Jess Rozek
Posted: Mon 18 Jul, 2011 4:41 pm Post subject: Gambeson elbows |
So, I recently finished a gambeson and it's great. My only problem is the sleeves. The bunching in the elbow is so tight I can barely hold an ochs position. Sewers of gambesons, enlighten me: how do I gusset or cut holes in the sleeves without ruining the whole thing?
Scott Hrouda
Posted: Mon 18 Jul, 2011 5:13 pm Post subject: |
Jess, is your sleeve seam along the inside of your arm or the outside?
Ian S LaSpina
Posted: Mon 18 Jul, 2011 5:46 pm Post subject: |
I've seen a lot of reproduction garments address this by constructing the sleeve to be pre-flexed at the elbow. Here's a photo of my gambeson (revival clothing's linen gambeson) elbow in it's natural state. The elbow is naturally in a pre-bent position. It doesn't bunch up when bringing a sword up in to ochs.
Attachment: 180.76 KB
My Pinterest
Jess Rozek
Posted: Mon 18 Jul, 2011 7:38 pm Post subject: |
Scott, the seam is underneath my arm.
Ian, unfortunately I'm not that good of a seamstress and I have no idea how to pre-flex the elbow especially now that it's done
My main worry is that if I flip the whole thing inside out to cut away at the elbow that I'm gonna cut the wrong side of the elbow...
Christopher Treichel
Posted: Mon 18 Jul, 2011 8:19 pm Post subject: |
go to your local fabric store and get a little packet of blue and white chalk.... draw on fabric while wearing it... so you don't cut in the wrong way... remember to leave seam allowance...
Mikael Ranelius
Posted: Tue 19 Jul, 2011 12:40 am Post subject: |
My new gambeson, which I'm currently working on, will be cut at the elbow similar to the Charles de Blois-garment which has the arm pre-bent. Also, there should be little or no padding at the bend of the arm wether or not the arm is cut in one piece.
Scott Hrouda
Posted: Tue 19 Jul, 2011 6:18 am Post subject: |
Ian's picture is worth a thousand words. Mikael and Christopher offered good advice, especially this quote:
Mikael wrote: | ...there should be little or no padding at the bend of the arm... |
It took making two gambesons for me to figure this out.
With the seam on the bottom of the arm, you should be able to open it up and insert a piece to give you the "pre-bent" appearance.
