Forum Index > Makers and Manufacturers Talk > Custom Viking Scabbard Reply to topic
Sonny Suttles
PostPosted: Thu 04 Aug, 2011 5:33 am    Post subject: Custom Viking Scabbard         Reply with quote
On this one we were provided the scabbard fittings. The objective was to blend the design of the fittings with the scabbard leather to create a visual flow.
As always comments are welcome.
Sonny
www.valiant-armoury.com
www.customswordshoppe.com
Tim Lison
(11 total ▮ 100% positive)
PostPosted: Thu 04 Aug, 2011 7:55 am    Post subject:         Reply with quote
Looks good! Will it get a belt or a bladric?
Tim Seaton
PostPosted: Thu 04 Aug, 2011 9:09 am    Post subject: lol         Reply with quote
looks great sonny , does it come in silver plate ? the leather work is outstanding very clean lines
CHEERS
Robert Muse
(2 total ▮ 100% positive)
PostPosted: Thu 04 Aug, 2011 9:48 am    Post subject: Scabbard         Reply with quote
Hello All,
Sonny has done his usual great work on this one!
Recognize the sword Tim? I had originally wanted silver fittings, but could not locate a slide in silver. After finding other custom scabbards that matched steel sword fitting with brass scabbard lockets and chapes I went with the brass set.
It will have a thin belt when I get the fittings from Germany.
All the best
Robert
Matthew Nabity
PostPosted: Tue 09 Aug, 2011 5:26 am    Post subject:         Reply with quote
gorgeous! function and beauty combined.
Could you recommend any sources for scabbard making?
Fortitudine vincimus
Bryce Felperin
PostPosted: Tue 09 Aug, 2011 10:10 am    Post subject:         Reply with quote
Excellent scabbard. I have to ask though I assume the answer is yes...did you make the scabbard metal fittings? Very nice work if you did!
Thanks,
Bryce
Mark Routledge
PostPosted: Tue 09 Aug, 2011 12:36 pm    Post subject:         Reply with quote
A very pleasing bit of work that. Fine attention to detail and very well executed.
www.wessexwildcraft.com
David Huggins
PostPosted: Fri 12 Aug, 2011 11:21 pm    Post subject: scabbard         Reply with quote
The frog, chape and slider are available in cast bronze and silver from a number of Polish traders.
regards
Dave
David Huggins
PostPosted: Sat 13 Aug, 2011 2:12 am    Post subject:         Reply with quote
Also available here from Rob Taylor http://www.jelldragon.com/scabbards.htm
best
Dave
