Forum Index > Makers and Manufacturers Talk > Swiss longsword - collaboration with "The Printed Armoury"! Reply to topic
This is a standard topic Go to page Previous  1, 2, 3  Next
Lukas MG
PostPosted: Sun 01 Jan, 2017 7:50 am    Post subject:         Reply with quote
The blade is polished and all components are in place. Ready for peening!
Custom sword maker:
http://www.lukasmaestlegoer.com
T. Diamante
PostPosted: Tue 03 Jan, 2017 8:12 am    Post subject:         Reply with quote
This one is coming together nicely! Are you planning on making a waisted grip for it?
Mark Moore
PostPosted: Tue 03 Jan, 2017 8:30 am    Post subject:         Reply with quote
I second that! Please, oh please...make a waisted grip! Maybe a half-wire? Big Grin That would look awesome! Big Grin ....McM
Lukas MG
PostPosted: Wed 04 Jan, 2017 2:04 am    Post subject:         Reply with quote
It will get a waisted grip, yes. Only appropriate grip shape for such a sword in my eyes Wink
No plans for a wire wrap though.
Custom sword maker:
Jean Henri Chandler
PostPosted: Fri 06 Jan, 2017 12:31 pm    Post subject:         Reply with quote
Exquisite weapon. What are the weight / dimensions?
System D'Armes Historical European fencing in New Orleans
Essays on Hroarr
Introducing the Codex Guide to the Medieval Baltic
Lukas MG
PostPosted: Sat 07 Jan, 2017 4:33 am    Post subject:         Reply with quote
Blade length is 95cm, overall slightly over 120cm if I recall correctly.
Weight will be around 1650g, the complex guards adds a good bit but being close to the hand, it's not a big problem.
Custom sword maker:
Mark Moore
PostPosted: Sun 08 Jan, 2017 3:14 pm    Post subject:         Reply with quote
And now, back to that grip! I'm living vicariously through you right now. Tell me it will be a rich, deep Oxblood red. Excuse me--had to wipe the saliva from my bottom lip just thinking about it. Big Grin ....Come on...really....What color have you decided on? Inquiring minds want to know! Big Grin .............McM
Lukas MG
PostPosted: Mon 09 Jan, 2017 4:30 am    Post subject:         Reply with quote
The customer indeed picked a dark oxblood red Wink
Custom sword maker:
Lukas MG
PostPosted: Thu 26 Jan, 2017 1:20 am    Post subject:         Reply with quote
Pommel is peened. It was a bit tricky with the peen being lower in niveau than the "points" of the pommel. I also wholly underestimated how much of a pain it is to clean off the oxides. The many groves and recesses make it impossible to reach all spots. I will do some more sanding once the grip is in place but I won't be able to get all traces off. A sand-blasting device would be handy but alas, I don't have one. Oh well, they had the same problems back then with this pommel shape.
Also, the wooden grip core is finished. You already get a good impression of what the sword will look like when done. Keep in mind the grip core is a tad undersized to allow for the cord and leather wrap.
I'm happy with the handling, the substantial and complex guard called for a wide, imposing blade and I wanted to make a powerful, smooth cutter with good point control. I think I succeded.
Custom sword maker:
T. Diamante
PostPosted: Thu 26 Jan, 2017 5:40 am    Post subject:         Reply with quote
Lukas the sword is really coming to life! Do you think if you did another pommel like that anything could be done differently to make peening easier?
Lukas MG
PostPosted: Fri 27 Jan, 2017 4:49 am    Post subject:         Reply with quote
Thanks!
I don't think there's any way of making it easier... that's just the problem with any type of pommel where the peen is difficult to access. Peening actually wasn't the issue, the clean-up is. I might give the dremel a shot at this... though it's really not bad, the slight dark patina is rather attractive, too.
Custom sword maker:
Mark Moore
PostPosted: Fri 27 Jan, 2017 6:57 am    Post subject:         Reply with quote
If you were making that for me (Oh, I wish!) I would have you leave it be, with only the slightest amount of clean-up. I, personally, find hammer marks on a pommel peen to be a selling point and very attractive. It lets you know--"Hey, this was made by a REAL person!" Some famous makers--I shall name no names--polish their peens to the point of near invisibility. I want to see it. I feel that it is a pure character mark--a sword 'birthmark', if you will, and gives the sword a feeling of empowerment. But....that's just me. Happy Beautiful sword...can't wait to see the final results! Big Grin .....McM
Lukas MG
PostPosted: Sun 29 Jan, 2017 3:47 am    Post subject:         Reply with quote
Swiss longsword
The Swiss longsword is finished. This piece is a collaboration between Mike Jia from the Printed Armoury and myself. He supplied the fittings, I did the rest. The fittings are inspired by those often (not exclusively) seen on swords from 15th/16th century Switzerland.
Stats:
Overall length: 120cm
Blade length: 95cm
Handle length: 19cm
Blade width (at base): 5.5cm
Blade width 1“ from tip: 1.2cm
COG: 12cm
COP: 67cm
Weight: 1640g
This is an imposing sword, with a wide blade and eye-catching fittings. The type XVIIIa blade combines excellent cutting ability with a deadly point. It is a sword that performs best against unarmored opponents, with a blade that retains sufficient width to allow for efficient cutting all the way to the point. While not quite rigid and narrow enough to readily deal with armor, the blade is plenty stiff and the point has no trouble penetrating deeply into soft targets.
The edges are of convex shape, most sturdy in the lower half and more acutely honed in the foible. This gives a more resilient base for parries and bind work without sacrificing the offensive capabilities.
Overall, the goal of this design was to produce a quick, powerful cutter with good point control. The result is a sword with noticeable blade presence yet agile and attractive handling characteristics.
I have only cut light targets with the sword so I can‘t say for sure but I believe it may be one of, if not the best cutting longsword I‘ve made to date. The little bit extra width and blade presence compared to my last XVIIIa is noticeable in its performance.
Mike Jia‘s fittings really are quite nice. They aren‘t completely flawless, with a few pits here and there and other slight casting marks. I do appreciate that, too perfect a finish would have looked out of place on an otherwise entirely hand-made piece. So I can certainly recommend „The Printed Armoury“ and am looking forward to future collaborations.
Thanks for reading!
Lukas
Custom sword maker:
Ian Hutchison
PostPosted: Sun 29 Jan, 2017 5:58 am    Post subject:         Reply with quote
Really nice work guys, very beautiful sword. Is the plan to keep this one or sell it? It will be interesting to see what other blades people will pair with these fittings.
Lukas MG
PostPosted: Sun 29 Jan, 2017 7:16 am    Post subject:         Reply with quote
Thanks, Ian. This was a commission so it's already sold...
Custom sword maker:
Mark Moore
PostPosted: Sun 29 Jan, 2017 7:57 am    Post subject:         Reply with quote
Fantastic....just as I had pictured in my mind, with the waisted grip in Oxblood. Absolutely fantastic! Big Grin ......McM
T. Diamante
PostPosted: Sun 29 Jan, 2017 8:26 am    Post subject:         Reply with quote
Nice work Lukas! It really turned out to be a very elegant weapon. I have an XVIIIb blade and this makes me excited to see how they pair.
And, despite how eye catching the hilt is, through this whole process the first thing I notice is always that clean fuller transition...
Julien M
PostPosted: Sun 29 Jan, 2017 11:13 am    Post subject:         Reply with quote
Splendid blade and grip work Lukas - blade finish is especially good.
I like the fittings too and think they are a great deal for the price, I just wish PA would stick more closely to historical examples and simpler forms. I'm hopeful I will get some one of these days, depending on what the next batch will look like.
J
Lukas MG
PostPosted: Mon 30 Jan, 2017 1:09 am    Post subject:         Reply with quote
Thanks guys.
@Julien: yes, some simpler fittings would be a very nice thing... some standard model wheels, etc.
Here's the cutting video:
https://youtu.be/uMqLLWRDlbk
Custom sword maker:
Jeremiah Swanger
PostPosted: Mon 30 Jan, 2017 8:05 pm    Post subject:         Reply with quote
Lukas,
Your sense of balanced lines and proportions never ceases to amaze! Each new sword you make seems just a touch more impressive than the last. I look forward to seeing what you can craft in the near future!
"Rhaegar fought nobly.
Rhaegar fought valiantly.
Rhaegar fought honorably.
And Rhaegar died."
Page 2 of 3 Reply to topic
