The open ring pommel or Irish sword as we also call it. My question is what type of blade has it ?? A XIX only or can it have a XVIIIa blade, I ask because this is a sword project i would like to work on and thinking of using the Hanwei /Tinker bastard with fuller for this project this blade is a XVIIIa I think. Any help would be great ,thanks.
Search and ye shall find info: :)
http://www.myArmoury.com/talk/viewtopic.php?t=5494
http://www.myArmoury.com/talk/viewtopic.php?t=5844
http://www.myArmoury.com/talk/viewtopic.php?t=18705
There are more threads but some are old and the pics they linked to are long since gone.
Seems a Type XIX blade was fairly common. There is one example with a diamond section as well. Don't know if I've seen any fullered XVIIIas.
Thank's Chad this info you gave me did help ,where XIX were most common any blade could be used ,as Owen Fentimen said " Irish swords are unique by there guards and pommels not there blades"also from what I read If popularity is an indicator of martial effectiveness, Type XVIII must have proven itself very effective indeed. According to Oakeshott, Type XVIII and its subtypes were "the most widely used swords between c. 1410 and 1510 all over Europe". So as it was around this time that Irish swords were assembled ( i use the word assembled because as far as i know they did not forge there own blades) in Ireland.So I will use the XVIIIa blade with fuller to assemble my own,i have the pommel, now I need only to get or make an "S" guard if there is a sword smith near Chicago that could help me that would be great.
If you're comfortable with that extensive justification, then go for it. :)
Have you thought about the unfullered bastard sword blade? A number of repros use a diamond section blade of Type XVIII form. And there is one surviving example of hand and a half proportions that appears to have a diamond section blade with no fuller. Using the unfullered blade would take you from a justification and a maybe-plausible situation to a configuration we know existed historically.
Think I will go with the unfullered bastard blade XVIIIa I'm going to go to KOA next week and look at both blades side by side first.When i am finished I will post some pics here.
My Irish bastard still a work in progress no work of art LOL but its all mine.
Attachment: 62.96 KB
Attachment: 55.19 KB
Attachment: 64.92 KB
That is coming along very nicely. :) Is the grip wire wrapped?
Congrats James on a fine looking sword, be sure to keep us updated on any future work
I like that a whole lot!
Everything looks nicely proportioned and belongs together which seems to be a feat even the mid-range production sword companies don't always get right (in my amateur opinion.) Looking forward to seeing it after the final touches have been made.
Thanks guys I like it so far I have a little more work to go on the guard and have to leather wrap it the grip ,josh that is cord on the grip which will be covered with leather next , going to go with black leather for this one to keep with a dark looking hilt over all. I will have more photos up later today .
Here is the new grip but the guard is not finished yet just a few more final touches to do on it.
Here are the specs : Blade Tinker/Hanwei bastard XVIIIa , pommel from Albion moat sale ,guard is stock which forged into a slight "s" and blued the guard and pommel and visible tang, hot penned.
Over all 41 1/2".
Width of blade 1 1/2".
Blade 33''.
Guard width 8 1/2''
Grip 5 3/4".
Hilt overall 8".
Weight 2 lb
P.O.B. 6'' from guard.
C.O.P. 23'' from guard
Attachment: 62.12 KB
Grip
Attachment: 48.77 KB
new grip
Attachment: 58.37 KB
new grip
Attachment: 62.14 KB
new grip
Attachment: 62.8 KB
Attachment: 49.9 KB
Over all 41 1/2".
Blade 33''.
Guard width 8 1/2''
Grip 5 3/4".
Hilt overall 8".
Weight 2 lb
Grip
new grip
new grip
new grip
Last edited by James Cunniffe on Mon 19 Jul, 2010 6:46 pm; edited 3 times in total
Nice Job, James. I am attaching a picture of a ring pommel sword in the Ulster Museum, Belfast. Blade seems to Oakeshott XVIII - fullered (?). Looks quite similar to your project. I wish I had more information on this particular sword; I couldn't find more information on the web. Slán.
Attachment: 40.62 KB
Daniel
Thank you very much for sharing the photo of the Irish sword from the Ulster museum I do appreciate it a lot. I feel that I am on the right path with my project now,thanks again.
Daniel Patrick O'Brien wrote: |
Nice Job, James. I am attaching a picture of a ring pommel sword in the Ulster Museum, Belfast. Blade seems to Oakeshott XVIII - fullered (?). Looks quite similar to your project. I wish I had more information on this particular sword; I couldn't find more information on the web. Slán. |
Do you have any more detailed pictures of that sword?
Has anyone found any more info on this sword?
Hello,
What information do you want on that sword?
I was there about a year ago to study some Viking era swords... I did get sidetracked a few times with other pieces, including that sword, I examined it for a bit, and handled it briefly.
I didn't take particularly detailed notes on it as I was not there to study that type. Also, I legally cannot post photos of the sword, so the best I can do is describe my impressions of it. I will write all I can recollect.
The sword is in a very pristine condition, it was found by a farmer in a field. The blade was most likely not broken until the farmer hit it with his equipment. It is unfortunate, however it would probably still be siting in the ground had he not hit it.
The blade is very lightly hollow-ground, if I recall. There are multiple nicks along the blade consistent with a well used sword.
Near either end of the tang there are grip remnants. At the top (near the pommel) there is remaining wire, and wood. On the bottom (near the blade) there is a bit of wood and some wire. The grip would have been quite thin originally. On the cross there are remnants of what appeared to be a chappe. The guard is formed in an S-shape, similar to this one by A&A. However, the guard does not have the beveled edges seen on that sword guard. The blade was an Oakeshott XVIIIb.
Cheers!
Cheers!
Quote: |
Belfast. Blade seems to Oakeshott XVIII - fullered (?). |
It is not fullered, it is of diamond cross section and is lightly hollow-ground.
Hadrian Coffin wrote: | ||
It is not fullered, it is of diamond cross section and is lightly hollow-ground. |
Wow Hadrian, I really appreciate your response, I never thought someone who actually handled the sword would respond. Your info was extremely helpful to me. I had thought that the only evidence for diamond section swords were in artwork but this proves it through archeology. Do you know the year it was found and if they have a name for the find? What about an estimate of the length overall and of the blade and guard? Are there any sketch's that you know of?
And since you were there what about the ring hilt to the left could I be so fortunate that you have some info on that one?
Thanks
Hello,
It was a stray find, by a farmer. I do not recall the year. My apologies. I did not measure the sword, so it is pure estimation based on what I remember... I would hazard somewhere around 120cm overall, with a blade around 92-95cm.
Yes, I did handle the other one to the left in that photo, very briefly. I do have several photos (again I apologize for not being able to post them), and a few recollections. I do not recall though where or when it was found.
The cross was S shaped and was quite thin near the ends, whereas the middle of the guard is fairly thick. The guard has very long langets, I'd hazard nearly 9cm! The blade is in quite poor condition. The tip is gone. The blade has 5 thin fullers, the outer most are only about 13-15 cm long. The inner three are longer... If I recall around 25 cm (the blade is quite pitted, and it is difficult to tell in my photos where they end, so this is a guess based purely on what I remember). The blade has a small latten cross inlaid on one side of the blade. There are no grip remnants remaining, the tang was quite narrow. The blade width is approximately 3.5-4.0 cm. The overall length originally is somewhat hard to guess as the blade is missing the end. Based on other swords of similar type, and the swords proportions I'd say it would be around 95-100cm.
I am sorry I cannot be of more help with this one.
Cheers!
Cheers!
Hadrian it is great that you got a chance to handle this sword to say the least I am very jealous .I just came back from Ireland after being there for the past 3 months I did not get a chance to get to Belfast to view this sword as I did want to. I did email them for more info but got no reply so may be you can tell me from my photos is my sword a good likeness of the Belfast sword the S guard I'm most curious about.Thanks
Page 1 of 2
