Eric S
Posted: Wed 29 Oct, 2014 6:53 pm Post subject: Chinese mace, truncheon, sai, iron whips etc. |
While discussing the origin of a sai recently I realized that there were just not enough available images of antique sai. Without representitive images that have a known origin it is hard to make a definite determination on any weapon other than guessing.
I decided to put together a Pinterest gallery with as many examples of Chinese iron bar weapons as I could find, this includes maces, sai, whips, etc. I have tried to weed out replicas as much as possible and I have tried to only include weapons that I know originally came from China or are easily identifiabe as being Chinese based on very close similarity to known examples.
Hopefully this gallery will be of use to anyone with an interest in these types of weapons. While researching this subject I came across only a handful of sai that were known to originate outside of China, these came from the Indonesian area, I have yet to find even one documented antique Okinawan sai.
One thing that is readily apparent is that the Chinese really liked the four sided profile, this creates a very sharp edge, the Indonesian examples I have seen either were round or eight sided, the Japanese jutte is also very rarely four sided.
http://www.pinterest.com/worldantiques/chines...whips-etc/
Luke Adams
Posted: Wed 29 Oct, 2014 7:50 pm Post subject: |
Very interesting stuff. I think the Chinese whip or truncheon deserves a lot more research. I've only been able to find a few historical sources outlining its techniques (http://www.chineselongsword.com/whip.shtml).
"God gives the nuts, but he does not crack them."
- German proverb
William P
Posted: Wed 29 Oct, 2014 11:11 pm Post subject: |
i always enjoy chinese weapons, and indian ones, because they can be so outlandish...
Timo Nieminen
Posted: Thu 30 Oct, 2014 4:03 pm Post subject: Re: Chinese mace, truncheon, sai, iron whips etc. |
Eric S wrote: | One thing that is readily apparent is that the Chinese really liked the four sided profile, this creates a very sharp edge, the Indonesian examples I have seen either were round or eight sided, the Japanese jutte is also very rarely four sided. |
The Chinese used both orientations of the four-sided profile, with a corner forming the intended striking surface (usual on 4-sided jian maces and cha (sai)), and with a flat face forming the intended striking surface (usual on the "iron ruler")
Shahril Dzulkifli
Posted: Tue 23 Dec, 2014 5:59 pm Post subject: Chinese mace, truncheon, sai, iron whips etc. |
The Chinese truncheon looks more like a sword to me but it's more likely used to break sword blades.
- Marcus Aurelius
Timo Nieminen
Posted: Wed 24 Dec, 2014 2:30 pm Post subject: |
This kind of mace/truncheon (jian, 鐧) is often called a "swordbreaker". As to whether it would break swords, the combat-usable one-handed ones are usually between 1 and 2kg, and two-handed swords of 2+ kg aren't super-swordbreakers. So why would these be much better? Of course, the user won't fear damaging his/her own edge, and can happily smack it into the opponent's sword harder than they might be willing to risk if they were using a sword.
John Hardy
Posted: Thu 25 Dec, 2014 1:02 am Post subject: |
I found this very interesting. I have occasionally eyed the Cold Steel Chinese Swordbreaker over the years, without ever buying either it or the polypro 'trainer'.
I had always thought that it was probably a development from some kind of 'bar mace', with the flanges simplified. But looking at these, I see the hollow-ground 'swordbreaker' is actually possibly more sophisticated variant of the four-sided truncheon, with the edges hollow ground to give a sharper striking edge.
Incidentally, some of the 'tests' on the Cold Steel video of its version show the swordbreaker being used to strike the blades of various kinds of swords locked in a vice - and the breaker does do a rather thorough job of bending most of them into spaghetti noodles (even though none of them break). While that test is mainly intended to show how 'tough' the CS swordbreaker is and is obviously wildly inaccurate in demonstrating how it would actually be used in combat -- it does appear to me to show that a Chinese 'swordbreaker' or truncheon (and probably, for that matter, one of the bigger Japanese jutte) could be used not so much to break an opposing sword as to bend it - especially if hit while the blade was 'pinned' between the sword wielder's hand and something like the edge of a shield.
In addition, if a user deliberately struck at a sword edge (because the sword wielder was too far out of range to make an attack on their body), the truncheon could potentially chip it rather badly - and thereby create a possible weak spot that might cause blade failure later on in the battle. Meanwhile, of course, the user of the breaker or truncheon doesn't really need to worry about equivalent damage on his own weapon -- because it doesn't have much of an edge to chip and also because it looks like most of them were made either of iron or else of mild steel tempered for toughness but not much hardness.
However, where I imagine these truncheons would really shine would be as close-quarters weapons used for binds and joint locks, as well as for 'half-swording' style thrusts and with the usual mace-style strikes of opportunity thrown in without concern for edge alignment.
Timo Nieminen
Posted: Thu 25 Dec, 2014 3:14 am Post subject: |
An old manual for the two-handed version: http://www.chineselongsword.com/whip.shtml
Used much like a longsword.
There is a risk to attacking an opponent's sword: it gives the opponent a free hit at you. Just move the sword to avoid the "swordbreaker", and cut at the same time. Don't need to worry about being hit, since the swordbreaker is targeting your sword, and not you.
("Swordbreaker" is AFAIK only a Western term for the weapon.)
X Zhang
Posted: Thu 25 Dec, 2014 7:25 am Post subject: |
well……you know, “jian3” (锏 the third tone,not “jian4” 剑 the fourth tone) is a broad category of weapons.
A thousand years ago, jian3 just was a big metal stick which can be used as a secondary weapon for equip heavy infantrys
but 500 years ago, jian3 usually can be regarded as a small sword which strengthened by bludgeoning .......so......
it is more akin to the original
Tyler Jordan
Posted: Thu 25 Dec, 2014 4:21 pm Post subject: |
I have to wonder if said 'swordbreakers' were more useful in China's bronze age, where one could likely quite trivially bend a bronze blade or at least make it nearly unuseable after a few strikes.
X Zhang
Posted: Thu 25 Dec, 2014 7:27 pm Post subject: |
Tyler Jordan wrote: | I have to wonder if said 'swordbreakers' were more useful in China's bronze age, where one could likely quite trivially bend a bronze blade or at least make it nearly unuseable after a few strikes. |
but it was usually made of brass or steel. And the two materials did not exist in bronze age.
jian3 probably first appeared in the later stage of the Northern Dynasties
Ps: Northern Dynasties, 386~581 AD
X Zhang
Posted: Thu 25 Dec, 2014 7:44 pm Post subject: |
Those are all basically the antiques after Ming dynasty
