Forum Index > Historical Arms Talk > Belt spanned crossbows in the 15th century Reply to topic
This is a standard topic Go to page Previous  1, 2, 3  Next
Jean Henri Chandler
PostPosted: Thu 22 Oct, 2020 11:00 am    Post subject:         Reply with quote
I think another major stumbling block is that people look at one region and extrapolate to another. Many things in terms of military organization seemed to be different between say, Western and Central, Southern or Northern Europe.
My focus is mainly on Central Europe and in that context, in the late medieval artwork especially in German, West Slavic (manly Czech or Polish) or Flemish artwork what you see depicted for battle are primarily the relatively small weapons spanned by the rack and pinion cranequin type spanners, and to a lesser extent, the somewhat larger weapons spanned by the windlass. Some depictions of the goats foot or wippe, and some of spanning with belt hook or the like, but not as much.
Examples would include images from the Swiss chronicles, Polish and Czech manuscripts, (Balthasar Behem Codex from Krakow is a good example) German manuscripts (like the Von Wolfegg housebook), and religious art such as various depictions of St. Sebastian. The prestigious weapon is usually the cranequin weapon.
By comparison if you look at some of the illuminated versions of Froissart from France and Flanders (for a French audience), they often depict the windlass or pully type or belt hooks.
In her War Book, Christine de Pisan clearly describes several distinct types of crossbows and spanners, unfortunately the translation just says "other crossbow" and "another crossbow" since the translator didn't know the period terms, and I've been unable to find a transcription of the original text.
This corresponds with the Teutonic Knights records, urban militia ordinances and records related to the Hungarian Black Army, which all point to an emphasis on the cranequin type weapons as the most preferred, with the stirrup crossbows coming second. I don't think the solid wood ones were used in a military context except in defense of fortifications or towns. They would be fine for hunting though probably.
Note in this detail pic from the Bern Chronik (attached / bottom) and one of the two St. Sebastian images where you can see it, he has a crossbow with a foot stirrup but he's spanning with the cranequin and not using the stirrup. However Bern Chronik also includes some images of belt-hooks.
 Attachment: 117.07 KB
Jean Henri Chandler
PostPosted: Thu 22 Oct, 2020 11:03 am    Post subject:         Reply with quote
Here one guy has a cranequin (on the ground next to his foot), and the other, with seemingly a larger weapon, is using the foot stirrup and (I think?) a belt hook
While we are discussing all this - do you happen to know the reason why all the crossbow quivers are always wood, have that flaring shape and are covered in fur?
Jean Henri Chandler
PostPosted: Thu 22 Oct, 2020 11:04 am    Post subject:         Reply with quote
One more with the cranequin. Some times the foot loop looks very small, as it does here. Note his foot doesn't seem to be in it. Maybe that is just a means to protect the prods, especially composite prods, when placing the crossbow nose down for spanning?
Sean Manning
PostPosted: Thu 22 Oct, 2020 11:54 am    Post subject:         Reply with quote
I think I have seen some crossbows hanging from their stirrups. That would be a way to protect the horn or wooden bow in storage. The very small stirrups could be for that.
I heard that badger skin has good water resistance. If you choose to use quivers on the hunt or in the field, keeping water and debris out are important. The badger skin also communicates that you are the kind of person who takes pests.
I translate some primary sources on crossbows from the 13th and 14th century in another thread.
www.bookandsword.com
Jean Henri Chandler
PostPosted: Thu 22 Oct, 2020 12:30 pm    Post subject:         Reply with quote
Definitely. It's just interesting to me how the crossbow quivers seem to be so distinctive and also different from (self) bow quivers.
Thanks Sean, I'll check that out!
J
Pieter B.
Reading list: 10 books
PostPosted: Fri 23 Oct, 2020 8:03 am    Post subject:         Reply with quote
Aren't crossbow quarrels loaded tip up in a case or quiver instead of tip down like arrows with the 'fletching' on crossbow quarrels being made of harder wood or parchment?
It makes sense to have a broader base if that's where the additional bulk of those hard fletching is positionened.
Duncan Hill
PostPosted: Fri 23 Oct, 2020 8:08 am    Post subject:         Reply with quote
I think that's correct - I always assumed that was specific to wooden-fletched bolts, to protect the thin brittle flights. I can't think of another reason.
Also, regarding the "very small stirrup", it is indeed simply a suspension ring. As far as I know, cranequins were used just holding the crossbow in your left hand while cranking away on the handle, which is why the rustung type didn't need a stirrup. Schnepper types typically had a large staple fastened to the front which doubled as an anchor point for the wippe (cocking lever) and as a suspension ring.
Jean Henri Chandler
PostPosted: Sat 24 Oct, 2020 8:50 pm    Post subject:         Reply with quote
Makes sense to me, I wasn't aware crossbow bolts were stored point up, that's interesting.
Pieter B.
PostPosted: Sun 25 Oct, 2020 4:12 am    Post subject:         Reply with quote
It's funny how little details can escape a person.
Look at the paintings you posted, tips up in all of them!
Duncan Hill
PostPosted: Mon 26 Oct, 2020 8:18 am    Post subject:         Reply with quote
I've also wondered if there was another reason. In the context of hunting, as I understand it, crossbows were used for hunting a variety of game, some of whose pelts one would not have wanted to damage. If one hunter, during one hunting session, was hunting more than one type of game, it seems feasible that he would have carried more than one type of bolt: broadheads for, say, deer, and blunts for smaller game. In that case, it would be handy to carry them points-up so that one could easily differentiate between the two types.
That said, that is a very specific scenario dreamed up through pure, unqualified speculation!
Jean Henri Chandler
PostPosted: Mon 26 Oct, 2020 8:22 am    Post subject:         Reply with quote
You definitely see all kinds of different hunting bolt-heads in the art and in collections of actual bolts.
Jean Henri Chandler
You are right, I saw it but I didn't realize it was a consistent pattern.
Michael Beeching
PostPosted: Mon 26 Oct, 2020 12:39 pm    Post subject:         Reply with quote
I think there might be a few more reasons to argue for a flaring shape on the quiver, though I don't have any answers - just a few questions worth contemplation:
1. Retention. Bolts are short and do not have the long length of arrows to help keep them grounded in their container. So, by tapering the mouth of the quiver and flaring the base, you can conceivably help to keep your missiles where you want them. The only thing a bit unusual is that the CG of a bolt should be nearer the tip than the fletchings, so you become dependent on the quiver's geometry more so for retention than the forces of nature, if you will.
2. Protection of the Fletchings. Well, maybe. I am not sure of how tough or not the fletchings on a bolt could be. But, perhaps if they tended to be made from wood, having them stick out of the quiver might result in breaking or cracking if you happen to bump into something, while if they are buried in a sturdy quiver this will be less of a problem?
3. Here is a legitimate question: how many bolts does a typical quiver hold?
Duncan Hill
PostPosted: Mon 26 Oct, 2020 12:54 pm    Post subject:         Reply with quote
This I think is certain - having made bolts with both wooden flights and feathers, I can say unequivocally that wooden flights are WAY more susceptible to damage in use. I assume the only advantage to wood was long-term storage (i.e. they wouldn't get eaten by insects as quickly).
Jean Henri Chandler
PostPosted: Thu 29 Oct, 2020 2:09 pm    Post subject:         Reply with quote
Seeing as it's routine for archeologists to track medieval battles by finding the iron bolt heads with metal detectors I would assume a fairly high number of the bolts are lost after being shot. Even my modern 175 lb draw hunting crossbow tends to mangle the 'arrows' when you shoot them.
Reading list: 7 books
PostPosted: Mon 09 Nov, 2020 5:28 am    Post subject:         Reply with quote
I'm not sure if the type of fletching needs to be part of the explanation, since there's a particular type of early medieval Central and East Asian quiver (usually known as a "closed quiver" since it had a lid that could be closed to protect the arrows) had a very similar shape, flaring towards the base with the arrows stored point up. The arrows had conventional feather fletching so damage to the fletching didn't seem to have been a major concern in the design of these quivers (or it might have been a concern but far lower in terms of priority than being able to close the quiver to protect the arrows, maybe from the weather or from pests or whatever threats were deemed the most relevant back then).
Obviously, length doesn't seem to have been much of an issue here either. The arrows appear to have been normal-sized arrows, and in fact the closed quiver would have been impractical for storing arrows of significantly different lengths -- the possible lengths are pretty much restricted by the size of the opening covered by the lid.
Last edited by Lafayette C Curtis on Mon 09 Nov, 2020 5:38 am; edited 1 time in total
PostPosted: Mon 09 Nov, 2020 5:34 am    Post subject:         Reply with quote
There is some differentiation in terminology in the records of the Teutonic Knights, of which some scholars have done some significant work. The number of papers is somewhat limited, I suspect because not that many people have learned to read Low German dialects compared to say, Early New High German. There is however also a considerable quantity of data mostly in High German from the Schützenfest contests which were routinely held in scores of towns and cities in the German-speaking, Flemish speaking and West-Slavic towns from the High Medieval through the Early Modern periods. These get into detail for the different types of shooting sports with their various different types of weapons - for example shooting at near and far fixed targets (with weaker and stronger crossbows respectively), shooting the popinjay, and shooting targets from horseback. Again, there aren't that many modern papers and most of this hasn't even been translated or reviewed recently but you can find transcriptions into modern German which were done in the 19th Century.
From these records, you can see clearly that there were sharp differentiations between various grades of crossbows, and a somewhat overlapping differentiation between different spanning systems or devices.
Do you have the titles for these 19th-century transcriptions? Schutzenfest records would be particularly useful for some research I'm currently doing.
Jean Henri Chandler
PostPosted: Mon 09 Nov, 2020 4:54 pm    Post subject:         Reply with quote
My original sources for that data were secondary - the relatively recent monograph by professor Ann Tlusty "The Martial Ethic in Early Modern Germany" has a lot of data on these, (derived from the surviving records) with a pretty good bibliography, and a much older (19th Century) but also pretty good source is Johannes Janssen's Geschichte des deutschen Volkes seit dem Ausgang des Mittelalters which has a bit more detail. You can find that online if you look around a little.
There are a few books also published in the 19th Century which have the transcription of the special songs which were composed by the organizer of these events, someone called a pritschmeister. They include everything that happened at the event, names of all the winners etc., as well the rules. There is also separately an account of a specific one from Zwickau mentioned in the memoirs of From Hans Ulrich Krafft "Reisen und Gefangenschaft" published 1583.
I had a PDF of a book of five of the schutzenfest songs but I've lost track of them. I will try to track those down, I've asked some HEMA friends for help.
Another source you can look for are the actual invitations they sent out, several of which survived. They put on the invitation all the basic rules, as well as the main prizes, and the size of what they consider a foot or an ell or whatever, since each town had a slightly different measure, and the size and distance of the target. I found a scan of one of them (attached) but unfortunately it's too low res to read the script. You can make out the circle and the length of the unit of measure on the bottom. Also the prize of a silver cup and two oxen. I can't quite make out the date but I think it was 16th Century.
I know there are more of those out there and of course, better image but that's all I have at the moment. If I can find some more for you I'll post it here.
 Attachment: 65.2 KB
Last edited by Jean Henri Chandler on Sat 21 Nov, 2020 7:48 am; edited 1 time in total
Jean Henri Chandler
PostPosted: Tue 10 Nov, 2020 8:31 am    Post subject:         Reply with quote
I should add that, in the rules (including on the invitation) they apparently include
* The size of one unit of measure, physically indicated on the invitation
* The size of the target, also physically indicated on the invitation
* The distance in (units of measure) to the target for the different grades of crossbow or firearm shooting
* The time allowed between shots
* The rules for qualifying as in how close to the hits need to be to the center of the target etc.
So this gives us a lot of ideas as to a baseline of expected accuracy and performance.
Jean Henri Chandler
PostPosted: Wed 18 Nov, 2020 8:20 am    Post subject:         Reply with quote
Ok so I did some digging, I believe Hans Sachs wrote a few of these, I haven't found the specific 19th Century collection I used to have but i did find this, which includes a description of a Fechtschule in Würtemburg in 1575, with a partial description of a Schützenfest. (It’s about 20 pages long covering fights, dussack, long sword, dagger, staff, halberd, the Federfechter, the Marxbrüder and delineates the Meisterstuck as per Hans Sachs though I'm not sure if this is him).
https://books.google.com/books?id=o3pUAAAAcAAJ&pg=PA414&dq=%22hett+zu+ro%C3%9F%22&hl=en&sa=X&ei=wBCMVcfPG8uXNqfuuxA&ved=0CB4Q6AEwAA#v=onepage&q=%22hett%20zu%20ro%C3%9F%22&f=false
Page 2 of 3 Reply to topic
