Forum Index > Historical Arms Talk > MRL Coustille upgrades Reply to topic
Julien M
PostPosted: Sun 12 Apr, 2009 4:39 am    Post subject: MRL Coustille upgrades         Reply with quote
Been busy lately, I was barely done with modifying the hilt of the Henry V that a friend of mine told me he wanted to purchase an MRL Coustille, and that he would request sharpening service on it. I had ordered a towton with sharpening service before and thought the edge had been done with care, I though the visible bevel reduced the appeal of the sword a great deal.
So I ordered a blunt one for him, and did a few modification while I was at it.
1- Established a secondary bevel with a file, then blended it to an appleseed edge. This took a while, but was well worth it. The bevel is invisible unless you use a magnifier, but yet the sword cuts very well (cuts paper with ease but you can hold the sword's blade with your bare hand without cutting yourself).
2- Cleaned the blade of grind marks, repolished to a satin finish.
3- blued the hilt, then use salt and vinegar to etch the blade, hilt furniture’s and scabbard mountings. I wanted to experiment with that, and it really improved the finish. This technique I learned from Sean in the instant antique guide works very well, isn’t permanent and adds a lot of character to the sword.
4- removed the glossy handle leather, placed raisers on the wooden core, and rewrap using chamois. I improved my technique: after two hours of drying, remove the cord around the grip. It will allow you to check if raisers formed correctly, and you'll be able to correct oddities as the glue isn’t dry yet. The most common issue is around the raisers, as when you glue the cord in place using instant glue, it sometimes hardens the cord and can cause ugly things when covered with leather. Sand the cord lightly to solve the issue. I improved the leather overlap too, then put everything back into place, damped the leather with an extra coating of dye, rewrap, leave it for the night...done. The grip would have looked average at best if I hadn't done that.
5- Removed the scabbard dye rubbing patiently with solvent, and died it again to match the new grip colour.
I really like how it all turned out...the bad news is that I will have to ship it to my friend soon, and I don’t feel like parting with it now:)
Hope you enjoy.
J
 Attachment: 27.39 KB
coustille before
 Attachment: 50.14 KB
hilt detail
 Attachment: 18.83 KB
 Attachment: 45.75 KB
 Attachment: 105.87 KB
 Attachment: 77.06 KB
David Sutton
Likes: 15 pages
Reading list: 39 books
PostPosted: Sun 12 Apr, 2009 4:59 am    Post subject:         Reply with quote
Really well done Julien! You are really getting good at this; just makes me want to get started on my own projects!
'Reserve your right to think, for even to think wrongly is better than not to think at all'
'To teach superstitions as truth is a most terrible thing'
Hypatia of Alexandria, c400AD
Bruno Giordan
PostPosted: Sun 12 Apr, 2009 7:29 am    Post subject:         Reply with quote
From costume to custom. Nice work
M. Eversberg II
Reading list: 3 books
PostPosted: Sun 12 Apr, 2009 12:17 pm    Post subject:         Reply with quote
*F*antastic.
M.
This space for rent or lease.
Joe Fults
PostPosted: Sun 12 Apr, 2009 12:47 pm    Post subject:         Reply with quote
As you and some others have shown, some of these pieces can really be made to look much nicer with a bit of work. I have no idea how much labor really went into this. Perhaps its labor cost prohibitive but it would be nice to see more of these upgrades adopted into standard production runs.
Roger Hooper
PostPosted: Sun 12 Apr, 2009 1:20 pm    Post subject:         Reply with quote
That is really impressive - 100% improvement on the original sword.
Eric W. Norenberg
PostPosted: Sun 12 Apr, 2009 10:07 pm    Post subject:         Reply with quote
When I first compared your "before" and "after" shots, the above quote is what immediately came to mind, verbatim. Bravo, sir! Encore!
Craig Peters
PostPosted: Mon 13 Apr, 2009 12:20 pm    Post subject:         Reply with quote
It's amazing to see the difference that your work has made. The first coustille I wouldn't even consider ordering based upon its appearance alone, whereas the second looks like an quality reproduction.
Alain Poirier
PostPosted: Mon 13 Apr, 2009 1:43 pm    Post subject: Coustel, ou basillard !!         Reply with quote
Wonderful work my friend, don't forget my futur "payback" : the Encyclopédie Médiévale by Viollet Le Duc !
Did you talk with "Alexi Goranov" ? Interested by this unoble weapon (that I ever wanted call "basillard" made with nozes of broken swords...)
A +
Alain Poirier
Coustillier
Julien M
PostPosted: Tue 14 Apr, 2009 2:56 am    Post subject:         Reply with quote
Thanks for your comments guys. much appreciated!
You should mate, it's very rewarding. There is something really cool about taking an entry level piece and making it closer to the more expensive replicas out there. I see Windlass steelcraft as the ultimate DIY kit now, providing a solid frame for home improvments: cheap (so that your hands don't shake when approaching the blade with anything more threatening than sandpaper), dismoutable, they also often feature nice hilts furnitures and their blade, thought soft tempered, are appropriate for anything the size of a one handler or below (even if some of their bastards swords proved better lately).
All in all, they end up very nicely with some elbow grease and some patience, plus I have gathered enough confidence to tackle more expensive swords now (just changed the color of my A Crecy grip).
Thanks Joe. I'd say hours spread accross a all week. (two or 3 per night) But sharpening/repolishing and antiquing were unknown to me and I had to acquire the skills and experimented along the way.
J
Ole W.
PostPosted: Tue 14 Apr, 2009 11:47 am    Post subject:         Reply with quote
I would be very interested to see the new grip colour of your Crecy. Did you colour it to match your scabbard? Pictures would be appreciated, especially photos of the sword and scabbard together. (Your crecy-scabbard thread was very helpful when I made a scabbard for my own, newly acquired Crecy)
Julien M
PostPosted: Tue 14 Apr, 2009 12:21 pm    Post subject:         Reply with quote
Hi Ole,
I'm glad that documenting the scabbard project was of any use to you. I did try to match the color of the scabbard (I might get sick of that burgundy color very soon Happy ), and it was no easy task as removing the dye from a windlass scabbard such as this one was a piece of cake compared to that crecy handle. Quality materials, quality dye...made to last. Lots of patience is requiered, lots of alcool (90 degree) too, only to remove very little dye and expose very little leather. Black to oxblood is a very hard transition to make. Mostly I managed to remove the upper layer, on the raisers and other raised pattern, but I uspected that it would be enough to set the new color, with a black undertone which I like anyway. It worked very well in the end I think, but the bad news is that I tried to undertone the scabbard too, in order to match the darker grip color....using dark brown shoe polish. Mistake: got a really convincing match, but the grip has a very matte finish and the scabbard is much too shiny. I've washed and rubbed the scabbard, with litlle succes so far. I will figure out something, or will do the wrap again...
have a look for yourself,
Cheers.
J
 Attachment: 40.06 KB
 Attachment: 66.15 KB
Brian K.
PostPosted: Tue 14 Apr, 2009 7:35 pm    Post subject:         Reply with quote
You seem to be enjoying what you're doing, and that is what is most important. Very nice work indeed.
"From costume to custom. Nice work"
I agree with this sentiment very much.
Brian Kunz
www.dbkcustomswords.com
Julien M
PostPosted: Wed 15 Apr, 2009 2:05 am    Post subject:         Reply with quote
Thanks a lot Brian,
Indeed I do enjoy working on such projects, partly I think to remedy to the frustration of not having the means (nor skills) to produce a blade from forge to finish. So I'm going the other way around, from cosmetic to structural. I'll try on more hilts and pommel alterations as soon as I can, then forging lessons for a blade someday (there are forging schools in London that I surely will visit)...long term perspective...
Anyway I stopped smoking 3 weeks ago, which does explain this sudden burst of sword related activity (a repentant smoker needs to be busier than an ant if he's to succeed Happy )
J
Michael B.
PostPosted: Wed 15 Apr, 2009 11:11 pm    Post subject:         Reply with quote
Well, Julien, your post was the straw that broke the camel's back. I finally had to do it, I ran to the store and picked up some supplies last night, and spent the next couple hours tearing apart my Cas/Hanwie Practical Arming Sword. It turned into a much bigger project than originally thought when I found out that the risers under the original wrap were plastic, and in fact, the whole handle was plastic, pretty much melted onto the tang. After cutting and sanding off all these plastic risers, I was about to start wrapping when I noticed a weird gap that had been created in the quillon. After filling it with epoxy and cord, started the rewrap. Overall, I'm pleased with how my first try came out, but now I may be feeling the pangs of addiction. Thanks for the incentive! Not as pretty as yours, but I'll keep trying! Also going to try my hand at antiquing the furniture.
Notes: I need to clean up the pommel end of the wrap still, and give it a good beeswax buff, also need to finish polishing the quillon after engraving, just too excited not to post. Thanks for looking.
Some links of the plastic bits I ran into.
http://i444.photobucket.com/albums/qq167/mkbergstrom/uglyGrip.jpg
http://i444.photobucket.com/albums/qq167/mkbe...edgrip.jpg
http://i444.photobucket.com/albums/qq167/mkbergstrom/wierdgap.jpg
http://i444.photobucket.com/albums/qq167/mkbe...ndgrip.jpg
www.facebook.com/bearmountainforge2
Michael Bergstrom
M. Eversberg II
PostPosted: Thu 16 Apr, 2009 12:00 am    Post subject:         Reply with quote
Not bad at all for a first go.
M.
Julien M
PostPosted: Thu 16 Apr, 2009 9:51 am    Post subject:         Reply with quote
My Pleasure Michael, and nice grip job for a first attempt (there will be many more I'm sure...once you start...).
These hanwei swords seem to have really dodgy construction materials. A plastic handle? Christ...can it be completely removed and replaced by a wooden sandwich one? That would definitely improve the sword further, allowing you to have a more even finish and also you could shape the grip to taper towards both ends, which is an easy win in terms of overall aesthetics. But I have no idea how hard it was to chopp some of that plastic off, judging by the pictures it looks like that wasn't too easy. That flatten pommel reduces the appeal too, but I seem to remember reading that those were hollow so they can't really be reshaped to something more round. Looking at the picts again and considering the proportion of the hilt, I think you could go for slighlty thicker raisers that would end up shaping the grip a little bit more.
How did you do the carving? With chisels? Dremel tool? Funny I also had in mind to give it a go at some point. It looks a bit crude, but not inapropriate for that type of sword and I'm sure that with some antiquing it will blend in nicely and will look very good. Do you have some bluing paste? I'd use that and then use vinegar and salt on the top. Just tried this combinaison and it works very well, giving a deeper/richer result than salt and vinegar alone. After bluing, you usually rub the surface with steel wool (or with a sponge depending on how well the metal takes it) to even the color, but in the recesses created by the letters, a dark tone would remain, making those letter stand out. A lasy solution could be to use something else, like shoe polish or an ink wash, to darken the recesses.
Make sure to post pics to see how that goes.
J
Ole W.
PostPosted: Fri 17 Apr, 2009 7:48 pm    Post subject:         Reply with quote
Thanks for the pictures!
Changing the grip colour of the sword to fit that of the scabbard made a huge difference IMO, the two objects now seem like components of a single "unit". I must admit that I'm very impressed with your upgrades (scabbard, grip colour) to the sword as it was received from Albion. Please do post pictures again when you have received the scabbard chape (and added a suspension system, if you opt for that) - I'd be very interested to see them.
Michael B.
PostPosted: Fri 17 Apr, 2009 8:30 pm    Post subject:         Reply with quote
Hello Julien. I put the engraving in with the Dremel tool, planning on going back with the diamond file and very fine sand paper. Good idea with the blueing paste, I'll give it a shot. I went back last night and tore everything off, down to the tang. I'm carving a whole new handle this weekend. I'll post the pics when I'm done. In a new thread, so I stop hijacking yours Wink
Look what you've done....
Michael Bergstrom
Christopher Finneman
PostPosted: Fri 17 Apr, 2009 9:10 pm    Post subject:         Reply with quote
Ok, Probably very easy explanation to it. But how did you do risers in the grip? Is it just cord under the leather? I know Im probably thinking way to hard on this but I need to know
I gots the MRL 14th century long sword that I oil blackened the hilt and pommel and redid the wire wrap in copper and mild steel wire. Now I need to know the riser part.
Thanks!
Proudly it stands until the worlds end. The victorious banner of love.
