I had been looking for a long sword to wear with my early 14th century armor kit when I found the Savoy (http://www.valiant-armoury.com/catalog/txt_VA120SE.html) at Valiant armory. The specs were just what I wanted, but I didn't like the flared cross and the sword suspension didn't look right for my time period. Sonny Suttles agreed to do a custom cross and sword belt to bring the sword more into my period of interest, and here are the results:
Overall Length: 45"
Blade Length: 35.5"
handle Length: 7.5"
Cross Length: 7.5"
Point of Balance: 5.25"
Weight: 3.1 lbs
Handling
A little background on me will be useful when talking about this sword's handling. I ran a German longsword study group about 10 years ago, so I know the basics of how a sword is supposed to feel and function. I am used to swords like Lutels and Del Tins, which are definitely on the heavy side. Compared to what I'm used to, this sword is a beauty to handle. In one hand, it's easy to strike, recover and change directions. In two hands, it floats like a steel feather. Part of that is due to the pretty aggressive rate of distal taper, resulting in a very thin and flexible tip area. To compare it to a sword most of this forum may be familiar with, it feels more like an Albion Crecy than anything else.
There's no question that this sword feels very lively, well balanced and responsive in the hands, but is that appropriate for a weapon of this kind? XIIas from other makers that I've handled (Lutel, Del Tin, Albion, MRL) have had more of a forward cast to the blade to aid in the cut, while the Savoy definitely has a more neutral feeling. That livelier feeling MAY translate into poorer results at the cutting stand. When I am able to set up cutting tests with this sword, I'll report back with results.
Aesthetics
I'm not going to talk around it: in terms of fit and finish Valiant Armory is the best in this price level. I love how this sword looks. The blade is taken to a medium-gloss finish which sets off the darkened cross and pommel perfectly. The cord-under-leather grip wrap is excellent, with a very unobtrusive glued seam.
There are some blemishes. The peen, although it looks strong, is very noticeably off-center on the pommel:
The fullers are not perfectly straight either, they wander a bit and they have a slight ridge running down the middle.:
I don't really mind those imperfections, they give the piece some handmade charm in my eyes. But they are something to keep in mind if you want your swords to have machine-perfect lines.
