high praises of God be in their mouth, and a twoedged sword in their hand. Psalm 149:6
Bill Grandy
Posted: Sat 04 Nov, 2006 7:22 am Post subject: |
I generally do the same thing Nathan does. i.e. "A 40 inch blade with a two inch ricasso." But Nathan's right, people measure them in different ways. I know that in some period sources they measured all the way to the quillon (including the ricasso). The Spanish fencing master Narvaez said the perfect length for a rapier can be measured by setting the tip on the ground, and the quillons should reach the naval, so he clearly measured it to the quillon.
But if you ever decide to order a custom sword, definately be clear. I once ordered a custom rapier from A&A and requested a 43" blade... Craig later called me to double check whether I meant from the quillon or from where the blade comes out of the guard. It was a good thing he checked, because I meant from the guard, and we was going to do a 43" blade IN ADDITION to the ricasso, which would have been gigantic for me.
HistoricalHandcrafts.com
Geoff Wood
Posted: Tue 07 Nov, 2006 10:18 am Post subject: |
Bill Grandy wrote: | . i.e. "A 40 inch blade with a two inch ricasso." |
Mr Grandy
Sorry, but even that can be taken two ways. In the context of this discussion I can see what you mean, but within the statement alone, 'with' could either mean 'including' or 'plus'. It is one of those ambiguous terms.
yeah, I know, i'm picky (and I know d*** all about rapiers)
Regards
Geoff
