Lancelot Chan
Shahril Dzulkifli
Posted: Tue 16 Jun, 2015 5:50 am Post subject: Alvin DS single-handed cuts |
Why does that sword cannot hold its edge well? Does it shake when you swing it?
- Marcus Aurelius
Lancelot Chan
Posted: Tue 16 Jun, 2015 5:56 am Post subject: Re: Alvin DS single-handed cuts |
| Shahril Dzulkifli wrote: | | Why does that sword cannot hold its edge well? Does it shake when you swing it? |
Because it may not be heat treated. The sword was made from a used truck spring leaf, with hole in the blade plugged to show that. Hardness is 40hrc around, so can't hold the edge well. No, it doesn't shake when I swung it though. I poured glue into the hilt to make it tight.
