Go to page Previous  1, 2, 3, 4, 5, 6
A most interesting and informative thread- many thanks to all the contributors. I know this thread has been around for some time, but one aspect hasn't been covered, as far as I can tell.
Who, of today's commercial , over- the- counter makers ( not custom) makes the most accurate Falcattas or Kopis today ?
Oog, well, "most accurate" may be better defined as "the worst except for all the others". Deepeeka has had a falcata which looks reasonable for a long time, very Iberian in style with a by-knife on the scabbard. They also have a couple kopis versions which don't look too bad at first glance, but I'd have to see them in more detail to judge. I'd be willing to bet they're too heavy, at least.
The movies of the last few years really haven't helped the workshops in India, etc., visualize what a *real* kopis looks like...
Matthew
Khukri Thrusting
Nathan Robinson wrote:
I don't know a whole lot about these swords, so please keep that in mind when reading this question. While I think it's obvious that these types of blades are extremely adept at chopping and cutting, I'm curious about the ability for them in the thrust. It would seem to me that the shape of the blade, like a khukri, would put the tip in a very natural position for an easy thrust. In other words, while the shaping of the blade makes for a more efficient chopper, it would seem to me that it doesn't detract from the thrusting ability. Thoughts?
Thrusting can be difficult for a couple of reasons. First, the distance to your target is not proportional to the length of the blade. While the user can overcome this, it's best realize as a buyer that a khukri with a 12 inch blade does not have a 12 inch "reach". Reach is more like 9 inches because of the dog leg in the blade.
Second, the downward cant of the blade can cause problems if a thrust encounters bone or body armor. The linear force of the thrust can be deflected by difficulty when penetrating, levering the blade downward and potentially out of your hand. British soldiers who were issued khukri's took specialized training in their use, including the thrusting issue. Thrusting IS possible, but the khukri's main purpose is chopping or slashing.
Many Greek kopides in artwork have a straight or nearly straight back, so thrusting would be no different than with a straight sword. The weight and balance were all in the same ballpark, too. It's the Spanish version which is more angular, but even there, I'd be surprised if it were so extreme as to affect your reach significantly.
Matthew
Re: Khukri Thrusting
Usual practice is to measure the length of the blade in a straight line from the base to the tip; with this convention, a 12" blade does have 12" reach. Similarly, it's usual to measure curved sabre blades, katana blades, etc. in a straight line. It's easier, and more useful information.
I get what you are saying, and I don't disagree, but my son has been in Nepal on disaster relief missions and he has witnessed khukri makers measure blade length along the spine. That seems to be routine practice in that area.
Makes a difference. Checking with the closest kukri at hand, measuring along the spin gives 35cm, and measuring from the base of the blade to the point in a straight line gives 32cm. Half of that difference is due to measuring the straight line distance from the base of the blade at the front rather than at the spine; the straight line distance from the base of the spin to the tip is 33.5cm.
(The middle of the base of the blade is sometimes used as a compromise. )
Page 6 of 6
