Total length is 19 1/4" ( This is 1/4" longer than what is given by Leo as the total length ? Not a bad thing, just mentioning it for accuracy ).
Blade length: 14 1/4"
Handle length: 4" between the inside " H " guard and pommel bars. ( These handles seem to be often called " i " hilts, but I think it looks a lot more like an " H " when the branches are this wide ).
The whole " H " handle + guard and pommel bars are 5" long, the guard and pommel bars are both 4" wide.
The full tang is 1/4" thick as well as the blade closest to the hilt.
There is some degree of distal taper but it is subtle, but with the triangular blade it does have a lot of profile taper.
The point of balance is 1 1/2" giving the blade some surprising presence, just enough that it makes the blade feel more responsive than if it had a neutral balance at the guard or a negative blade presence with a point of balance behind the guard and in the middle of the hand.
I believe that this slight forward balance is good in helping to make wrist snap cuts that could do some real damage and gives the blade more cutting power than one would assume just looking at the blade profile and type which is optimized for thrusts or stabs.
The steel of the guard bar and pommel bar are at 1/4" at the tang but they taper in thickness toward their ends: This is a lot more work when it comes to fitting the wood slabs that form the handle and that cover the " H " guard and pommel bars.( Not sure what these should be called, so I'm improvising and inventing my own descriptive terminology )
The wood scales are done in 3 pieces with the wood grain logically in line with the length of the handle and at 90° to the handle on the bars and in line with these: If it was made of one piece of wood the wood would be very weak if the grain on the bars ran crosswise.
The diamond section blade has a flat triangular surface on each side for 3" to 3 1/2 inches ( This triangular section seems a little longer on one side, but I'm not concerned about this since historical makers didn't seem to worry too much about perfect symmetry in any case, and Leo always produces weapons which look like someone had a time machine and went into the past to buy them from a period arms merchant ;) :D :cool: )
The boxwood handle is a very nice cream colour and is pinned in place with small brass pins, and I also think that the handle and bar scales are epoxied on which is something I like from a structural assembly point of view even if not historical.
The fit of wood to metal is very good overall, but there are a few small gaps or flaws in fit that the epoxy fills. ( Just mentioning these very small flaws for the sake of an accurate review, but they are very small and one has to look for them with a magnifying glass )
The dagger also comes with a very nice double thickness heavy leather sheath with some nice leather tooling detailing and a nice brass chape at the end.
In handling the " H " type handle works very well for me in hammer grip point forward or in ice pic grip, but I also like the way the pommel bar fits at the base of my hand for a handshake grip.
This type of handle does seem to be extremely secure so one can have a relaxed grip in hammer grip and if one extends the hand in a snap cut it fall naturally into a handshake grip when one firms up ones grip just before one's cut makes contact.
I think in boxing or other martial arts it is said that a relaxed hand is faster than one where one's knuckles are white from having the fist closed as tightly as possible: A punch starts with a relaxed hand and tenses up just before impact.
The " H " hilt also sort of reminds me of late bronze age/early iron age antenna hilted/pommel swords in imagined handling: A wide pommel gives a very secure grip and a very comfortable handshake grip ( My pics below will show what I mean )
Customer service from ordering on the " In Stock " page to delivery was fast and efficient: Shipped a couple of days after ordering and received 10 days later, I also got quick and timely e-mail replies to a few questions I had.
I'm very happy with this dagger, that is a great surprise in how well it feels and handles in the hand contrary to the assumptions one might make thinking that this type of grip would be awkward.
Pic from Tod's web site.
Dagger in scabbard.
Very nice tooling on the leather scabbard.
Close up on chape.
Back side of scabbard showing stitching.
Nice boxwood handle.
Really sharp needle point, but the tip is still thick enough to be robust.
