What is CoG?
I did not see this listed in the glossary, and could not find a definition with search.
I saw it referenced in the specs for the Viceroy:
CoG: 4.75" (12 cm)
Thanks
Center of Gravity (or, more rigorously, center of mass). Distinct from center of percussion (CoP). CoG is often measured from the crossguard towards the point.
Re: What is CoG?
Thanks
I think it means Centre of Gravity. Or: http://www.abc.se/~pa/mar/cog.htm Depends on context and Google gave me a lot of strange alternate meanings. :p
O.K. couldn't resist to tease a little, no harm meant. :cool:
So in reference to my other post about the Viceroy, is CoG that same as PoB?
Hi again; I just posted in that topic referring you back here. ;)
Yes. CoG is a bit more technically precise than PoB, since people occasionally mean different things by "balance."
-GLL
Got it. Thanks!
Lance
-GLL
Cog is a very 3 dimensional thing while with point of balance one could speak of how far from the guard the sword would balance on a finger.
With a strait symmetrical blade the two are the same for all practical purposes but with a very highly curved blade the CoG might actually be floating in the air above the top of the blade in a sabre or below the blade with a Kukri or yatagan blade.
Think of a Donut: the CoG is actually at the very middle where the hole is.
The PoB might be 5" from the guard but with a asymmetrical blade the CoG could also be 5" from the guard but at the top of the blade or floating above it in on one of the other 3 dimensions: One can feel this in the handling of a very curved blade when one tilts the blade from side to side.
( Well, I could be wrong, and for all practical purposes they are the same. )
In the context of swords, Center of Gravity and Point of Balance are identical.
Interesting and maybe I was reaching too much for distinctions between the two, but with a curved blade the Cog won't be on the center line and would affect handling, I think, in the way I imagine.
Actually I haven't read here anything that I remember about the handling of curved blades : I have an original very heavily curved Shamshir and when the blade is on the side it feels very different than a strait blade when the hand and sword are turned to the side: The strait blade feeling neutral while the curved blade wants to twist out of your hand.
Just curiosity. :confused: :cool:
Jean,
You are right, with a very curved blade the fact that the center of gravity is not in line with the handle can make the weapon feel different, even in static handling. However, since the handle is not necessarily in line with the forte of the blade, I suspect that there are curved blades that do not have this effect, if the center of balance is aligned with the handle it will not tend to twist it when turned to the side. That could be a reason for hilts curving opposite to the blade in a number of curved swords...
I've seen a iaito (training Japanese sword) that had a small defect: the handle was not contained in the plane of the blade, thus the COG was often not right behind the edge when stopping a cutting motion, and that resulted in an unpleasant twist in the hands. Slight, but still disturbing. So I think you are right pointing out that the center of gravity is really a point in space, and not just a distance from the guard...
Since most European swords are straight, the 3D nature is most of the time hidden and we can safely speak of the point of balance as 1D. Plus, the 3D position is something not easy to find out, it would involve 3 measures with the sword hanging from 3 different points. Since the 1D distance from the guard is already quite significant, I believe looking just at that makes sense.
Or we could go at the intermediate level and say it's 2D (distance from the guard + distance from the handle's axis for example) but I'm quite confident someone will still find some exotic weapon where that's not enough :)
Regards
