Forum Index > Makers and Manufacturers Talk > Rondel and Mace, 15thC by WhiteWellArms, White Rose Reply to topic
J. Dawes
PostPosted: Mon 24 Jan, 2011 4:30 pm    Post subject: Rondel and Mace, 15thC by WhiteWellArms, White Rose         Reply with quote
Hello All,
Please find below some of my recent work.
They have both been a pleasure to manufacture, being based around my personally favourite period, and also the same period that I re-enact.
THE RONDEL
The Blade is of Hardened and Tempered EN45 spring steel. Made sharp with a single edged slightly bellied shape, with the back edge false sharpened to approximatly a third of the way up from the tip. Stamped with my makers stamp and mirror polished.
The hilt of this high end Rondel is of turned Ash, bound with 3 strands of fine wire spun together clockwise and a second set the bound anti-clockwise, then wrapped side by side and locked into place with steel rings top and bottom. The top ring has 8 flush pins locking both the wire and the ring together and the bottom ring the same process but with 4 pins. The rondels are of inhouse made bronze and cusped and pierced.
Finally the whole of the dagger has then been peined together and cleaned back flush and mirror polished finished with a jeweller polish leaving a spectacular mirror finish.
THE MACE
Conctructed from steel stock. the shaft is mildly tapered to the head and hexagonally ground.
The flanges are all finely copied from an original German mace.
They are then attached using a solid weld running between each of the flanges then ground back flush.
Before this processs I manufactured a brass nut from a piece of square brass bar, then slid it down the shaft and butted up to the flanges and filed slots to meet each flange. Then pinned through each side of the brass nut through to the flange and interfierence fitted piened then cleaned back flush.
The same process was used to attach the crown on the top of the Mace, this was also hand ground from the same piece of brass square bar and carefully filed to the desired shape.
The hilt of the Mace has been made using Ash carved into a tapering haxagonal shape matching the shaft. Then a sleeve of black died leather was sewn and brass pinned to the grip. Then capped with a large steel hexagonal hand guard and a flush cap of hexagonal shape cappin the back also I manufactured a brass cap to finish the hilt was added. To fix this all into place it was then piened closed. Finally a lanyward was attached to the Mace with a 2 inch tap and dyed hand made eyelet being screwed in and locktighted, flemmish bound leather was then made to allow security whilst being used.
All the Mace was then carefully polished to a fine finish.
I will take stats of the items and post them up shortly.
These are for sale and would accept;
110 GBP for the Rondel
180 GBP for the Mace
I would sell them as a pair for 225GBP
Thankyou for taking the time to read this Post.
Many Kind regards
Josef
WhiteWellArms
 Attachment: 17.88 KB
 Attachment: 36.22 KB
 Attachment: 21.83 KB
 Attachment: 28.89 KB
Robert Hinds
PostPosted: Mon 24 Jan, 2011 4:46 pm    Post subject:         Reply with quote
That dagger is beautiful. Very nice work. Happy
"Young knight, learn to love God and revere women; thus your honor will grow. Practice knighthood and learn the Art that dignifies you, and brings you honor in wars." -Johannes Liechtenauer
"...And he that hath no sword, let him sell his garment, and buy one..." Luke 22:36
J. Dawes
PostPosted: Mon 24 Jan, 2011 5:06 pm    Post subject:         Reply with quote
Cheers Robert! Happy
Likes: 29 pages
Reading list: 327 books
Spotlight topics: 32
(12 total ▮ 100% positive)
PostPosted: Mon 24 Jan, 2011 7:01 pm    Post subject:         Reply with quote
I'm extremely tempted to purchase the pair!
J. Dawes
PostPosted: Tue 25 Jan, 2011 7:35 am    Post subject:         Reply with quote
These are one off prices for the Rondel and Mace
I usually work to commision, but I made these in my own time through sheer enjoyment of making them.
A usual price for a mace would be around 210GBP and the rondel would be around 150GBP so who ever buys these are saving money, buying them as a pair your saving a huge 135GBP
They are now wrappen in cotton and lightly oiled in the Armoury awaiting a new home.
thank you for your interest.
many kind regards
Josef
WhiteWellArms
Aaron Morris
PostPosted: Tue 25 Jan, 2011 9:07 am    Post subject:         Reply with quote
those are both good lookin what type of steel did you make the mace out of , just curious
J. Dawes
PostPosted: Tue 25 Jan, 2011 9:11 am    Post subject:         Reply with quote
The Mace was made from Mild Steel.
Thanks for your comment Aaron!
Josef
WhiteWellArms
Audun Løkse
PostPosted: Wed 26 Jan, 2011 3:07 pm    Post subject:         Reply with quote
Somebody wants these to go to Norway.
PM sent for the pair.
Terry Crain
PostPosted: Thu 07 Apr, 2011 12:38 pm    Post subject: mace and rondel         Reply with quote
Hi Josef,
Please check your pm's. Thanks much.
Best regards, Terry
Terry Crain
A/K/A
Donal Grant
Honor, not Honors!
