Posted: Fri 08 Jul, 2005 7:37 pm Post subject: Gilding and or plating of pommels and guards? |
Have any manufacturer's offered (would Albion do it at a modest price) silver guilding or nicklel plating as options with pommels and guards?
I have experiemented for about 6 months with cold blueing and found that this slows down corrosion from hand imparted oils. I would like something better so that the sword does not need to be oiled and wiped down every few days after just minor handling of the hilt area.
Posted: Fri 08 Jul, 2005 7:41 pm Post subject: Re: Gilding and or plating of pommels and guards? |
Jared Smith wrote: | Have any manufacturer's offered (would Albion do it at a modest price) silver guilding or nicklel plating as options with pommels and guards?
I have experiemented for about 6 months with cold blueing and found that this slows down corrosion from hand imparted oils. I would like something better so that the sword does not need to be oiled and wiped down every few days after just minor handling of the hilt area. |
Gilding requires precious metals be suspended in liquid mercury. From there, the piece is heated and the mercury burns off as a gas, leaving the precious metal bonded to the under surface. This is a highly dangerous process, as you might imagine, and is unlikely to be done by a modern maker.
Nickel plating is highly non-historical and I hope that nobody is doing that. It's just plain ugly in my humble opinion.
Some entry-level products have used nickel-plating, such as some from Windlass Steelcrafts and Hanwei.
If you're not going for something historical, you can bring parts down to a plating company and they can plate them for you for a relatively inexpensive price. Depending on the thickness and the quality of your vendor, the plated finish may not hold up well to repeated use.
G. Scott H.
Posted: Fri 08 Jul, 2005 8:56 pm Post subject: |
I'd go with a satin chrome finish personally. It looks very much like steel and can be done for very reasonable prices. Good example here: http://www.guildplaters.com/finishes/satin_chrome.html . Nickel typically ends up looking really gaudy, and it can eventually develop an ugly yellowish patina (if you've ever seen an old nickel plated gun, you know what I mean).
Posted: Sat 09 Jul, 2005 3:12 pm Post subject: |
Thankyou much for the input.
I am still looking for the "best option" to direct Albion to execute on my Munich sword.
I have a "nickle silverode" pocket watch that was actually made during the Civil War, 1870's vintage. This is proveable, and has been assessed by at least 2 jewelers based on material composition, model inscription, and style. It has held up very well and looks pretty much like an average nickel of just a few years circulation that you would take out of your pocket in terms of patina. Based on that, I had thought a combination nickel silver plating could be a reasonable look (like fairly new condition steel), but still durable.
As alternatives, I am considering the "fire blueing" which I have seen on other Albion swords. Twenty years from now I don't want a "plumb brown" hilt section. I will oil if that is the only way....
