I love the curvaceous forms of these bows, they are always a pleasure to make and are beautiful to look at and hold and lend themselves so well to applied decoration.
The top plate (usually) of bone serves as a low friction surface and the cut outs just in front of the nut also serve this purpose. There is no groove, again to minimise friction and so the bolt is supported and guided at the front using a small bone insert. The nut is usually antler (though not in this case) and has a lower moment of inertia than steel or bronze. The nut is lashed into the socket and due to the method of manufacture this area of the bow is weakened drastically, so it must be strengthened again and this is done using the scalloped horn plates that also form the sides of the nut recess.
Basically all the lovely bits that look like whimsy are in fact required for the sucessfull operation of the bow and are designed to keep it together or make it shoot faster.
These bows are the classic embodiment of Ferdinand Porches maim of 'form follows function' and I love that.
I hope you like it. This bow, complete with goats foot and bolts is for sale at £1350
Regards
