Posts: 5,739 Location: Wichita, Kansas
Fri 09 Jul, 2004 8:23 pm
Paul Mortimer wrote: |
Patrick,
I will certainly try to do that and I am honoured that you have asked me.
Shall I contact you off list to get details of how to approach the review? I am a little new here.
Paul |
I'll send you a Private message Paul.
Posts: 301 Location: Palo Alto, CA
Fri 09 Jul, 2004 8:55 pm
:eek: :eek: :eek: Wow!
Will you ever dare cut with it?!?!?!
A magnificent piece. Major Congratulations to the maker and the owner.
Posts: 802 Location: In a van down by the river
Sat 10 Jul, 2004 1:03 am
Well, as long as we're showing off.... :D
Attachment: 13.29 KB
![PBViking4.jpg](files/pbviking4_271.jpg)
Sat 10 Jul, 2004 1:05 am
The pattern (
blodida, right?):
Attachment: 18.07 KB
![PBViking3.jpg](files/pbviking3_824.jpg)
Sat 10 Jul, 2004 1:07 am
Pictures don't really do it justice... the fine details really make the sword....
Attachment: 20.66 KB
![PBViking7.jpg](files/pbviking7.jpg)
Posts: 634 Location: UK
Sat 10 Jul, 2004 6:24 am
The A10 viking on Mr Barta's site has long been one of my favourite swords. All of his pattern welded blade work is exquisite, but when it is topped off with a hilt like that on the Sutton Hoo I run out of adjectives. That isn't even my favourite period, and looking at it coldly I'd probably have to go with Mr Wilson's viking (of the two), but those garnets on the Sutton Hoo, and the metal work!! It would be a delight to own either, but just to see the pictures is a privilege. Thanks to both Mr Wilson and Mr Mortimer for sharing.
Posts: 353 Location: NJ, US
Sat 10 Jul, 2004 8:14 am
These are absolutely incredible.
Are those prices on his site correct? Or, should I say, am I reading them correctly?
Posts: 1,191 Location: San Francisco, CA
Sun 11 Jul, 2004 8:20 am
Russ Ellis wrote: |
Agreed, we definitely need to see more pictures of that sword. It is a replica of the Sutton Hoo sword? |
Hi Russ,
I wondered the same question and went on to find the answer. It does appear to be a replica (at lest the hilt) of the Sutton Hoo sword. I have attached two pictures of the original, that I found on the web.
Alexi
Attachment: 23.19 KB
![SuttonHooSwordHilt.jpg](files/suttonhooswordhilt.jpg)
The Hilt
Attachment: 12.45 KB
![SuttonHooCompleteSword.jpg](files/suttonhoocompletesword.jpg)
The whole sword
Posts: 285 Location: England, Essex
Sun 11 Jul, 2004 11:30 am
The sword is not an exact replica of the Sutton Hoo -- for one thing the original sword, when found, only had two filigree clips on the grip whereas Patrick Barta has put four on my sword. Patrick's sword is also slightly longer -- as far as we can tell.
Paul
Sun 11 Jul, 2004 1:09 pm
Paul |
I imagined that it would not be an exact replica first of because not all a whole lot of the original sword was left. That being said, the hilts (the remaining part of the original) looked identical at brief, and not very thorough inspection. Apparently I missed the filigree clips.
Alexi
Sun 11 Jul, 2004 10:35 pm
Alexi Goranov wrote: |
Paul Mortimer wrote: | The sword is not an exact replica of the Sutton Hoo -- for one thing the original sword, when found, only had two filigree clips on the grip whereas Patrick Barta has put four on my sword. Patrick's sword is also slightly longer -- as far as we can tell.
Paul |
Alexi |
Mr Barta's addition of the two extra clips appears a rational reconstruction of the original, unless it was intended to be a single edged sword (or at least one used with a preferred edge). Although there are obvious exceptions (basket hilts etc..), symmetrical blades tend towards having symmetrical grips.
Posts: 820 Location: Texas
Mon 12 Jul, 2004 9:51 pm
Geoff Wood wrote: |
Alexi Goranov wrote: | Paul Mortimer wrote: | The sword is not an exact replica of the Sutton Hoo -- for one thing the original sword, when found, only had two filigree clips on the grip whereas Patrick Barta has put four on my sword. Patrick's sword is also slightly longer -- as far as we can tell.
Paul |
Alexi |
Mr Barta's addition of the two extra clips appears a rational reconstruction of the original, unless it was intended to be a single edged sword (or at least one used with a preferred edge). Although there are obvious exceptions (basket hilts etc..), symmetrical blades tend towards having symmetrical grips. |
I read somewhere that it is possible that the clips were only on one side to make sure that the sword was placed into the scabbard in a preferred position... not sure why? Maybe the blade had a sharp edge for slicing and dicing and a not so sharp edge for heavy duty chopping.
ks
Mon 12 Jul, 2004 10:14 pm
Kirk Lee Spencer wrote: |
ks |
Or maybe they were part of a 'posh' one sided grip repair. Interesting speculation. It also remains possible that the matching pair were lost before burial or during recovery (they did kind of miss the traces of the body too, if I recall correctly).
Posts: 1,757 Location: Storvreta, Sweden
Tue 13 Jul, 2004 4:21 pm
[quote="Geoff Wood"][quote="Alexi Goranov"]
(First of all: Stunning Work!)
It should be kept in mind that even on symmetrical styled hilts/swords, there is normally a back and front of the blade or the hilt. On a ring hilted sword there would be one obvious way to wear the sword: with the ring facing the side towards the ground when worn in a sloping angle on the left hip. Non-symmetrical mounts are not uncommon on migration era swords. To us it might seem stange at first, but it can be part of the style.
Even when there are no signifying features in a sword there is still usually one way that a blade will fit best in the scabbard. A well-made scabbard will have a fit that is tight enough to make a difference for an ever so slight sabering in the blade (not unusual to find asymmetries that are not readily recognizable by the naked eye, but will show when the sword is pushed the wrong way into the scabbard)
I do not think there were two different types of sharpness in the blade. Both edges would have been sharpened the same: second edge for back hand cutting or as back up edge.
Tue 13 Jul, 2004 7:54 pm
Peter...
Excellent info... as usual. I always look forward to your posts...
thanks for taking the time.
ks
Wed 14 Jul, 2004 11:50 am
Geoff Wood wrote, "Mr Barta's addition of the two extra clips appears a rational reconstruction of the original"
There is a ring sword that was found in a Lombard cemetery in Italy, Nocera Umbra - grave 32, that has very similar filigree clips to the Sutoon Hoo and it has four. The clips are so similar in fabrication to those on the Sutton Hoo that they could have been made by the same artist.
However, I don't believe that the Sutton Hoo, at the time of burial had four, and I suspect never did. I have to agree with Peter.
Paul
Posts: 150 Location: Brisbane, Australia
Tue 27 Jul, 2004 11:46 pm
Just to bring to the top an awesome thread, I am VERY impressed with Patricks work...much so that after my Trip to the US and after I have my Bugei kat I'm ordering from him to get a precise replica made of a favoured migration style sword but then my own customiseations.
IMO I havnt EVER been as impressed with someones hilt work then I have been with that Sutton Hoo like sword...for those of you that remember my posts on SFI about the sutton hoo sword (before my posting priveledges were removed) I was trying to find a smith cabable of carving garnet and doing that type of work and now I'm VERY happy to have found one (in a sense of the word).
Great swords everyone that has posted one up, when it gets closer to me having enough to make an order I'll be sure to ask for help in the design process to keep it historical to the period of sword I'm after (since 90% of my sword knowledge is invested in Japanese swords).
:cool:
Posts: 11,553 Location: San Francisco
Fri 06 Aug, 2004 10:37 am
Patrick Bárta has recently published some new big and detailed photos of his Sutton Hoo sword:
[ Linked Image ] [ Linked Image ] [ Linked Image ]
Click any photo to see its full-sized version
These are highly detailed photos that show the amazing talent of this man.
Impressive work, to say the least.
He's also recently completed a Celtic sword:
Click photo to see its full-sized version
This sword features a pattern-welded blade and an iron scabbard
Posts: 1,717 Location: Buffalo, NY.
Fri 06 Aug, 2004 1:03 pm
Yes, Mr. Barta shows amazing skill in this, and other, pieces. I especially like the inlays in some of his viking hilts- seem very historically accurate. Does anyone know if other of Mr. Barta's swords tend to be a wee bit heavier than would be desired? Do any of his swords feature inlay on the blade? Thanks Jeremy
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
