Forum Index > Off-topic Talk > Middle Ages Crossbows; Really Need Someone to Answer This Reply to topic
Kevin S.
PostPosted: Wed 16 Dec, 2009 11:14 pm    Post subject: Middle Ages Crossbows; Really Need Someone to Answer This         Reply with quote
Most reliable people that I have talked to stated that the 250 lbs crossbow would be for the Early Medieval Ages; that the 300 lbs to 600+lbs would be for the High Middle Ages; and that the 1000+ lbs would be for the Late Medieval Ages.
Are there any academic sources that would back this up?
thank you
Randall Moffett
PostPosted: Thu 17 Dec, 2009 7:01 am    Post subject:         Reply with quote
Take a looks at springalds and the great crossbows by Jean Lebiel. It is released by the Royal Armouries.
PostPosted: Thu 17 Dec, 2009 11:18 am    Post subject:         Reply with quote
Are you referring only to war bows?
Kevin S.
PostPosted: Thu 17 Dec, 2009 12:33 pm    Post subject:         Reply with quote
the war crossbows
Kevin S.
PostPosted: Thu 17 Dec, 2009 5:17 pm    Post subject:         Reply with quote
It's not on the internet Sad Cry
And I don't have the time to go to the library. Darn it, I should have a private library at home Mad
Randall Moffett
PostPosted: Fri 18 Dec, 2009 7:24 am    Post subject:         Reply with quote
If you are limited to things online I do not think you will find any real useful information that would be academic.... The books is only 15 dollars or so though.
