Etienne Hamel
Posted: Wed 18 Jul, 2018 5:08 pm Post subject: Ball warclub project |
Hello folks! been a while since i posted anything, thought i'd share the ball warclub i finished recently it's made out of a maple tree i cut almost a year ago (11 months or so). i followed the instructions of corey boise from woodland warclubs on this one and i'm pretty happy with the result
here are the stats for those interested:
lenght: 24 7/8''
ball size:3 inches
material: maple
the ball is the root of the maple tree. it is finished with tung oil based dark walnut stain but it doesn'T show much the stain on the handle, only the ball looks stained... (didn'T have any pure oil at hand)
the design is pretty much vines and leaves even though it'S not perfect and burnt into the wood with pyrography tools. had to do some stippling as an accent and to hide some saw marks that i had a rough time removing...
it actually feels pretty heavy so i have no doubt that this warclub could crack a skull or break some bones pretty easily. i don'T have the scale to weight it unfortunately
i was told that it looks pretty much like a pawnee style warclub and wanted to base it on one so yeah mission accomplished
thanks for looking ^^
Attachment: 363.79 KB
Attachment: 127.25 KB
Attachment: 110.97 KB
Mark Moore
Posted: Thu 19 Jul, 2018 8:12 am Post subject: |
That looks great! I bet you could make one heck of an Irish Shilel....Shalaigh..Shill...You know! An Irish head-knocker. ...McM
Etienne Hamel
Posted: Thu 19 Jul, 2018 9:52 am Post subject: |
| Mark Moore wrote: | That looks great! I bet you could make one heck of an Irish Shilel....Shalaigh..Shill...You know! An Irish head-knocker. ...McM |
with more research on them maybe, i'm pretty much in a rush of anicinabe stuff at the moment
Carl W.
Posted: Thu 19 Jul, 2018 6:41 pm Post subject: |
Well done. Thank you for sharing this (including the before picture).
Posted: Fri 20 Jul, 2018 5:48 am Post subject: |
Very good job, looks very attractive and functional. The wood burning decoration is really well done without being overdone.
Since I like to be able to make actual use of something like this I would personally really like a walking stick length version of the same thing, but I can see that at this length it's much more an accurate representation of the length of historical original pieces.
Would make a very good shillelagh or rather a shillelagh " Interpretation " if one uses different woods than the traditional blackthorn
Etienne, if you can find some Lilac branches I've had some good success working with Lilac, and I have a Lilac tree in my backyard that I have to trim off branches once every few years when rogue branches end up touching a bedroom window, so I have my own source of Lilac that isn't a wood harvested as lumber because it grows too small and with often crooked branches that it's not a wood attractive for commercial exploitation.
On the other hand Lilac is about twice as hard as Oak or Ash, but drying it can be tricky because it can almost explode with big cracks at the cut ends unless sealed with wax or vaseline so that the ends dry at the same rate as the rest of a branch with the bark left on it.
One work around if one hasn't the patience to wait a year for the wood to dry is to quickly remove all bark and keep rubbing in boiled linseed oil into the wood and add oil as soon as the wood has soaked in all of the oil.
With a recent project using Lilac I must have rubbed in a total of 12 applications of BLO, each application soaked into the wood like magic inside an hour, I did this every day for about a week. ( Oh, I carved the stick before applying most of the oil but I did rub some oil into the wood after removing the bark and doing some initial rough carving, the first few applications of oil was to protect the wood from drying over night before I continued refining the carving and sanding ).
After carving a walking stick from that branch, and sanding and burnishing the wood with a hard piece of steel I gave the wood a " SUPER GLUE " finish that is water proof, sealing in the oil and the moisture already in the Lilac .... so far I haven't seen any cracking or checking on the wood. ( Crossed fingers, waiting a year for the wood to dry is still a better idea ).
A good source of information about woods: http://www.wood-database.com/
Lilac: http://www.wood-database.com/lilac/
For comparison Hard Maple: http://www.wood-database.com/hard-maple/
Gregg Sobocinski
Posted: Sat 21 Jul, 2018 7:46 am Post subject: |
I concur with the other commenters. That decoration is well done, and I appreciate seeing your starting material. I just developed an appreciation for these clubs after handling one at Historic Jamestown this summer. It’s amazing how cultures were able to learn the properties of trees to the point of exploiting the dense, hard wood of root balls and limb joints.
A lot of people think of the sheleleigh as a pinnacle of “head knockers”, but I find these clubs to be more elegant.
Thanks for sharing.
Dan D'Silva
Posted: Sat 21 Jul, 2018 8:30 am Post subject: |
Wonderful work, and great use of the opportunity. Maple has such a nice grain with the right kind of stain.
Etienne Hamel
Posted: Sat 21 Jul, 2018 11:36 am Post subject: |
| Jean Thibodeau wrote: | Very good job, looks very attractive and functional. The wood burning decoration is really well done without being overdone.
For comparison Hard Maple: http://www.wood-database.com/hard-maple/ |
thanks jean! well normally (from what i've been told) those clubs are oiled even as green... i guess the oil makes it easier to dry in a sense because moisture isn't removed as quickly. at least the person guiding me along this project said that it doesn'T change anything to oil before or after it is dried. so i would guess that it could be an idea to control the moisture in lilac wood. tung oil has water proof ability too so it might be a good idea, since i moved i don'T have lilac anymore, i only have a maple tree and flowers in the backyard... tung oil seem to be better for some stuff like poping out the grain of the wood and protecting against water. what i hate about tung oil though is that it doesn'T yellow like BLO... it would be interesting to try lilac though.
the stain wasn't that good though... untill i started wet sanding the wood with some oil on it, it looked horrible! glad i found that video on youtube talking about finishing with tung oil...
