Andrew MJ
Posted: Fri 28 Aug, 2015 11:53 pm Post subject: Identifying this Harness |
Hi, not sure where this belongs but this seems like the best place.
I bought this armour on craigslist recently and have had trouble placing it in its era. The breastplate doesn't look like a reproduction of anything specific, but I could be wrong. After looking at hundreds of pictures on the forums and on pinterest, flickr, etc. I still can't place the breastplate.
Is it a composite of different eras or is it all relatively from the same period? 1400-1500? I'm trying to narrow down what type of helmet to buy!
Thanks!
Edward Lee
Posted: Sat 29 Aug, 2015 12:25 pm Post subject: |
That harness was made by armstreet, it was their first generation Gothic harness. It was not accurate but their current second generation is a lit better.
Andrew MJ
Mark Griffin
Posted: Tue 01 Sep, 2015 12:34 pm Post subject: |
a sallet or armet would be the way to go.
Andrew MJ
Posted: Tue 01 Sep, 2015 12:57 pm Post subject: |
I have my eye on a sallet. An Armet could be interesting. A little more difficult to find in Canada. Thanks Mark.
Edward Lee
Mark Griffin
Posted: Wed 02 Sep, 2015 12:24 am Post subject: |
btw, I only suggested an armet as I thought aesthetically it might work. Should be a sallet if you want to be more accurate as its trying to be a bit 'gothic' or N European.
Andrew MJ
Posted: Wed 02 Sep, 2015 7:05 am Post subject: |
Thanks. Battle merchant has some great prices. Looks like decent quality, too.
Yea, I'd like to stick as close as possible to period accurate helmets. As much as that's possible anyways, lol.
EDIT: Ok, this one looks awesome. Fully articulated bevor, riveted to the inside of the helmet. But no liner. Is a padded cap a good substitute? http://www.battlemerchant.com/Helmets/Late-Mi...:3180.html
Mark Griffin
Posted: Wed 02 Sep, 2015 7:15 am Post subject: |
The armet is period accurate, but not regionally. But prefer them for looks and use.
Andrew MJ
Posted: Wed 02 Sep, 2015 7:28 am Post subject: |
Ok good to know. Yea, I think I'd like to be regionally accurate as well, not that Armets don't look just as awesome if not more so. Thanks for the info.
EDIT: I plan on sparring using this armour, so is there much of a difference functionally between the sallet and armet? In other words, which would be better to keep my head from ringing?
Andrew MJ
Posted: Wed 02 Sep, 2015 7:45 am Post subject: |
Also, I don't have an arming jacket or gambeson. Having difficulty finding one that's suitable and will hold up well.
Mark Griffin
Posted: Wed 02 Sep, 2015 7:56 am Post subject: |
Many jousters and foot combat exponents worldwide use these. I have many and swear by them as the only versions worth considering in that price range.
[url]
http://historicenterprises.com/index.php?main...cts_id=713
[/url]
Mark Griffin
Posted: Wed 02 Sep, 2015 7:58 am Post subject: |
But have a care to work out what mail system you are using before plunging in to doublet purchase. Lots of new theories and research out there so before asking HE to make something with loads of point holes in, make sure you need to.
Andrew MJ
Posted: Wed 02 Sep, 2015 8:01 am Post subject: |
Wow, yea, I saw that in another thread. Pretty amazing work they do. I will definitely consider it. Would you recommend the linen or cotton version?
Mark Griffin
Posted: Wed 02 Sep, 2015 8:06 am Post subject: |
I have both and they all stand up pretty well. My principle jousting one is cotton and is only starting to wear out after 6 or so tears of very hard use.
I feel the cotton one breathes better and is easier to clean but its totally down to what the cloth is. Linen would be the only choice for living history purposes of course.
Andrew MJ
Posted: Wed 02 Sep, 2015 8:23 am Post subject: |
Good to know. Yea, it looks great. Really considering it. The price hurts though, Can't imagine a higher price range than that!
Mark Griffin
Posted: Wed 02 Sep, 2015 10:32 am Post subject: |
Its incredibly reasonable for a bespoke garment.
But there again i joust so have the mentality that if its not right you'll probably be injured or worse. Each and every part of what you wear and use has to be 100% or forget it. Buy cheaper and you'll be buying again very soon most likely.
Andrew MJ
Posted: Wed 02 Sep, 2015 10:54 am Post subject: |
Great point. Yea, I can't imagine a cheaper one being of any use whatsoever if it tears after a few hits. That just won't do.
Mark Griffin
Posted: Wed 02 Sep, 2015 11:43 am Post subject: |
Its not only the strength, its the movement and comfort. Those have had some serious testing in the field so work.
Andrew MJ
