I wanted to take a few minutes to share two projects that are currently underway, and looking for a patron. The first is a pattern welded sword that is inspired by very early viking/migration era blades. There is no fuller, and the pattern is heavily influenced by the theme of the serpent. The core is composed of 9 rods, the central rod being a slowly creeping serpent of wrought iron, the patterning achieved by twisting the rod back at froth approximately 90 degrees, then forging flat, and is the same rod on each side. Next there are two bundles of 4 rods, on one side they form circles, or diamonds to symbolize the spots found on the back of snakes. On the opposite side the twisted sections are twisted in a similar proportion, but are offset to form the visual pattern of a snake moving across the ground, weaving back and forth.
I am really happy with the way that it turned out, but have yet to come up with a design for the hilt. If someone is interested in becoming the patron for this sword, I am very open to discussions as to what direction to take the hilting and scabbard making.
