Forum Index > Historical Arms Talk > My latest project: heater shield Reply to topic
Eric Allen
PostPosted: Wed 13 Sep, 2006 7:08 pm    Post subject: My latest project: heater shield         Reply with quote
Now that my wife and I have moved into a larger apartment (with a garage I can turn into a workshop!), I took the opportunity to get to work on some of the projects I've wanted to do for a while now. This is the first project of mine, a "heater" shield.
Its made of birch plywood 1/2" thick with a slight curve applied (I was shooting for more curvature, but hey), backed with wool felt and faced with 6-7 oz leather. The arm pad is seuede with cotton batting underneath (I was hoping for wool, but cotton is cheap). Final dimensions are approximately 20.5 x 29.5 inches.
As you can see, I did make some modern allowances, such as the use of modern upholstery tacks to help attach the leather to the back (I originally had fewer, strategically placed tacks, my wife "filled it in" because she thought it looked nicer that way).
The face was designed by me and painted by my wife.
Still some adjstments to be made. The main enarm needs to be trimmed shorter, and I need to add the guige (the attaching points are on there, as you can see). Other than that, I'm pretty happy with it.
My next project is to make a kite shield Happy
 Attachment: 56.38 KB
face of the shield
 Attachment: 62.66 KB
back of the shield
 Attachment: 49.67 KB
just for scale
Patrick Kelly
PostPosted: Wed 13 Sep, 2006 8:00 pm    Post subject:         Reply with quote
Very nice first project! Is this for use in some kind of re-enactment activity or a "just becuase I want it" kind of thing?
Eric Allen
PostPosted: Wed 13 Sep, 2006 8:49 pm    Post subject:         Reply with quote
Partly "just because I want it," partially for lugging around ren-faires.
Mostly so I have something of proper size an weight for when I get around to flourishing and working at the pell when I get the inkeling to take a break from longsword to do sword-and-shield.
Al Muckart
PostPosted: Thu 14 Sep, 2006 12:42 am    Post subject:         Reply with quote
Nice work!
Out of curiosity did you base the lace-on attachments for the straps on a particular historical example? I ask because one of these is fairly high on my project list and I don't know a great deal about the details of the strapping.
Thanks for sharing.
Al.
http://wherearetheelves.net
Greg Griggs
PostPosted: Thu 14 Sep, 2006 6:09 am    Post subject:         Reply with quote
Nice job. Looks great. That birch isn't the easiest to bend is it, eh? Adjustments, never ending aren't they.......
Ken Rankin
PostPosted: Thu 14 Sep, 2006 7:25 am    Post subject:         Reply with quote
Hi!
The shield looks great! How did you curve your wood? In my shield I had a small press that I used (but plywood bends easier) and I used 2 pieces of plywood instead of a single piece. Love to hear the mechanics of the construction!
Ken
Eric Allen
PostPosted: Thu 14 Sep, 2006 9:31 am    Post subject:         Reply with quote
Ken Rankin wrote:
Hi!
Ken
I used two 1/4" birch plywood sheets, slathered ample amounts of wood glue between them, and lashed them to a tree with truck tie-downs Wink
Honestly, the adjustable enarms via lacing, I "borrowed" that idea from looking at the shields offered by The Mercenary's Tailor. I played wround with a few different methods of attaching them to the shield itself--carriage bolts, screws, nails--I ultimately wanted to try rivets, but the closest store that sells half-way decent rivets is in Des Moines. On this one, I ultimately ended up with these things I found at Lowes. I think they're called "screw posts" or something like that. Its a post, threaded internally, and it has a short screw that fits in it. I used them even though they're not in the least bit hisotrical because they sort of look like rivets, but you only need a screwdriver, and they were readilly available.
Greyson Brown
Reading list: 15 books
PostPosted: Thu 14 Sep, 2006 10:51 am    Post subject:         Reply with quote
Eric Allen wrote:
On this one, I ultimately ended up with these things I found at Lowes. I think they're called "screw posts" or something like that. Its a post, threaded internally, and it has a short screw that fits in it. I used them even though they're not in the least bit hisotrical because they sort of look[/] like rivets, but you only need a screwdriver, and they were readilly available.
I think those are also called Chicago Rivets. I have used them from time to time, and my father has used them on several things. I do find that they can come loose on some projects, but a shield does not flex much, so it probably won't be an issue.
-Grey
Ken Rankin
PostPosted: Thu 14 Sep, 2006 12:45 pm    Post subject:         Reply with quote
Eric Allen wrote:
[ On this one, I ultimately ended up with these things I found at Lowes. I think they're called "screw posts" or something like that. Its a post, threaded internally, and it has a short screw that fits in it. I used them even though they're not in the least bit hisotrical because they sort of look[/] like rivets, but you only need a screwdriver, and they were readilly available.
Have you thought about using carriage bolts and acorn nuts? Also, you can get copper rivets at stores like Tractor Supply, which I don't know if you have in your area, it's a feed type store that carries alot of supplies for horses and the like. Also, I found some really cool brass tacks at Lowe's as well and used them on mine.
Ken
Here's a pic of my fantasy shield:
Eric Allen
PostPosted: Thu 14 Sep, 2006 1:15 pm    Post subject:         Reply with quote
I've used carriage bolts in the past. I did like the fact that if you don't peen them, the enarms are removable/replacable (I used this feature when the cheap cruddy straps on of the padded sparring shields I made a couple yars ago broke. Simply uncrewed the nuts and replaced the strap). They don't really have that "look" I'm going for, though. I keep them in mind as a sort of "if all else fails" contingency.
Hmm, I'll have to check out one of the local farm supply stores for rivets. I'm in the middle of Corn Country, there's plenty of them around here. Thanks for the tip, Ken. If I can find good ones, I may use rivets for the upcoming kite shield. Leather stores like Tandy Leather also sell rivets and tools to set them.
Oh, and here's a general tip: if using nails to secure the straps, make sure the nails are of a relatively soft metal. I tried roofing nails at one point. Yeah, that was a mild disaster.
Chuck Russell
Reading list: 46 books
PostPosted: Thu 14 Sep, 2006 5:21 pm    Post subject:         Reply with quote
good job
Allan Senefelder
PostPosted: Thu 14 Sep, 2006 6:33 pm    Post subject:         Reply with quote
Isn't there a thread around here somewhere in which Chuck mentioned a source for clinch nails for making shields?
