I'm proud to present you my latest project, a XVIII single hander!!
Stats:
overall: 95cm (37.4")
blade: 77cm (30.3")
weight: 1080g (2.4lb)
width at guard: 5cm (2")
width guard: 17cm (6.7")
PoB: 12cm (4.7")
CoP: 50cm (19.7")
Steel is 5160, heat treated to 53-54RC. This blade was originally intended as a blunt practice weapon, therefor the lower hardness and the steel. Usually my sharp blades are 56Si7 hardened to 60RC but after heat treat I decided to sharpen it up as I had found a cheap but serviceable training sword elsewhere. So this sword does not have the normal edge retention of my other sharp blades but certainly is good enough for everything reasonable, just don't chop nails, etc.
This blade has a convex distal taper, making for a very rigid and stout blade that thrusts very well. At the base it's 6mm thick and tapers very little on the first third. Then it tapers aggressivly to 3mm at the CoP and then slowly to 2mm before the tip.
The guard is a heavily reground Windlass classical medieval, the pommel I made myself. The guard is wedged, back peened and epoxied in place, the pommel wedged, hot peened and also back peened. The tang is full 6mm thick, has round shoulders and the edges of the tang are rounded too, just like on ATrim tangs. The grip is thick leather wrapped with cord and thin leather.
The way this sword handles is quite distinctive. It has definite blade presence and the stout blade really packs a punch. The PoB is also rather forward compared to other XVIII (Albion Poitiers or Kingmaker). This isn't a light, floating sword but a brutal tool of war. It's however still quite fast and easy enough to manouver for sword and buckler play.
While it cuts light targets very well, it really shines when pitted against hard targets like branches, etc. I was shocked how easily it severd branches of impressive thickness. I wished I had tatami mats and the like but my current funds don't allow that. I dare to say that it would not have problems even against double mats.
Note that the grip is not wrapped yet in two photos and shows the cord wrap beneath the leather.
Here's the cutting: http://forum.sword-buyers-guide.com/viewtopic...901#p47901
Sorry for my feet, didn't mean to include them :?
Comments and critics welcome!!
Btw, this is the first time I post a project here so if I'm doing anything wrong, please correct me!!
