I was looking through the gallery today when I found this image.
http://www.myArmoury.com/albums/photo/1987.html
I have the windlass 16th century german mace that looks like this one. I would like to re-do the grip so that mine looks more like this one.
Any ideas on how to accomplish this?
Assuming that the surface is leather, I would say that that is simply a spiral-carved wooden grip covered with thin leather.
that might not be leather.... might be horn or just wood.
An easy way to get a similar look would be to wrap a thin rope around the handle, to get the spiral look, then add a thin layer of leather covered with glue. Wrap the handle with a string going in the same direction of the rope to conform the leather to the rope. Instead of carving out a spiral in the handle this is a relatively easy way to get the desired effect.
| Paul Greathouse wrote: |
| An easy way to get a similar look would be to wrap a thin rope around the handle, to get the spiral look, then add a thin layer of leather covered with glue. Wrap the handle with a string going in the same direction of the rope to conform the leather to the rope. Instead of carving out a spiral in the handle this is a relatively easy way to get the desired effect. |
Thanks Paul,
I like the idea, but I am worried that doing it that way would make the grip overly thick... still, I'll have to try it out and let you know. =)
