Forum Index > Makers and Manufacturers Talk > Nijmegen Sax Reproduction. Reply to topic
Ben Potter
PostPosted: Sat 11 Sep, 2010 10:15 am    Post subject: Nijmegen Sax Reproduction.         Reply with quote
I am currently making a (rough) reproduction of the Nijmegen sax.
I will be posting some pictures of the process on my blog:
http://benpotterbladesmith.blogspot.com/
Enjoy.
Ben Potter Bladesmith
For any other man's,
Nor that I will be ashamed
Of my work torn hands-
Knowing it would be steep,
And the consequences reap.
Paul Hansen
Likes: 5 pages
PostPosted: Sun 12 Sep, 2010 10:47 am    Post subject:         Reply with quote
Always nice to see a Dutch weapon reproduced. Happy
However, I fear that the hilt in your sketch seems to be a bit on the short side. Also, the original seems to have a "scandi-grind" edge profile, rather than the flat or convex profile usual for saxes.
I've attached a top-view of the same sax for comparison. Length is 59cm. And a picture where the grind can be seen. More pictures can be found in Jeroen's "information about saxes" file.
 Attachment: 20.86 KB
 Attachment: 242.46 KB
Dustin R. Reagan
PostPosted: Sun 12 Sep, 2010 11:18 am    Post subject:         Reply with quote
The transition point where the grind changes is a scraped or engraved small fuller. It has a matching one at the top of the blade which meets the bottom one in a point. This is a very typical feature of narrow seax. I'm actually not 100% sure that the grind does change...it may be an illusion caused by the fuller? I'm sure someone who has seen this seax in person could say for sure?
Thanks for this much clearer picture! I'm going to have to make a narrow seax like this myself someday. I can't recall...narrow seax are not typically pattern-welded, correct? Does anyone know what some of the typical construction configurations are? Piled wrought back, steeled edge, steel sandwich, etc?
Thanks,
Dustin
Ben Potter
PostPosted: Mon 13 Sep, 2010 8:43 am    Post subject:         Reply with quote
Thanks for the input.
Peter Johnsson
PostPosted: Mon 13 Sep, 2010 9:53 am    Post subject:         Reply with quote
It is exceedingly rare to see a sax with a defined ground in edge, as in "scandi grind" (I cannot remember seeing one single example). This type of grind is rare on most types of knives in the european tradition before the industrial revolution. It is one of the most commonly made mistakes we see on modern replicas. I guess this is because it is the expected norm on most modern knives.
Cross section on seaxes is almost always triangular with an apple seed sharpening. This is true for narrow seaxes, light broad saxes, broad saxes and lag saxes. Sometimes the apple seed edge is so generous and sturdy that the edge faces are may look like almost parallel, but there is always some taper in the section.
Various types of groves and fullers may decorate these blades. Some set ups are more common with certain types.
Narrow saxes (like the Nijmegen sax in this thread) are pretty slim in shape and proportions. They are more big knives than short swords. Think large japanese tanto. Or perhaps bayonet? They commonly have scraped groves, but only rarely fullers between there groves. You do find decorative engravings on a number of them that originally were inlayed with silver.
Thickness of the back is some 5 millimeters or so, at a width of some 30 millimeters at base. Dimensions would vary according to size. A slightly bigger blade would probably be a tiny bit thicker, while a slimmer example would be thinner.
Point tend to be a not-quite-centered spear point, and the back sometimes has a very slight hint of a clip point form. It can also be a slightly of set spear point made up of two smooth curves. It tends to be rather drawn out. Generally not so much belly in the point.
Dustin R. Reagan
PostPosted: Mon 13 Sep, 2010 10:53 am    Post subject:         Reply with quote
Thanks for all this information on blade geometry! Can you say anything about blade construction?
Paul Hansen
Likes: 5 pages
PostPosted: Mon 13 Sep, 2010 12:29 pm    Post subject:         Reply with quote
Yes, but if you look at this attached picture of the tip of the sax, it does look like it's a wide fuller. Indeed rather uncharacteristic...
I´ve seen this sax myself, but I can´t remember this feature...
If it is indeed a wide fuller, then the cross-section would be like a Scandinavian blade, I guess. See the attached drawing.
 Attachment: 47.15 KB
 Attachment: 109.82 KB
Dustin R. Reagan
PostPosted: Mon 13 Sep, 2010 12:32 pm    Post subject:         Reply with quote
I don't see any signs of a fuller...I do see the two narrow incised grooves i (and Peter) mentioned, though.
Paul Hansen
Likes: 5 pages
PostPosted: Mon 13 Sep, 2010 1:06 pm    Post subject:         Reply with quote
Could be, it´s quite hard to see. I think the difference in colour between the edge and the "fuller" might indicate a change in profile (i.e. from convex to fuller), but I'm not sure either.
Next time I visit that museum I´ll try to get a better look at it...
Ben Potter
PostPosted: Tue 14 Sep, 2010 8:50 am    Post subject:         Reply with quote
Thanks for all the help.
I do need to say that the length of the piece was set by the customer at around 18" so it will be bit shorter than the original. Also, the sketch is a VERY rough sketch the blade profile will be different and the dimensions are only nominal. After HT the piece is slightly over 18" with a 5 1/2" tang. it is 3/16" thick at the base of the blade with a Appleseed V grind.
My camera battery died yesterday which is why I haven't posted pictures yet.
Ben Potter
PostPosted: Wed 15 Sep, 2010 11:31 pm    Post subject:         Reply with quote
Here is the blade so far. It is polished out to 800gt and heat treated.
I'll be polishing again tomorrow so I may not post for a bit.
Matt Corbin
PostPosted: Thu 16 Sep, 2010 6:43 am    Post subject:         Reply with quote
Oh that's looking REALLY nice. I can't wait to see how this turns out.
- R. Ewart Oakeshott
Ben Potter
PostPosted: Wed 22 Sep, 2010 1:14 pm    Post subject:         Reply with quote
Here is the last couple of days progress:
I have a little more to do on the blade and then on to the hilt.
PostPosted: Wed 22 Sep, 2010 1:32 pm    Post subject:         Reply with quote
Oh, that looks promissing. Big Grin Cool
Jeroen Zuiderwijk
PostPosted: Thu 23 Sep, 2010 3:02 am    Post subject:         Reply with quote
http://3.bp.blogspot.com/_aepG1XqNfAw/TJpp_w_...sseax2.jpg
Awesome! Excellent work on the engravings too!
Jeroen Zuiderwijk
- Barbarian metalworking
- Museum photos
Ben Potter
PostPosted: Thu 23 Sep, 2010 7:54 pm    Post subject:         Reply with quote
Here is the guards and pommel inlet:
Matthew Stagmer
PostPosted: Fri 24 Sep, 2010 4:41 am    Post subject:         Reply with quote
Nice. I am loving the engraving on the blade.
Matthew Stagmer
Youtube.com/ThatWorks
Ben Potter
PostPosted: Fri 24 Sep, 2010 7:51 pm    Post subject:         Reply with quote
Shaped and polished the hilt fittings today:
Ben Potter
PostPosted: Mon 27 Sep, 2010 8:28 pm    Post subject:         Reply with quote
Here is the day's progress:
Ben Potter
PostPosted: Tue 28 Sep, 2010 6:09 pm    Post subject:         Reply with quote
Here is the hilt as it sits tonight:
Lord willing I will bed the hilt and peen the tang tomorrow and have this one finished.
