James Anderson III
![](images/avatars/20558471824d239b54624e7.png)
Posted: Sat 20 Sep, 2014 3:06 pm Post subject: Multi-purpose cutting stand |
I made a few cutting stands this weekend, and I know a number of people on here do cutting with sharps, and I thought I would share the pictures and general info on them.
Some quick photos of a new style cutting stand I made. Had some materials on hand that have been sitting around, and decided I'd make myself a stand. Made a couple extra, because, well why not?
All 3 are the same. The "lower" part of the stand has a hole in it that can use: (1) a spiked peg for tatami / pool noodles, (2) a flat platform to place milk jugs, water bottles, evil cabbages, etc., or (3) an add-on piece to raise the height of the stand, which also has a hole in top and can use the spiked peg or platform as well.
Basic measurements:
* 35" tall overall
* main post: 27" base + 8" elevation add-on, 4x4 post (3 1/2" x 3 1/2")
* roughly 10" long feet, 2x4 lumber (1 1/2" x 3 1/2")
* 1" holes for spikes / platform
Assembly:
* Two screws per leg.
* Each leg butts against the other for stability.
* Drill holes for pegs (3)
* Cut little platform (6"x6" is what size I did)
* Cut small peg that goes on the bottom of platform and screw together
Photos:
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-xap1/v/t1.0-9/10671448_10204167063193451_9223126529994761647_n.jpg?oh=c2d872756defd297aff0046688c8953c&oe=54CF18CA&__gda__=1422483871_c456c5010027471568a9499a7cf3b00e
Overview. I turned the extension piece on the one in the middle so it's easy to see where it joins.
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-xap1/v/t1.0-9/10686861_10204167063033447_90832834963766457_n.jpg?oh=53e43b9e8606439d72d8974e4abf93d5&oe=54932F3B&__gda__=1422283495_e7300dfe33654beb3ac74a40fe7b88cf
Close-up of the stands.
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-xpa1/v/t1.0-9/1606948_10204167063153450_7950327171287459444_n.jpg?oh=227f7a7ad402033bd2ed5c23add01b8b&oe=548BF82D&__gda__=1422599751_ebd218bdd92a45d9339d38739d5ece27
Overhead view of the peg and the rotated add-on piece.
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-xfp1/v/t1.0-9/10006221_10204167063793466_5459684340595482456_n.jpg?oh=d765548e1b46e47717e26bb357c59fa0&oe=54CD780E&__gda__=1418232683_812d40afce3329c6adf4ac466e193153
The add-on piece showing the peg and hole for the peg.
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-xfp1/v/t1.0-9/10420420_10204167063993471_5680200502794976026_n.jpg?oh=7b0a8bd75184b9cdbc07e92ccda98590&oe=54C7FC3A&__gda__=1418352735_5ebcf03634ec321104b15c670afee2d6
The little platform and the bottom peg piece. This one is a little shorter, I made the other few slightly longer since I had enough leftover dowel rod.
Sable, a chevron between three lions statant Argent
Knight, Order of the Marshal
Shahril Dzulkifli
![](images/avatars/202306156555e486d1ebc67.jpg)
Posted: Tue 23 Sep, 2014 3:31 am Post subject: Multi-purpose cutting stand |
For those with swords, these cutting stands may come in handy.
My question is: How to get one of these, James?
- Marcus Aurelius
James Anderson III
Posted: Wed 24 Sep, 2014 11:33 am Post subject: Re: Multi-purpose cutting stand |
Shahril Dzulkifli wrote: |
My question is: How to get one of these, James? |
Shahril, they are very easy to make. I am not selling them. I made one for myself and a couple for friends. They can even be made with hand tools (if you can get a drill).
The lumber can be found at any nearby lumber or home improvement stores. There are 4x4 deck railings but it is cheaper to get an 8' long post. You can make two stands from one 8' post (or a 6' post if your store has those).
You can also get two stands out of a single 2x4 that is 8 feet long. Cut it in half, then cut both of those into quarters.
The pegs are just 1" dowel rod that I cut into shorter pieces and sanded into a point. The point does not have to be very sharp.
If you try to make one and get stuck, let me know if you have any questions.
