Gabriele Becattini
Posted: Mon 02 Feb, 2009 5:32 am Post subject: sabre hilt pattern |
Hello,
i'm looking for a new hilt for my practice sabre,
i believe that a simple sheet guard like the swedish cavalry pattern or the spanish infantry officer of the late 19th century ,are not too difficult to make by myself.
could someone give me some complete measurements of an hilt like that or better a pattern?
thanks for help
gabriele
Kjell Magnusson
Posted: Tue 03 Feb, 2009 4:58 pm Post subject: |
Not quite the same, but if there's interest I could take some rough measurements on the guard of my Swedish naval cutlass m/1849.
As for the Swedish cavalry swords such as the m/1893, then I seem to recall hearing that it's been inspired by an Austrian pattern, so perhaps you could find something looking for that.
Attachment: 96.2 KB
m/1849 hilt
Attachment: 76.64 KB
m/1893 hilt
Gabriele Becattini
Posted: Wed 04 Feb, 2009 1:23 am Post subject: sabre hilt pattern |
Hello Kjell,
i will appreciate if you could give me the measurements of your cutlass, it could help me .
i'll try to follow your advice regarding the austrian cavalry hilt, it look pretty good for my project.
thanks
Gabriele
Kjell Magnusson
Posted: Wed 04 Feb, 2009 10:31 am Post subject: |
Let's see here then, hopefully this image will be understandable. All measurements in mm.
For the two main discs, the measurements have been done in a straight line. They are both dished to a depth of ca 10mm, and if one measures along the curve the width and length is in both cases ca 5mm longer than this. The dishing isn't entierly uniform, the "ear" have been bent a bit extra towards grip, so it's a bit shallower in the up-down direction (in this image).
The rounded part at the bottom basically just follows the profile of the grip, as seen in the photograph I posted above.
Measuring with a normal ruler the thickness of the metal appears to be 1mm, possibly a bit more.
I'm also attaching a side view of the hilt to show the shape it's been bent into.
Attachment: 5.16 KB
Measurements
Attachment: 81.43 KB
Side view
Gabriele Becattini
Posted: Thu 05 Feb, 2009 5:29 am Post subject: sabre hilt pattern |
Kjell,
thank you very much for posting it, it's very helpfull
Gabriele
Jonathan Hopkins
Posted: Thu 05 Feb, 2009 5:32 am Post subject: |
Kjell,
Your cutlass is interesting. The hilt looks like that of the British P1804 cutlass.
Jonathan
Kjell Magnusson
Posted: Thu 05 Feb, 2009 6:15 am Post subject: |
Jonathan Hopkins wrote: | Kjell,
Jonathan |
It's the same sword, one of three British patterns bought by Sweden. We also bought 4000 each of the 1796LC, which ended up as the m/1808 for artillery, and the 1796HC, which was designated the m/1808 for heavy cavalry, earlier in the 19th century. These were both bought as an emergency order (we needed a lot of swords in a hurry). I don't think anyone is quite sure why we bought the P1804 though.
Despite the navy getting a new model as early as 1851 (an entierly domestic design this time), the m71849 would remain in use with some units into the 20th century. The navy never had much of a budget for melee weapons.
