Hello myArmoury community.
I'm a firm believer that every sword deserves a good home, and the Windlass Arming Sword is no exception! I felt pretty good about this one once completed and I thought everyone here would enjoy having a look.
Commentary and such are welcome, as usual and thanks for looking!
That looks very nice Brian. You took something that some might look down on and made it special with another one of your superb scabbards. While it is not your fanciest work in terms of decoration it's simplicity speaks to me as it were.
Scott
Scott
| Scott Kowalski wrote: |
Scott |
Thank you Scott, you always have something nice to say and are very cordial I might add. Every once in a while a customer forces my hand into the simple, yet elegant looking leatherwork ;)
| Brian K. wrote: | ||
Thank you Scott, you always have something nice to say and are very cordial I might add. Every once in a while a customer forces my hand into the simple, yet elegant looking leatherwork ;) |
You are welcome Brian. I was always told if you do not have something nice to say then do not say it. I try to keep to that as much as I can. I guess it also stems from the fact that I am in sales so how I present myself most of the time as well as speak is important to my well being, and my ability to buy shiny toys and the things that go with them. Sometimes simple is better. Especially when you can make it elegant in the doing.
Scott
That and I plan on contacting you for a scabbard when a couple of other projects are completed so it does not hurt to schmooze you! ;)
| Brian K. wrote: |
I think the mark of an artisan is to be able to visualize his project be it simple or intricate, plain or ornate culminating in a balance of form, color,- and in the case of scabbards- function. The range and depth of your talent is evident with every piece you post, Brian. Always a pleasure to see your work..
| R D Moore wrote: | ||
I think the mark of an artisan is to be able to visualize his project be it simple or intricate, plain or ornate culminating in a balance of form, color, |
I agree completely :). Brian always does a superb job creating a scabbard that matches its sword perfectly. Another great job Brian.
Superb scabbard.
M.
M.
Hey Brian,
I've been curious. Why do you cut your belt ends the way you do? When I do a belt I usually notch the transition between the fixture and the leather so that it's flush. Like I said, just curious. Like your scabbards.
~A
~A
that really dresses up what I have always considered a rather bland sword, excellent presentation
Randy
Randy
| Adam S. wrote: |
| Hey Brian,
I've been curious. Why do you cut your belt ends the way you do? When I do a belt I usually notch the transition between the fixture and the leather so that it's flush. Like I said, just curious. Like your scabbards. ~A ![]() |
Hmmm, in short, I actually do everything a little differently each time. I think in this case it could have gone either way. Good eye though.
Another solid victory! Keep them coming, your scabbards get better and better. Gorgeous. Simply gorgeous.
you really are a complete and utter b*****d.
by which, I should add, that that is yet again, completely and utterly gorgeous, and therefore I envy you something rotten for being able to make something of such quality... :)
Actually, what I envy most is that you seem to be able to make them so blimmin' fast... there's a new post every few days, it seems... amazing.
Someday, if I'm able to send something all the way to you from this side of the pond, I'll have to look at a commission or two. maybe three. or four. actually, make that five. do you do bulk discount for one of every period? :)
two things I'd like to ask, however: The first is if you have any photos of the scabbard throats? I gather from a comment you made in one thread that you use a wool lining... friends have tried to make scabbards with wool lining for viking period swords (reenactment) and let's just say the end results were... well.... if you imagine a scragging a sheep, and stuffing a strip of it's side between two bits of timber, before wrapping it in a bit of a shaved coo's bum, you've got an idea of what it looked like. now take that image, and make it about 3 times uglier than your first image, and you've got a pretty good picture of the monstosity that was done... I swear, you could've driven a bus into that thing.
so I'd love to see a shot of the throat, so we can look and go "aah, so it is possible", and, if it does'nt inspire the chap to do a commission, perhaps at the least inspire something a little less ghastly than that Frankenscabbard... though even using the same word "scabbard" to describe such an object is an insult to your gorgeous work.... I dont think we got photographs of it, thankfully. it might've cracked the camera lens.
The other question is, can you do scabbards for rebated reenactment blades, with a thicker edge, or does the router/jigging/carving/miracle working you do preclude such thickened edges?
Nice! The only thing that doesn't look right is the buckle and the strap end; they're both a bit late for that type of suspension, although it is possible they might've coexisted. And I'm probably one of the few that'll care or notice anyway so... ;)
Johan Schubert Moen
Johan Schubert Moen
"Handsom" was the word that imediately sprung to my mind when I looked at those pics. very nice work.
| JG Elmslie wrote: |
The other question is, can you do scabbards for rebated reenactment blades, with a thicker edge, or does the router/jigging/carving/miracle working you do preclude such thickened edges? |
I'll get back to you on the throat pic's, as I don't have any right now.
I guess it depends on how thick the edge is. I've made scabbards for blunt's before, in fact this particular scabbard is a blunt, but of course Windlass blunt edges are fairly thin. My question would be, how chewed up is the edge or would it become after use, because that would definitely affect the fit down the road. I could use a different technique that allowed for plenty of edge damage, if that is the case, but it wouldn't be a 'fit's like a glove' fit. But it would look good, and that would be the point, right?!? :cool:
This seems a little like the Excalibur example on the Albion web site. I don't mean to put down a great value sword, but I am not sure it is worthy of its scabbard!
That is a lovely fit up of the chape to the raised leather outline of its mouth profile by the way. (I am not sure if it is raised there, or if you have stippled the contrasting region to give it the matt finish.) I don't recall seeing it done much before. I think its a great example of creativity based upon historically based design philosophy.
| Brian K. wrote: |
I'll get back to you on the throat pic's, as I don't have any right now. I guess it depends on how thick the edge is. I've made scabbards for blunt's before, in fact this particular scabbard is a blunt, but of course Windlass blunt edges are fairly thin. My question would be, how chewed up is the edge or would it become after use, because that would definitely affect the fit down the road. I could use a different technique that allowed for plenty of edge damage, if that is the case, but it wouldn't be a 'fit's like a glove' fit. But it would look good, and that would be the point, right?!? :cool: |
thanks for that - I'll look forward to the pics - to discuss commissions for reenactment use, I'll likely discuss that via email or the likes when my cashflow is a bit more secure...been laid off work for a while due to RSI :/
Well, it's kind of like approving a subprime mortgage so a crackhead can live in a quarter-million dollar home but to each his own. :D
Seriously, you took a mediocre sword and turned it into an eye catching ensemble. Did you re-do the grip as well?
Very nice.
Very nice.
You're going to have to take my word for it when I say that the sword is far from mediocre. Of the three I've seen so far, they're all worth at least twice what the asking price was. Far from mediocre.
The scabbard is excellent, Brian.
| Patrick Kelly wrote: |
Seriously, you took a mediocre sword and turned it into an eye catching ensemble. Did you re-do the grip as well? Very nice. |
Thank you Patrick. The grip is my handywork as well.
| Nathan Robinson wrote: |
The scabbard is excellent, Brian. |
Thank you very much.
Thank's everyone for the kind word's, it really mean's a lot.
Page 1 of 2
