Patrick Fitzmartin
Posted: Sun 20 Feb, 2005 1:04 pm Post subject: Maille Quandries |
Greetings All, First off thank you Patrick Kelly and everybody else that partipated in the "Wholesale Armor" thread. An excellent and informative read.
I have been toying with the idea of obtaining chainmaille. The biggest problem I have is finding something that will fit. I have a 40" chest and 32" waist. Everything I have looked at starts at 47" to 54" chest. Now I know all the makers say the maille will form fit because it moves but that will still be too much material for me. I have gone thru the same trouble with tunics. I have to get them altered because I wind up wearing a tent. Throw in waist belts and gear and I wind up with folds, bunches and weird looking pleats. I can just imagine what too much maille will do.
At this point I have come to 2 solutions. Buy one and alter it or make my own. From what I have read either one will be a task. I would welcome any recommedations as far as instructional material as well as observations and insights. Thank you everybody. Sincerely, Patrick Fitzmartin
Chris Post
Posted: Sun 20 Feb, 2005 1:34 pm Post subject: |
These sizes look very peculiar. What kind of maille do you want - e.g. butted, rivetted, welded? And how much do you want to spend?
Here in Germany there is an excellent manufacturer of welded ring maille. See examples of it in the "Testing Armour" thread. They offer various types in six different sizes, basically from 32" to 53" chest circumference. The most typical ones are between 40" and 44" though. They all feature the "Norman Cut", i.e. very form-fitting.
The main problem with a maille that is way too big is not that it won't fit, but it's a lot of weight to carry around. And also you always pay for every ring, and of course you don't want to pay for more than you need.
Skeppsmannens härsmakt räddes ej väta:
blodulvar vadade väst över Panta:
fram över flodens glimmande vatten
buro de lindesköldar i land.
Aaron Schnatterly
Posted: Sun 20 Feb, 2005 1:55 pm Post subject: |
Patrick-
Chris is correct - it isn't so much an issue of it fitting, bunching, or whatever - maille doesn't act like fabric in that regard due to the structure and dynamics of the stuff. Below is a picture of a 9 y/o (friend of mine, but don't have permission to post his pic, so off with his head - sorry...) wearing my maille shirt. I'm 3 times his weight and 2 feet taller. At 6'2, 230, this comes to a finger-width or two past my wrist/palm crease, and hangs to mid-thigh. What does become an issue is the weight - he obviously doesn't need to tote all of this around with him - could do with 1/2, possibly less, just in circumference, and a lot less sleeve and length. As it is, it's 36 pounds. His would be approximately 12 to get the same coverage and density.
Just for the sake of being thorough... approx. 25,000 3/8" I.D. galv steel 14 gauge rings with brass trim. Took somewhere in the neighborhood of 120 hours... still have the chausses and coif to do. It isn't hard, just mind-numbing and time-consuming. I have a hell of a grip, though...
Hope this helps...
-Aaron Schnatterly
Attachment: 76.34 KB
Patrick Fitzmartin
Posted: Sun 20 Feb, 2005 5:56 pm Post subject: |
Chris Post wrote: | These sizes look very peculiar. What kind of maille do you want - e.g. butted, rivetted, welded? And how much do you want to spend?
The main problem with a maille that is way too big is not that it won't fit, but it's a lot of weight to carry around. And also you always pay for every ring, and of course you don't want to pay for more than you need. |
Greetings Chris Post, These are sizes listed in catalogs, websites and eBay but this is probaly the "generic" market. The same thing goes for costuming. After I posted this I found a site called "the Ringlord" that sells kits with instructions so I think that may be the route to go. Very good point about carrying extra weight and paying for it. Sincerely, Patrick Fitzmartin
Patrick Fitzmartin
Posted: Sun 20 Feb, 2005 6:12 pm Post subject: |
Greetings Aaron Schnatterly, Nice looking work sir even on him. I see what you and Chris are talking about. After I made this post I found a site called " the Ringlord" that sells kits with instructions. The prices don't look too bad and with my labor I will probaly get what I want. A bit of study brought me to the conclusion you just don't take one of these apart and put it back together again. Sincerely, Patrick Fitzmartin
Aaron Schnatterly
Posted: Sun 20 Feb, 2005 6:37 pm Post subject: |
Patrick Fitzmartin wrote: | Greetings Aaron Schnatterly, Nice looking work sir even on him. I see what you and Chris are talking about. After I made this post I found a site called " the Ringlord" that sells kits with instructions. The prices don't look too bad and with my labor I will probaly get what I want. A bit of study brought me to the conclusion you just don't take one of these apart and put it back together again. Sincerely, Patrick Fitzmartin |
Patrick-
Thanks for the complement! There is quite a bit of satisfaction in knowing that armour you wear is truly *yours*. You'll enjoy that feeling. A good bit of the labor is in the cutting of the rings. I'm guessing you are looking at pre-cut rings? Assuming they are good quality (I can't speak one way or the other about ANY vendor - I make all of my own), you will save a lot on labor and time. You are correct - the stuff is difficult to tear apart and put back together. If it wasn't durable, it wouldn't do us much good, so this is a good thing... Butted maille is easier than the rest...
I can offer some suggestions for fitting and construction if you can answer a bit more about what style / period you are after. Also, I am assuming you are looking for the "usual" standard 4:1 pattern and not some exotic other one - am I correct? Why do you want a maille shirt? For a collection, for costume use, for contact sparring use, for reenactment use? Just trying to get you more dialed in to what it is that you actually want - we (both you and I) want you to be very happy with the fruits of your labor.
-Aaron Schnatterly
_______________
Fortior Qui Se Vincit
