Forum Index > Off-topic Talk > Wanted: Small chainmail rings Reply to topic
Eric Hejdström
PostPosted: Thu 07 Oct, 2010 9:54 am    Post subject: Wanted: Small chainmail rings         Reply with quote
I'm looking for really small rriveted rings for a chainmail hood ca 1480. The original is with flat rings and most likely round rivets. I could be wedge rivets too but that case they're very well done. The weave is very tight and there's virtually no gap between the interlocking rings in the peice.
Anyone got any idea where to get some?
PostPosted: Thu 07 Oct, 2010 10:03 am    Post subject:         Reply with quote
Eric,
I've moved this from Marketplace into the Off-Topic Talk forum. You're seeking advice, which is not what the Marketplace is for. By moving it here, you can actually get the advice you're looking for.
Blaz Berlec
PostPosted: Thu 07 Oct, 2010 10:43 am    Post subject:         Reply with quote
Cap-a-pie has 6mm flat rings, with round or wedge rivets:
http://www.capapie.co.uk/materials.html
János Sibinger
PostPosted: Thu 07 Oct, 2010 9:10 pm    Post subject:         Reply with quote
Greetings!
At a pinch, you still could make your own rings. The process requires relatively few tools, and most of the work could be done at home. Yes, it is time consuming, and sometimes it might be a bit fustrating, but still a solution to get the rings that you want to. I hope I was able to help.
Good luck!
John
Eric Hejdström
PostPosted: Fri 08 Oct, 2010 12:29 am    Post subject:         Reply with quote
I've been considering making my own rings, but I really don't have time. A friend of min also wants to make a two, finger gauntlet with maille. Wich requires even smaller ones.
