Things like the image below but hopefully with more detail.
Thank you.
| Craig Peters wrote: |
| Are two-point suspensions more commonly found on long sword scabbards intended for cavalry wear? I notice that nearly all of the mounted images show this form of suspension, while images of long swords worn by men on foot often seem to lack the two point attachments. |
| Eric LeClair wrote: |
| That's just an incredible share @Sean Flynt Thanks for sharing such awesome pics. |
| Sean Flynt wrote: |
| The one that's a simple frog with gilt iron (?) fittings really grabs my attention. I think it might be meant to match a belt hook. It's another type I'd love to try. The scabbard attachment is dead simple and ripe for tooling, metal applique, tacks, gilding, etc. I would pair this with a gilded iron or brass hook and a broad, decorated belt like the one in the background. What a set that would be!
Cornelis Tromp posted the images of a hook mechanism for a messer suspension: http://www.vikingsword.com/vb/showthread.php?...&pp=30 The other image is Peter Johnsson messer of this period with a variant of the single-point suspension. That knot or slide arrangement might be like what we're seeing in some of the ImaReal images I posted above. |
| Sean Flynt wrote: |
| Hello! An Apple update wiped out my Mac and the stuff I was able to save is a bit scrambled so I don't have the specific image number for that. However, it's from this incredibly rich source: http://tethys.imareal.sbg.ac.at/realonline/
If you select the date range (probably 1480-1530) and search the German terms for scabbard, belt, purse, etc. It will turn up somewhere. The site will show the full image and several details, including this one. Good luck! Judging from your name, I'm guessing you won't have a problem with the German terms, but let me know if that's not the case. |
