Vaclav N
Posted: Tue 31 May, 2005 2:02 am Post subject: Sword info |
Hi, can anybody please tell me something about this sword replica (e.g. to which period does the original of this sword belong to, type of this sword...) ?
Attachment: 6.23 KB
Chad Sonderberg
Vaclav N
Posted: Tue 31 May, 2005 7:33 am Post subject: |
It really looks like type XIIa but isn't the dimension of this sword too big for this type? The length of the blade is 35" (90 cm) and the length of the grip is 8" (20 cm) and I guess it should be basically hand-and-half sword. Could it be this type even though?
Chad Sonderberg
Posted: Tue 31 May, 2005 8:21 am Post subject: |
It was hard to tell the size by the photo. By those measurements it would classify as a XIIIa. Though, it may be able to squeeze in as a XIIa. The same time period applies to the XIIIa as the XIIa, just a different region.
A.C.S.
Lebend mit Ehre, Sterben Sie mit Dignität.
Vaclav N
Posted: Tue 31 May, 2005 8:38 am Post subject: |
At first I thought it would be rather XVII type, but it seems it isn't. Thanks for helping me with classifying this sword.
Vaclav N
Posted: Tue 31 May, 2005 11:14 am Post subject: |
The cross-section of the blade is broad-fullered.
Vaclav N
Posted: Tue 31 May, 2005 11:29 am Post subject: |
I've already read that article and the blade cross-section is really fullered, but the fuller looks to me something between narrow and broad.
Posted: Tue 31 May, 2005 11:34 am Post subject: |
| Vaclav N wrote: | | I've already read that article and the blade cross-section is really fullered, but the fuller looks to me something between narrow and broad. |
The fuller is a completely different element than the cross-section. It's often difficult to figure out of it's a hex, lenticular, or diamond with that fuller dug in there, but if you look at the areas above and below the fuller (the areas without a fuller), you can hopefully figure it out.
In that article where it talks about "narrow-fullered", "broad-fullered", etc, it shows it on a lenticular cross-section, but a diamond or hex can also have various widths of fullers, too.
Alexander Ren
Posted: Tue 31 May, 2005 12:11 pm Post subject: |
| Vaclav N wrote: | | It really looks like type XIIa but isn't the dimension of this sword too big for this type? The length of the blade is 35" (90 cm) and the length of the grip is 8" (20 cm) and I guess it should be basically hand-and-half sword. Could it be this type even though? |
According to Oakeshott's "Records of the Medieval Sword" the types XIIa and XIIIa are war swords of hand-and-half and two-handed size. The specs on this sword put it right into that range. It looks like a XIIa with an almost fantasy hilt to me, definitely tapers to acutly to be a XIIIa.
Alex
Vaclav N
Posted: Tue 31 May, 2005 12:15 pm Post subject: |
| Nathan Robinson wrote: | | The fuller is a completely different element than the cross-section. It's often difficult to figure out of it's a hex, lenticular, or diamond with that fuller dug in there, but if you look at the areas above and below the fuller (the areas without a fuller), you can hopefully figure it out. |
OK, now I see what you mean. The cross-section is diamond.
