Posted: Wed 28 Sep, 2016 10:20 pm Post subject: Early 16th century longsword scabbards |
Can anyone share some historical images of scabbards for early 16th century longswords with me? I'm looking for historical artwork or extant originals to find inspiration for scabbard details, chape and locket designs, and suspension styles.
Things like the image below but hopefully with more detail.
Thank you.
Attachment: 124.99 KB
Lloyd Winter
Posted: Thu 29 Sep, 2016 8:13 pm Post subject: |
For suspension tips you might look at the Durer St Eustace altarpiece and the Death the Knight and the Devil engraving. Both are pre 1520 as I recall.
Craig Peters
Craig Peters
Craig Peters
Craig Peters
Posted: Fri 30 Sep, 2016 8:06 am Post subject: |
Are two-point suspensions more commonly found on long sword scabbards intended for cavalry wear? I notice that nearly all of the mounted images show this form of suspension, while images of long swords worn by men on foot often seem to lack the two point attachments.
Mark Lewis
Posted: Fri 30 Sep, 2016 9:50 am Post subject: |
I'm going to post a number of things from this period that I know are not quite what you're looking for, but will be good to gather here. I'm still looking, but here's something that might be of special interest--an elite sword with a decorative locket and tooled scabbard. No suspension shown here, unfortunately, but I would assume that the simple knot most often seen on scabbards of this period and culture would not work. Staple or ring on the back of the locket, maybe, meant to ride on a belt hook? Or, possibly, not meant to be worn, but carried in the crook of the arm as a ceremonial weapon. (?)
German, 1510 (via ImaReal)
Attachment: 88.39 KB
Posted: Fri 30 Sep, 2016 10:00 am Post subject: |
A few more from ImaReal. My search range for these was 1510-1550.
Note that in some of those martyrdom images, the sword scabbard is on the ground, with suspension clearly visible.
FWIW, I have used the single knot on all my scabbards, and find them to work extremely well. It holds the weapon at the correct angle and allows the belt to rest loosely on the top of the right hip.
Attachment: 470.45 KB
Attachment: 453.79 KB
Attachment: 388.26 KB
Attachment: 56.73 KB
Attachment: 393.16 KB
Posted: Fri 30 Sep, 2016 10:02 am Post subject: |
Craig Peters wrote: | Are two-point suspensions more commonly found on long sword scabbards intended for cavalry wear? I notice that nearly all of the mounted images show this form of suspension, while images of long swords worn by men on foot often seem to lack the two point attachments. |
I've noticed this, too, but I don't know the answer. I also haven't looked at other suspension systems and who is depicted with them.
Posted: Fri 30 Sep, 2016 10:26 am Post subject: |
The one that's a simple frog with gilt iron (?) fittings really grabs my attention. I think it might be meant to match a belt hook. It's another type I'd love to try. The scabbard attachment is dead simple and ripe for tooling, metal applique, tacks, gilding, etc. I would pair this with a gilded iron or brass hook and a broad, decorated belt like the one in the background. What a set that would be!
Cornelis Tromp posted the images of a hook mechanism for a messer suspension: http://www.vikingsword.com/vb/showthread.php?...&pp=30
The other image is Peter Johnsson messer of this period with a variant of the single-point suspension. That knot or slide arrangement might be like what we're seeing in some of the ImaReal images I posted above.
Attachment: 175.48 KB
Attachment: 67.36 KB
Attachment: 98.5 KB
Attachment: 194.62 KB
Attachment: 281.78 KB
Eric LeClair
Posted: Mon 03 Oct, 2016 2:09 pm Post subject: Wow |
That's just an incredible share @Sean Flynt Thanks for sharing such awesome pics.
Hass Fernen
Posted: Tue 19 Mar, 2019 8:43 am Post subject: |
Sean Flynt wrote: | The one that's a simple frog with gilt iron (?) fittings really grabs my attention. I think it might be meant to match a belt hook. It's another type I'd love to try. The scabbard attachment is dead simple and ripe for tooling, metal applique, tacks, gilding, etc. I would pair this with a gilded iron or brass hook and a broad, decorated belt like the one in the background. What a set that would be!
The other image is Peter Johnsson messer of this period with a variant of the single-point suspension. That knot or slide arrangement might be like what we're seeing in some of the ImaReal images I posted above. |
Hello Sean, would it be possible to get a source for that sword with the gilded flower design. Thank you.
Hass Fernen
Posted: Tue 19 Mar, 2019 9:40 am Post subject: |
Sean Flynt wrote: | Hello! An Apple update wiped out my Mac and the stuff I was able to save is a bit scrambled so I don't have the specific image number for that. However, it's from this incredibly rich source: http://tethys.imareal.sbg.ac.at/realonline/
If you select the date range (probably 1480-1530) and search the German terms for scabbard, belt, purse, etc. It will turn up somewhere. The site will show the full image and several details, including this one.
Good luck! Judging from your name, I'm guessing you won't have a problem with the German terms, but let me know if that's not the case. |
Thanks a bunch Sean. Appreciate it.
