The specs are as follows:
Weight - 4 lbs, 1.8 oz
Overall Length - 52 7/8 in
Blade Length - 40 1/8 in
Grip Length - 10 in
Guard Width - 8 1/2 in
Point of Balance - 4 5/8 in
Center of Percussion - 23 1/2 in from guard
Blade Width - 1 3/4 in
Blade Thickness - 0.260 in
Steel - 5160 spring steel
This sword is hand made by stock removal method and ground to a satin finish. The rigid blade is sharpened and the tip reinforced to track through cuts and thrusts effortlessly with an excellent point control.
The guard and pommel are made of mild steel. The hilt is dismountable and is secured by a specially made barrel nut. The pommel is fitted over the rectangular section of the tang which eliminates any unwanted rotation.
Please feel free to comment. I would like to hear from you.
