Forum Index > Historical Arms Talk > Board kite/vedge shield projectDIY Project Reply to topic
Elling Polden
PostPosted: Sun 02 Jun, 2013 8:52 am    Post subject: Board kite/vedge shield project         Reply with quote
Hi
I have been tinkering with a method for making shields out of boards without massive amounts of carpentry for some time. More details on this to come. But I have now (mostly) finished the 0.2Beta version of my new vedge/flat topped kite shield!
Due to circumsatnce (what was laying around at home), it is made out of 10 8mm thick pine boards, with a central vedge wider and thicker pine boards (added after 0.1Beta proved to narrow.
Specs:
110cm tall
55cm wide
72cm outer diameter
20cm deep.
ca 4kg weight
The main feature of this sheild is the cuvature and depth. Where a convensional reenactors plywood shield has only a gentle curve, this shield very deep indeed. The goal was to match period depictions, which it now does.
It also enables the use of the vertical arm grip, that is pretty much useless on a flatter shield.
Aditionally it features very low attatchment points for the shoulder straps (inspired by the Lewis chessmen) that allows both for more or less free use of the shield while on the straps, and carrying the shield with the shield at eye level witth both hands free.
Overall, the results are quite interesting, and I am looking forward to field testing the shield during the summer season.
 Attachment: 220.82 KB
 Attachment: 222.78 KB
 Attachment: 179.32 KB
 Attachment: 212.51 KB
 Attachment: 221.14 KB
Thomas R.
Reading list: 17 books
PostPosted: Sun 02 Jun, 2013 11:54 am    Post subject:         Reply with quote
Hi Elling,
great work. It does indeed match period illuminations now. You got the curvature very well! I would like to see the strap-setup and since you mentioned it, maybe add a picture of your arm, while using the vertical hold?
And how did you join the boards? You hinted at a fast process? I am really curious about that.
All the best,
Thomas
Sam Gordon Campbell
PostPosted: Sun 02 Jun, 2013 8:54 pm    Post subject:         Reply with quote
Those curves...
Host of Crash Course HEMA.
Mart Shearer
PostPosted: Mon 03 Jun, 2013 5:24 am    Post subject:         Reply with quote
Barrel making 101...
Elling Polden
PostPosted: Wed 05 Jun, 2013 8:36 am    Post subject:         Reply with quote
Since Thomas asked about how the shield was made and I wanted to develop the process, I decided to make another shield:
This is the story of how it came about;[url]
http://s40.photobucket.com/user/Ellingpolden/story/7053[/url]
or, in short, the trick is to glue the pieces to a cloth backing, prop it to desired shape, and close the gaps with glue/trowel.
Cheating, I know. But an effective alternative to bending plywood. Which is also cheating.
Jeremy V. Krause
PostPosted: Wed 05 Jun, 2013 8:41 am    Post subject:         Reply with quote
Your shield is great and WOW! Norway is beautiful!
Tanner Sheltry
PostPosted: Wed 05 Jun, 2013 4:24 pm    Post subject:         Reply with quote
Could you post pics of the strapping system? Also on that third pic wouldn't that put your leg out as an obvious target?
the more skill a man has with his weapon the more gentle and courteous should he behave, for in truth this is rightly the honour of a brave Gentleman, and so much more is he to be esteemed: he must not be a bragger, or lier, and without truth in his word, because there is nothing more to be required of a man than to know himself" - Vincentio Saviolo
Pat M
PostPosted: Thu 06 Jun, 2013 12:06 am    Post subject:         Reply with quote
that is a beautiful shield good sir! I too, am dabbling a bit with working on a more period authentic kite shield. It's interesting, but most people around my parts believe kites are good for reenactment only for "wars" and on horseback, even though history states otherwise. I'm looking forward to further watching your progress with this, as it's always nice to see others working on a similar experiment.
"Be open with your thoughts, Be witty with your humor, Be kind with your words, Be sensible in your acts." - Lord Dane
Never theorize before you have data. Invariably, you end up twisting facts to suit theories, instead of theories to suit facts.
~Officium-Honestas-Sacrificium~
Thomas R.
PostPosted: Thu 06 Jun, 2013 1:53 pm    Post subject:         Reply with quote
Ha, that's an ingenious way to build a shield, Elling.
Did you already put it to the test? Does this glue-joint take a beating well?
Thomas
Elling Polden
PostPosted: Thu 06 Jun, 2013 2:27 pm    Post subject:         Reply with quote
Tanner; Here is what the strapping currently looks like:
Here are some examples on the various options.
http://s40.photobucket.com/user/Ellingpolden/story/7071
Thomas; I have tested the 0.1 beta version, which held up OK. Unfortunately I have been working away from practice opportunities for the last months, so propper testing will have to be done during summer. So far the impression is that they can take some beating. I have been experimenting with diferent kinds of glue/trowel, but have ending up trying out the kind used for car/boat repair. Results are good so far, but true durability testing will take some time.
