Forum Index > Makers and Manufacturers Talk > Yushman Project Reply to topic
This is a standard topic Go to page 1, 2, 3 ... 24, 25, 26  Next
Boris Bedrosov
PostPosted: Thu 07 Jan, 2010 4:00 pm    Post subject: Yushman Project         Reply with quote
Reconstructing 15. C heavy Ottoman Infantryman, I made this armour
[img]
almost two and a half years ago.
Being not very saticfied of it, last year I decided to make another suit ot Ottoman armour, main item in which is the combined plate-and-mail cuirass, called "yushman".
After the initial plannig, this
http://media.snimka.bg/5280/016816066-big.jpg
is what I intend to be my future armour.
This raw sketch
[img]
shows how the plates are combined in rows (the center-back row is in the middle of the sketch).
The cuirass itself is not a replica of any particular one, but rather it is combination of elements and ideas, taken from authentic 14. - 15. C Ottoman and Islamic armours
So, in the process of my work I will show you the progress of my work and the construction methods in "real time".
Enjoy!!!!!
[/img]
Tokugawa Ieyasu
Find my works on Facebook:
Boris Bedrosov's Armoury
PostPosted: Thu 07 Jan, 2010 4:38 pm    Post subject:         Reply with quote
Interesting choice, one rarely sees heavy ottoman infantry kit. I like the breastplate.
Maurizio D'Angelo
PostPosted: Thu 07 Jan, 2010 5:13 pm    Post subject:         Reply with quote
Boris,
I found only a helmet Ottoman - XV century - Historical Museum Athens.
Not sure about the shoes and the sword. Perhaps only the Byzantines wore a shoulder belt for the scabbard.
Please correct if I'm wrong.
I can not wait to see something more. Happy
Ciao
Maurizio
 Attachment: 89.02 KB
Maurizio D'Angelo
PostPosted: Thu 07 Jan, 2010 5:46 pm    Post subject:         Reply with quote
here some sword of the fifteenth and sixteenth century
 Attachment: 56.05 KB
 Attachment: 16.18 KB
Last edited by Maurizio D'Angelo on Fri 08 Jan, 2010 12:49 pm; edited 1 time in total
Romulus Stoica
PostPosted: Fri 08 Jan, 2010 7:48 am    Post subject:         Reply with quote
I will watch this topic very closely since I am making something similar. A Kolontar type armor Happy . It's an earlyer version of a maille and plates armor from XIV-XV century.
 Attachment: 217.55 KB
Boris Bedrosov
PostPosted: Sat 09 Jan, 2010 5:58 am    Post subject:         Reply with quote
Good choice and work so far!
I like the kolontar too, but it was used mainly by the Russians and such armour is not appropriate for Ottoman Infantryman.
Is your mail butted or riveted?
Because I will use riveted on.
Tokugawa Ieyasu
Romulus Stoica
PostPosted: Sat 09 Jan, 2010 9:03 am    Post subject:         Reply with quote
For this project the maille is butted. I intend to make a bechter armor (polish/hungarian form of yushman) later and I will use riveted maille then. The kolontar is intended for an irregular Transylvanian infantry kit.
Tibor Szebenyi
PostPosted: Mon 11 Jan, 2010 11:58 am    Post subject:         Reply with quote
I am happy to see mail-and-plate armours, Boris! Yours is good. I also want to improve mine, like your sketch. Here is it:
http://nomadok.gportal.hu/gindex.php?pg=27550495
I made it with riveted links between the plates.
Romulus Stoica
PostPosted: Thu 13 May, 2010 10:52 pm    Post subject:         Reply with quote
Here is an update to my project, a kolontar type vest:
Kolontar face:
The full kolontar layout:
Boris Bedrosov
PostPosted: Tue 18 May, 2010 5:30 am    Post subject:         Reply with quote
Dear friends!
Around the end of January I moved to a new flat and last months I worked quite hard in order to equip my new workshop. That's I was severely restrained to do any significant progress on the project.
Now, my new workshop is ready, so I'm able to continue with my work
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Tue 18 May, 2010 5:35 am    Post subject:         Reply with quote
As a new begging, these
are the paper patterns for the Yushman.
As you see, there is a little difference between them and the sketch in post#1. This is because I'm still not very sure, if the two small sections just under the armpits would be necessary
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Wed 19 May, 2010 11:38 am    Post subject:         Reply with quote
Meanwhile, I purchased this riveted mail
which I will use as a supply depot for straps of riveted rings.
Here is a closer view to a section of the mail
The coin (which is Bulgarian national curency) is almost equal in size to 1 EURO coin.
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Sat 22 May, 2010 2:35 pm    Post subject:         Reply with quote
Somewhere at this point, I started with the real work.
The first step is to prepare the plates, and these are the phases:
From bottom up: firstly they were drawn and marked; secondly - all holes were drilled; the plates were cut, the corners - rounded and the edges - finished; then the plates were bent and the surface - finished to a smooth satin appearance; and lastly - the plates were oxidized against rust.
In this closer look:
the order (clockwise starting from the top left corner) is the same.
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Sun 23 May, 2010 11:24 pm    Post subject:         Reply with quote
These
are the almost countless little plates for the skirt - a work done during the "dead" period in which I equipped my new workshop.
And a simplified pattern of their arrangement
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Mon 24 May, 2010 2:41 am    Post subject:         Reply with quote
Now, with almost all plates (except these from the breastplate) done through the previously showed phases
and the mail, destroyed Laughing Out Loud into straps
I can start to connect the plates into desired rows.
Tokugawa Ieyasu
Romulus Stoica
PostPosted: Tue 25 May, 2010 12:29 am    Post subject:         Reply with quote
Very nice work! What are the inside diameter of the rings of mail and the thickness of the wire? Also what are the dimensions of the plates (the height of the rows of plates)?
Boris Bedrosov
PostPosted: Tue 25 May, 2010 10:09 am    Post subject:         Reply with quote
Romulus!
The wire is 1,4 mm thick and the inner diameter of the rings is 8 mm.
Obviously, the plates are different in size and shape - the height is constant for all of them (50 mm), but the wight varies from 46 to 146 mm. The plates for the skirt are 98 x 34 mm (big ones) and 50 x 34 mm (small ones). The plates for the breastplate (not shown yet) are bigger than everything else.
The height of the central back row, which I managed to assemble today, is 508 mm when fully streched.
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Tue 25 May, 2010 11:24 am    Post subject:         Reply with quote
The central back row is ready:
Although I have some experience with combined mail-and-plate armours, I was well surprised by the flexibility of the row
and in the opposite direction:
Actually, I think that this flexibility will be restrained when the full cuirass is ready, but the result is good so far
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Thu 27 May, 2010 9:46 am    Post subject:         Reply with quote
The breastplate right into the middle of the working process
As you see, there is a great difference between the initial idea and the result.
In order to use these traditional Ottoman locks (the hooks aren't still attached)
I was forced to re-work the whole breastplate, but although (with bigger plates) it is still quite close to the autentic ones.
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Fri 04 Jun, 2010 1:36 pm    Post subject:         Reply with quote
And the finished backplate looks like this
Tokugawa Ieyasu
Page 1 of 26 Reply to topic
Go to page 1, 2, 3 ... 24, 25, 26  Next All times are GMT - 8 Hours
