Forum Index > Off-topic Talk > Best Hiking/Hunting Knife? Reply to topic
Chris Artman
PostPosted: Mon 29 Sep, 2008 10:57 pm    Post subject: Best Hiking/Hunting Knife?         Reply with quote
Ok, so I don't feel like carrying a shortsword or leafblade hiking/camping... what are some of the best 'big knives' available? Even if there is one you like just for whatever reason... Quality, looks, function....
M. Eversberg II
Reading list: 3 books
PostPosted: Tue 30 Sep, 2008 12:50 am    Post subject:         Reply with quote
Can't go wrong with a machete, or is that too large?
M.
This space for rent or lease.
D. Austin
PostPosted: Tue 30 Sep, 2008 1:25 am    Post subject:         Reply with quote
I guess it really depends on the intended use but for a "big" knife, the khukri fits the bill in terms of quality, looks and function in my opinion. It is also quite adaptable to a number of purposes. I have quite an old one which doesn't look like it'll ever give up.
Jan H.
PostPosted: Tue 30 Sep, 2008 3:44 am    Post subject:         Reply with quote
Try and have a look at the laminated knives from Fällkniven.
www.fallkniven.com
Jeroen Zuiderwijk
PostPosted: Tue 30 Sep, 2008 4:33 am    Post subject:         Reply with quote
Depends on how big you're looking for, but for bigger then the average pocketknife, I'd personally go for a leuku. Depending on which brand/maker, they can be really pretty. And you can't go wrong with a swedish/finish blade. They do know how to make their knives sharp and durable:)
Here's a few examples:
http://www.ragweedforge.com/FinnishKnifeCatalog.html
There's another much larger distributor, but I can't find the link at the moment.
Mick Czerep
PostPosted: Tue 30 Sep, 2008 4:34 am    Post subject:         Reply with quote
Nothing wrong with a Bauernwehr, is there? That's what I'd choose, but I'm mediaeval-fixated.
Sordes ocurrit
B. Fulton
PostPosted: Tue 30 Sep, 2008 6:35 am    Post subject:         Reply with quote
www.graymanknives.com
I know the owner, and two of his Suenamis are currently downrange thanks to me.
His knives aren't "pretty" but they're well made and tough.
If you're on a budget, the Cold Steel SRK does a fine job.
Raymond Deancona
PostPosted: Tue 30 Sep, 2008 6:49 am    Post subject:         Reply with quote
I have to agree with everyone else here: how big and what purpose? If I'm going fishing I carry a Bud Nealy or Bob Dozier, small enough fixed blades to fit in the pocket (and really lightweight) but big enough to be "tactical" if things go wrong. If I'm out deer hunting I carry something bigger (though no real reason too). If I am at a re-enactment meeting I try to keep something "period" for the daily chores. And finally, how much are you willing to spend?! There are dozens of excellent custom and semi-custom makers out there with all kinds of price ranges. One thing you may want to consider on price is how bad are you going to feel if you lose the knife in the field? Can you shrug off a $400 dollar loss? Also check out a knife show and feel the knife in your hand before buying it. (can't stress that enough, doesn't matter how well the knife was made it you just can't stand how it feels in your hand)
R D Moore
Reading list: 11 books
PostPosted: Tue 30 Sep, 2008 4:24 pm    Post subject:         Reply with quote
Here's some of my favorite links:
http://www.highcountryknives.com/index2.html
http://www.alanwarrenknives.com/index.html
http://www.customknife.com/cbSearch2.asp?Category=Gallery
And, like everyone else has already said, it's whatever you are going to be using it for. I wouldn't want to clean a fish with a bowie knife (even though that works very nicely) any more than I'd want to clean and skin a deer with a pocket knife (I'm sure this would work, too)
Chris Artman
PostPosted: Tue 30 Sep, 2008 4:34 pm    Post subject:         Reply with quote
I suppose I was more interested in a large, well-made tactical knife, something you'd fight a mountain lion, grizzly bear, or stalker with... just like I do every weekend Wink
Ted Parolari
PostPosted: Tue 30 Sep, 2008 4:56 pm    Post subject:         Reply with quote
I too agree that it depends on what you want to do with it. One of the best knives I've found for field use is a Ka-bar. You can pound, pry, cut, thrust, chop and do just about anything with it. They are simple and rugged. Check it out here.
http://www.bestglide.com/kabar_knife.html
The other knife I'd look at is a Kukri. You can get the real McCoy here!
http://www.ima-usa.com/product_info.php/cPath...ts_id/1497
You can step back and find some others here as well. These are a piece of history!
G Ezell
PostPosted: Tue 30 Sep, 2008 5:17 pm    Post subject:         Reply with quote
When carrying a big knife I always carry a smaller knife for detail work.
Some pretty good suggestions so far, just a few things I'd like to add...
Go for carbon steel over a stainless, if possible, for a big knife that will be subjected to impact/heavy chopping. Adding enough chromium to steel to make it stainless really reduces the impact resistance.
Almost any big knife can be used as a weapon in a pinch, but you may want to consider a big stick, the reach advantage is worth it.
There seem to be two schools of thought concerning big knives, thick or thin. Thick packs a punch in a more compact package, thin makes for less fatigue and faster swings, both have their advantages and disadvantages. Thick is better for heavy chopping, thin is better for general brush removal. The kukri is a good example of a thick blade, the shorter machetes are good examples of thin.
Convex is your strongest grind, scandi/sabre is almost as tough, flat is fairly strong, and hollow grinds belong on skinners, not choppers...(IMO, hollow grinds tend to offer more resistance to cutting hard materials {wood} and only offer advantage in the cut if the material being cut if soft/pliable...if the hollow grind is made strong enough for chopping, it tends to not cut anything very well)
I've always wanted to try a good barong...
http://www.oriental-arms.co.il/item.php?id=280
Matthew D G
PostPosted: Tue 30 Sep, 2008 6:04 pm    Post subject:         Reply with quote
This is the knife i would go with, the Jefferson Spivey sabertooth
www.spiveysabertoothknife.com
This knife has been on my list for a very VERY long time Big Grin
Form the reviews I've read it sound like it would never fail you in the field
Hope that helps Worried
"I thought what I'd do was, I'd pretend to be one of those deaf-mutes."
PostPosted: Tue 30 Sep, 2008 6:50 pm    Post subject:         Reply with quote
Just to echo the previous questions, what are you really using it for?
For hiking or backpacking the Swiss Army knives make a lot of sense when trying to minimize weight in a pack along with food, tent, etc. You can actually get a lot done with a compact knife. A four inch long fixed trailing or clipped point blade in a sheath is not that obtrusive either. That is what I have my son carry when he expresses a desire for a "big knife" in typical modern situations where a small sword is not likely to be warranted. You can roll over in your sleep while wearing one, or take massive steps over rough rocky terrain without the sheath seeming to be obtrusive. This is actually big enough to improvise as a chef's "all in one" knife in camp.
Hunting, the question may be dependent on how much you intend to do in terms of field dressing and saving the hide. Drop points tend to be my favorite for scraping a hide. At least for me, the handle needs to slope up and away from the blade edge for my knuckles to stay comfortably away while working on it.
PostPosted: Tue 30 Sep, 2008 8:45 pm    Post subject:         Reply with quote
I would look at Tinker for a custom knife and if I wanted to avoid long waits I would just look at his " what is available now "
http://tinkerswords.com/Page%203.html
I would also look at John Gage's knives as well as his swords: More collectables than knock around using but nice designs and great art: http://www.gagecustomknives.com/knives.htm
I have this Ballock dagger from him that I'm very pleased with: http://www.myArmoury.com/review_gage_cocbal.html
Antoine Marçal is a very talented Québec maker who forges his blades and does very high end artistic work:
http://www.myArmoury.com/review_amar_rondel.html
http://antoinemarcal.wordpress.com/
If looking for the max. in a large factory folding knife I would go for this one by Coldsteel:
Espada series http://antoinemarcal.wordpress.com/
Or the Rajah series http://www.coldsteel.com/62kseries.html
Also look at their large Bowie knives or their very nice Kukri:
http://www.coldsteel.com/35atcj.html
Just a few suggestions and makers you might want to know about but there is an infinity of good choices out there. Wink Big Grin
Justin King
Reading list: 20 books
PostPosted: Tue 30 Sep, 2008 9:46 pm    Post subject:         Reply with quote
Angus Trim has some of his tactical knives availible on Christian Fletcher's site. They are pretty simplistic looking but knowing Gus they ought to perform well.
Oliver Wiegand
PostPosted: Wed 01 Oct, 2008 5:31 am    Post subject:         Reply with quote
http://www.chrisreeve.com/
Oliver
Hunter B.
PostPosted: Thu 02 Oct, 2008 3:53 pm    Post subject:         Reply with quote
Then you can't go wrong with a Gerber LMF II. It's my utility knife. For hunting/skinning (and other sundry tasks) I also like to use my Finnish Puuko.
I typically carry a .45 to dispatch two legged predators (never had the occasion to yet, thankfully) and for the larger ones a .44 magnum lever action rifle would work quite well, though the last time I was hunting in grizzly country I took a .45-70 Government. Grizz vs. Human without a firearm= Manburgers. Mountain lions are ambush predators so I'd be sure to keep some kind of weapon close at hand.
“It is the loose ends with which men hang themselves.”
Chris Artman
PostPosted: Tue 07 Oct, 2008 9:59 pm    Post subject:         Reply with quote
I'm leaning toward the Chris Reeve knives... They have a few 9 inch blades that seems nice. the 7.5 inch project 1 and 2 seem nice also... for what I'm looking for a fixed blade in that size range seems about right...
The Spivey knive looks nice also, but not sure how the finger/thumb hole will feel...
Anyway, something with a fixed blade in the 7.5-9" blade range seems right....
Sa'ar Nudel
Likes: 16 pages
PostPosted: Wed 08 Oct, 2008 2:04 am    Post subject:         Reply with quote
After years of using knives in the outdoors, being an archeologist, a hunter and a trailguide, I found out that basic designs make the best for me. Oh, I do have two Chris Reeve knives, several custom-made knives and our local pride, the tough as a tank Dustar Arad-1. I strongly disregard the Spivey Sabertooth because of the finger ring and the saw back. For me, a knife and a saw should be two separate items - there are wonderful super-light folding saws out there, and they are usualy cheap, too.
My recent big knife for the outdoors is surprizingly a low cost one, but in the long term test it well worth its weight by gold - the Kabar Heavy Bowie https://www.kabar.com/product_detail.jsp?productNumber=1277&mode=category&categoryId=1,2,3,7&categoryName=Military/Tactical
First, it's not so heavy. Blade is 1085 carbon steel, precisely heat treated, flat ground from the spine - that makes it a super cutter, reduces weight while still heavy enough (at the 9" version) for heavy duty chopping tasks, keeps a good edge and easy to sharpen. The handle fills the hand comfortably and its construction prevents the hand from slipping forward (this cannot be seen in a profile photo). I always use a wrist lanyard. The sheath is also well designed - the point or the razor-sharp edge will not pop out all of a sudden under stress, and there are double keepers.
p.s. I also use occasionaly a custom-made knife-size dussak, as part of a long term experimant.
Page 1 of 3 Reply to topic
