Eytan K.
Posted: Tue 11 Oct, 2016 10:32 pm Post subject: Del tin swords - reprofiling |
Hello,
I own a Del tin Venetian great sword (2162) and I want to order the 6169, 6154 or 7164.
In my opinion Del tin swords gives great value for the price, and I don't have the funds for Albion or similar.
I use my swords for performance cutting.
I read the debates in this forum regrading the fact that Del tin swords are not optimal for cutting due to the problematic blade geometry- blunts and weight (I will not grind a secondary bevel on them )
Regarding the steel: Del tin's steel is tough, and I have no worries on that.
I practice and provide services in water-stones blade sharpening, mostly knives, sometimes long blades such as machetes. Swords is a different story.
Bottom line: I need the advice of experienced members on how to re-profile my Del tins to highly effective cutters.
Thank you
Mark Griffin
Posted: Wed 12 Oct, 2016 1:20 am Post subject: |
I just use a hand file then stones and work on them til I'm happy. I prefer this method as its more traditional and i hate playing with sharp blades and power tools. It also gives a better finish imho than the more obviously machined modern repros.
Ant Mercer
Posted: Wed 12 Oct, 2016 4:10 am Post subject: |
I concur with Mark: I have had no problems using hand files. Finish it off with various grits of wet-and dry, and job's a good'un.
Eytan K.
Posted: Thu 13 Oct, 2016 9:12 pm Post subject: |
Thanks,
I'll give it a go,
You recommend for the first stage ,removing the steel, a single cut Bastard or double cut Bastard?
