Posts: 3,637 Location: Maitland, NSW, Australia
Sun 26 Mar, 2017 8:15 pm
Philip Dyer wrote: |
Dan Howard wrote: | Mart Shearer wrote: | Does anyone have the exact source of the "felt coats" worn by Richard I's men on the Third Crusade? I have seen it cited as being Arabic and Latin, but have never found the specific document. |
I'm pretty sure I used the full citation in the Mail Unchained article. Unfortunately I had to rely on a translation similar to the one above and there is no way to know how accurate it is. Assuming it is correct, there is no way to tell whether the felt was worn underneath or whether it was worn over the top. |
How would the chronicler know about the material or shape of the garment when being worn on the field if the garment was worn under the hauberk? The passage would have probably read that our arrows made no impression on their dense mail. |
How would he have known that their mail was dense and strong without seeing it? He could have seen a dead Frank or simply asked a Frank to show him. There was plenty of interaction between the two sides - even in the middle of a battle they visited each other's camps.
Posts: 1,456 Location: Laurel, MD, USA
Mon 27 Mar, 2017 8:58 am
Arne G. wrote: |
Out of curiosity, what sort of advantage is gained by not wearing any sort of thick lining, padded aketon, or the like under mail? |
Mail literally can't be beat for mobility, flexibility, and ventillation. Not to mention how quick it is to put on. Heavy padding negates all of that, while not *really* stopping the kind of bone-crushing blunt impact that some folks are so worried about.
Matthew
Posts: 1,220 Location: Cork, Ireland
Mon 27 Mar, 2017 9:43 am
Arne G. Depends on how thick you mean exactly, but basically I'd agree with what Matthew and Philip said.
Mon 27 Mar, 2017 11:05 am
Less wieght on you, better mobility, less hot to wear. |
Well, OK. However, how much less weight? Is it really an appreciable fraction of what the iron mail itself weighs? Does the padding really inhibit mobility to any meaningful degree? Finally, earlier in this thread there is an excerpt where Saladin mentions crusaders wearing thick aketons in one of the hottest climates on the planet - why, then, should the wearing of padding (of whatever specific nature) be an object of concern in, say, Northern Europe?
Matthew Amt wrote: |
Mail literally can't be beat for mobility, flexibility, and ventillation. Not to mention how quick it is to put on. Heavy padding negates all of that, while not *really* stopping the kind of bone-crushing blunt impact that some folks are so worried about. |
Properly articulated plate armor does not significantly impede range of motion (with a couple of minor exceptions); overall weight is more of a determining factor w.r.t. mobility - and the weights of comparable levels of mail and plate coverage are pretty similar. Even flexibility is not that badly impacted, though mail is obviously superior in this respect. Quickness of donning is true, though that really only applies to a hauberk or haubergeon worn by itself - chausses for example would require additional effort to lace on. Padding does not necessarily negate any of this - for example, the padding could be sewn integral with the mail, so no additional time would be spent putting it on. Nor should a reasonable level of padding inhibit range of motion to any meaningful degree.
It should be pointed out that the padding need not have been "heavy" - substantial, maybe, but not necessarily heavy. How do you define heavy, anyway? Also, a blow need not be truly "bone crushing" to put you out of a fight - merely fracturing your collarbone could do that, something that padding/lining might easily prevent if worn.
Is there any proof that an aketon would present the level of hardship that is claimed? Are there any studies that can be linked to that prove that mail's positive qualities are degraded or negated by wearing padding? I would be very interested in seeing those.
Posts: 59 Location: Norge
Mon 27 Mar, 2017 12:29 pm
Stephen Curtin wrote: |
Getting back to the subject of arming garments in the Viking Age for just a moment ... So if the idea of arming garments under mail carried on after the Romans, and through to the High Medieval period, then this garment was probably a thick felt tunic, and not an aketon-like garment. ... Other than this, the only other evidence that I know of for felt arming garments in Europe, is that recently some 17th century "buff coats" have been found to have been made from felt, and not buff leather. |
You allways have the Ǫrvar-Odds saga a legendary saga about arrrow-Odd's exploits around Northern Europe written down in the late 13th century saying: "ŝeir váru allir í flókastǫkkum, ok beit á engan járn", something like "They were all in their felted tunic, and no sword would bite". Be warned though, this is the medieval equivalent of GoT or LotR.
[Ed: you find 'em in Sturlunga saga too, where "ŝorbiorn var i ŝófa-stacki, ŝeim er sverdin ŝeira bito ecki, ŝot ŝeir breiddi a tre; ŝann hio Hǫgni i svndr bak ok firir." Compiled in the 12th and 13th century and edited ca 1300, this beeing a late 14th century copy that might contain a corruption of "torf stakkr", Thorbiĝrn beeing hidden in a pile of turf.]
Last edited by Hċvard Kongsrud on Mon 27 Mar, 2017 12:46 pm; edited 1 time in total
Mon 27 Mar, 2017 12:33 pm
Arne G. wrote: |
It should be pointed out that the padding need not have been "heavy" - substantial, maybe, but not necessarily heavy. How do you define heavy, anyway? |
Well this is based on my own interpretation of period sources so it could be off, but then again I don't think anyone knows for sure. I think that typical aketon probably weighed about 5 or 6 lbs. A heavy garment would be something like a 10 - 30 layer jack, which would weigh about 1 lbs per layer. I'm not sure how much padding you can get away with under mail, before it interferes with mobility, or the weight becomes a hindrance.
Arne G wrote: |
Also, a blow need not be truly "bone crushing" to put you out of a fight - merely fracturing your collarbone could do that, something that padding/lining might easily prevent if worn. |
How much padding do you think it take to distribute the force of a strike which would fracture an un-padded collarbone? I think "padding" wouldn't do much. I think that to handle these heavy blows would require more rigid armour. Of course that is just my opinion. I don't know of any studies that have tested this stuff. Those would be interesting.
Mon 27 Mar, 2017 12:35 pm
Thanks for the saga reference Hċvard.
Mon 27 Mar, 2017 1:53 pm
Arne G. wrote: |
Perhaps I misunderstood what you meant by thick padding, but if what you meant was, what advantage would one gain by wearing mail over regular clothing, as opposed to wearing mail over an arming garment? None that I know of. Arming garments would certainly have some advantages over regular clothing, if they didn't, it wouldn't have been invented. The one grey area is, in climates where regular clothing was fairly thick due to the cold, perhaps dedicated arming garments weren't necessary.
Mon 27 Mar, 2017 4:12 pm
Well this is based on my own interpretation of period sources so it could be off, but then again I don't think anyone knows for sure. I think that typical aketon probably weighed about 5 or 6 lbs. A heavy garment would be something like a 10 - 30 layer jack, which would weigh about 1 lbs per layer. |
Weight can increase by up to 100% when it gets soaked with sweat. This isn't a problem when it is worn on top. Rain isn't such a problem: sources suggest that the surcoat was designed to keep armour clean and protect it from rain.
Quote: |
How much padding do you think it take to distribute the force of a strike which would fracture an un-padded collarbone? I think "padding" wouldn't do much. I think that to handle these heavy blows would require more rigid armour. Of course that is just my opinion. I don't know of any studies that have tested this stuff. Those would be interesting |
Yep. The amount of padding required to mitigate these attacks is way too much to comfortably fit under mail - you'd look like the Michelin Man..Rigid protection is required.
Mon 27 Mar, 2017 5:31 pm
Hċvard Kongsrud wrote: |
You allways have the Ǫrvar-Odds saga a legendary saga about arrrow-Odd's exploits around Northern Europe written down in the late 13th century saying: "ŝeir váru allir í flókastǫkkum, ok beit á engan járn", something like "They were all in their felted tunic, and no sword would bite". Be warned though, this is the medieval equivalent of GoT or LotR. |
It really doesn't require much to stop a sword cut. Proper armour was designed to stop points.
Mon 27 Mar, 2017 7:36 pm
Dan. Good point. The weights I suggested were of the dry garments. Of course the weight would significantly increase when they got wet. We have some sources which indicate that attempts were made at waterproofing some of these garments, but sweat would certainly increase the weight from the inside.
As you mentioned earlier thick winter clothes have been recorded historically to have sometimes stopped sword cuts. These felted tunics could just have been thick winter clothes.
Hċvard, does the saga give any more details to suggest if these felted tunics were considered as regular clothing, or as cloth armour?
Tue 28 Mar, 2017 11:39 am
Hċvard, does the saga give any more details to suggest if these felted tunics were considered as regular clothing, or as cloth armour? |
The passage in Arrow-Odd's saga is listing the armour of the raiding party entering Bjarmeland, (Karelia) which make it useable as both, I guess.
The quote from Sturlunga saga is quite entertaining actually - i found a google translate-friendly Danish translation here. (search "filtkofte"). It's your average seven samurai or Bonnie and Clyde scenario, where a gang falls upon a small group in a village, and eight warriors decide to break out. This was pretty recent history when written down, the story of the turbulent years that lead the Icelanders to accept the Norwegian king. Quite a few dramaturgical elements can be found, though. In this passage, where a warrior cut through the impenetrable garment it is obviously concidered cloth armour, It could still be used as a civilian garment too.
One note on climate and clothing: Reenacting winter events in Norway, down to minus 5-10 degrees celcius (23-14 degrees Farenheit) I use a linen undergarment, a single wool tunic and a cloak on my torso, both at around 400 g pr square meter. If works fine if I don't sit down for too long. Off course a supertunic was common too, but one should not overestimate the need for thick clothing even in cold weather when beeing active. The biggest problem in cold weather is getting wet from sweat reducing the clothing's isolating effects.
Posts: 1,302 Location: Jackson, MS, USA
Tue 28 Mar, 2017 4:16 pm
Perhaps he wasn't describing the Crusaders at all, but was assuming they were armed with felt coats like his own infantry, due to his own cultural bias.
Manouchehr Moshtagh Khorasani wrote: |
Most troops could not afford to buy expensive armour and were protected by felt. These
were called namadpu نمدپوش (felt wearer; someone who uses felt as armour). |
Wed 29 Mar, 2017 3:28 am
Thanks for the link Hċvard. For some strange reason the Google translate function isn't working for me right now, but when I figure it out, I'll be sure to have a read through. As for the thickness of clothing. In battle you most likely wouldn't be wearing your cloak, and so might choose to double up on layers of clothes. You might even wear two linen undershirts and two wool tunics. Of course most of the fighting took place in the summer months, so this might not have been necessary. Either way I think that the clothing worn in Europe would have been thicker than those worn in the Middle East, where I believe aketons most likely originated. My point is that because lighter clothing was worn in hotter climates may have necessitated the invention of specialized arming garments.
Mart. That's possible. Of course it's also possible, as Dan mentioned, that there are errors in the translation. For all we know the author might have meant that some crusaders worn mail and others worn a thick felt garment. The translation makes it seem like each man worn both a hauberk, and a felt garment, but without getting someone familiar with the language to take a look at the original, we can't be sure of anything. Who knows perhaps "felt" isn't even the correct translation. We've seen bad translations lead to misconceptions before. The "leather jerkin" from Gerald of Wales springs to mind.
Wed 29 Mar, 2017 3:31 pm
Then there is the question of what is considered "felt".
In the Sixteen Regulations of Armorers, Fabric Armorers, and Helmers of Paris of 1364,
http://gallica.bnf.fr/ark:/12148/bpt6k55440899/f332.item , Article 4 describes the making of linings for
bascinets and camails with this line:
Quote: |
Et que nul ne face fouceau ou bassinet, se il ne lui est commandé, et que le feutre soit couchié de coton neuf sur vieilz linge et enterin flotté de cendail, et contrendroit, de la couleur du cendail. |
...and the felt (feutre) is laid down of new cotton (coton neuf) on old linen and in between entirely floated in cendal,....
Which sounds like loose cotton fiber sewn to old linen and covered with silk is considered to be "felt".
Thu 30 Mar, 2017 2:30 am
Good point. The word had a different meaning at the time. Today it is largely used to describe matted wool.
Thu 30 Mar, 2017 2:48 am
It seems that without having someone look at the original text, who is familiar with the language, history, and the textiles of the region, we can't be sure of the translation. So until this happens, we can either take the above translation at face value or ignore it altogether.
Sat 01 Apr, 2017 1:09 am
I think that it's possible that panzar could mean everything from aketon to gambeson to surcoat. We have an example of something similar in the way that German speaking people used the word waffenroc. Correct me if I'm wrong, but waffemroc could be used for surcoats as well as padded garments.
Jason
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
