Posts: 272 Location: Scotland
Mon 11 Jul, 2016 9:26 pm
I'd just like to add my weight behind the fact that sword is not original.
I've handled, oh, a good few hundred medieval swords now, from the 10th to the 16th centuries, from all over Europe, and I've studied more in publications and academic papers than I can even begin to list.. That's not a medieval sword.
the fuller position on the blade is a great big flashing neon warning sign of its origins. I see no indication of a difference in patina between fuller and blade flats to indicate that this was recently added, even if such a process were likely to be done. That any restorer would grind in fullers to an unfullered blade, frankly, strikes me as nonsense on par with the notorious Blanken
shield conspiracy theory on the Armour Archives that all armour had rolled edges, and the curators were snipping them off...
While the photography is, if you'll excuse my bluntness, crap, I'm not seeing any indication there of significant age. the patina there is no different to carbon steel blades I have in my workshop from the 1930's to 50's. It does not have the sort of depth of patina I'd expect of an original - even around the tang hole where the sort of cack-handed restorer who might grind a fuller in would struggle to reach into the corners..
the entire pommel - the technique of decoration, and the artistic style of decoration used on it, even the tone of the metal itself looks to be a modern zinc brass. the round drilled slot, likewise. Again, there is nothing of the sort of patina I'd expect of an original.
the tang
cross-section is nothing more than a wallhangar with no resemblance to originals. If by some freak of chance the blade is antique, then there is no way in hell that the tang is original too - and by association, we must conclude the hilt furniture attached to it is equally suspect.
the details of the cross are ropey as hell, I'm seeing the sort of striations I'd expect off a slack belt sander without a platen, running something like a 80-120 grit belt. It is in no way medieval.
blade, cross, tang, pommel. None of those components are medieval or display the characteristic details I'd expect from even a rudimentary replica. I am exceptionally sceptical that any of the historians at Wawel would consider this to be an original, in any shape or form, unless their field of research was absolutely unrelated to medieval arms.
Quite simply, this item is as bent as a €6 note.
At my most charitable, I'd say you have a lovely example of a mid-20th century, low-quality replica, probably from between the end of WW2 and 1980.
I understand you may wish to lash out angrily at those like Mark and Tim who were rather blunt - especially if you paid anything more than a tenner for this thing. However, their comments were absolutely spot on. Even a cursory review of photographs shows nothing even remotely indicative of a medieval sword of any date, yet alone one of 14th century origin.
