John Cooksey
Posted: Fri 09 Dec, 2005 8:42 am Post subject: A question of balance: falcata and kopis |
I am getting ready to have one of these babies put together, and I am curious as to how far out the center-of-gravity "ought" to be.
Would there be a significant difference between the handling of an Eastern Med. Kopis and a Western Med. falcata?
Seems like Kopis blades are often skinnier, but Falcata blades have more fullering.
B. Stark
Posted: Fri 09 Dec, 2005 3:46 pm Post subject: |
I had a few conversations about these swords with Peter Johnsson. Firstly, from what PJ has discovered, these swords tend to be lighter than most would initially believe. Also, they apparently have very drastic and or complex distal taper. Some incorporate a "T" shaped crossection. Being that they are so short also contributes to a lessening of true blade presence. At least in the Iberian versions. They seem more robust then many of the Greek versions. Which tend to be longer and slimmer in profile in some cases.
I think that it is a misconception that these swords were heavy cleavers. Though they were designed to give a devastating blow. I believe they were quite quick in the hand.
"Wyrd bi∂ ful aræd"
John Cooksey
Posted: Sat 10 Dec, 2005 9:07 am Post subject: |
From what I have read, it does seem like falcata, at least, were pretty quick little beasts.
I am having a generic "falcata/kopis/machaira" made, and I can't decide whether to have the POB/COG somewhere in the vicinity of 2 inches, or somewhere in the vicinity of 4 inches, out from the hilt.
I tend to like weapons with a bit more blade presence, both for cutting and for thrusting.
It's going to be a bit heavier than some historic falcata, but it's going to be a pretty good-sized weapon, too.
Thanks, y'all.
Shane Allee
Posted: Sat 10 Dec, 2005 10:18 pm Post subject: |
Well if it isn't the Scythian... I knew your name looked familiar John, but couldn't place it. Finally made the connection with the ginko leaf avatar and your sword for sale. Good to have you around here and have you posting again.
About the best source we have found is El armamento ibérico by Sanz, shouldn't be a problem for you to ILL through your university. You are still at the university down there right? Anyway, if you have problems let me know and I'll get you what I have. He does have a good number of illustrations for the kopis, machaira, and the falcata with cross sections included. It will also get you some thicknesses for a few different falcata blades. Few other bits in there as well if you take the time and work with it. Really would be worth your time, should be more than a few things in there that will catch your eye.
I would hold off on going too generic, after you get Sanz you will really start seeing some of the specific characteristics of each type. With the machaira and kopis you can pretty much figure the balance point will be out there a bit, I wouldn't even venture a guess on where it will fall on until I get a falcata finished though. There is just that much going on that it will be interesting seeing how things shift around as it comes together.
Look forward to seeing what you come up with.
Shane
John Cooksey
Posted: Sun 11 Dec, 2005 10:52 am Post subject: |
| Shane Allee wrote: | Well if it isn't the Scythian... I knew your name looked familiar John, but couldn't place it. Finally made the connection with the ginko leaf avatar and your sword for sale. Good to have you around here and have you posting again.
Shane |
Indeed, it is I. :-)
That book sounds like a fabulous resource. I am going to try and get it through ILL soon. My Spanish is a little rusty, but should allow me to read it passingly well.
Heh. I already commissioned a custom piece.
It is going to be more of a try piece, though, to see what works for me. A little extra weight is not much problem, given my arm, as long as the weapon is quick enough, overall.
It will be probably be weighted and balanced more to the "large kopis" end of the spectrum, as I find the historical context of the earlier Greek weapons more fascinating (given my obvious historical bent [grin]) than the later Iberian ones.
Also getting a small iron-age type smithy set up, so don't be too surprised if y'all start seeing some "primitive" leafies and chiruwa-style khuks from me in the next couple of years.
That's mostly going to be a research endeavor for me, into archaeological process and reconstruction. And the fact that I just like to play with tools and fire . . . . . . . :-)
The weapon is actually being forged out now, so I should have it available in a few weeks.
