after moving and setting up my new workshop I finally started to make things again :)
About two weeks ago I finished this commission of a 14th c. bollock dagger after a harbor find from Stade (Germany).
Dimensions:
Blade length 23,5 cm
Overall length 38 cm
Blade max width 6,5 mm
The blade was made by my preferred smithy Timm Esemann out of 17th c. refined steel with differential construction.
The handle is boxwood (like the original) with brass fittings.
The scabbard has a beech core, is covered in red wood died and stamped 1mm calf leather.
The scabbard fittings (the original dagger was found without the scabbard) are made after an english find.
Here is the original:
Here is my reproduction:
Hope you like it.
