The baselard has an 8" hollow ground blade with a steel guard, lined in bronze and fitted to a buffalo horn grip. The top guard is solid silver and crowned with bronze rivets and also lined in bronze. The grip itself has silver wire inlay to each side following the grips facets. The sheath is finished with a bronze chape.
The bauernwehr has 6.5" flat ground blade and a classic pommel and bolsters and has a nagel on each side to protect the knuckles and thumb. The blade has some file work to the spine. The knife also has buffalo scales and silver pin work in a floral/vine motif. The sheath is finished again with a bronze chape.
The 'scalpel' has a bauernwehr style grip, filer work to both sides of the tang, a double sided 'dagger' style blade and again with black buffalo scales and silver pin work and the sheath is finished with a bronze chape.
The three knives are individually mounted in a carrying frog and tied in on the rear, but can be dismounted as required.
I hope you like them.
