Hello,
My name is Brian Kunz, and I am the owner of DBK Custom Swords. I want to formerly introduce to the fine members of myArmoury my works which I consider my art. Please don't hesitate to ask any questions, and comments are welcome.
I specialize in European/Medieval scabbards, with a penchant for classic leatherwork. My turn-around times on scabbards are typically 1 to 2 weeks once the sword is received and the work the begins.
The scabbards are handmade with a wooden core and lacquered on the outside. The core is custom sized to the individual sword for a precise fit. A precise fit means a last push snug so the sword won't fall out when turned upside down. But the sword easily draws from the scabbard when pulled out. The oak tanned leather is hand crafted with a historically accurate complex suspension system. Dye colors are applied via a multi-step hand rubbed process. Each piece is hand-stitched with a single seam in the back.
Please have a look at some of my work.
Thank you!
Thats really nice! I like the brown and green one the best.
Do you replace/customize handle grips as well?
Very well done sir. Do you have a website we can view or a link to pricing models/wait time? You might get some work from me soon. :)
WOW! those are some great looking scabbards Brian. I was just on your site and I have just two questions. First, you say you laquer the outside of the scabbard, does this mean under a layer of leather or over it or are they two different options? Second I seen the pommel decor you do and would like to know how it is applied? Anyway nice work, next time I get a sword I will consider you.
| Dan P wrote: |
Do you replace/customize handle grips as well? |
Yes I do. I do traditional cord wrapped grips with reshaping of the wood core if so desired.
http://www.dbkcustomswords.com/Traditional.html
| Mike Arledge wrote: |
| Very well done sir. Do you have a website we can view or a link to pricing models/wait time? You might get some work from me soon. :) |
http://www.dbkcustomswords.com/handmadescabbard.html
Wait time right now is less than two weeks upon receiving your sword.
| Stephen Curtin wrote: |
| WOW! those are some great looking scabbards Brian. I was just on your site and I have just two questions. First, you say you laquer the outside of the scabbard, does this mean under a layer of leather or over it or are they two different options? Second I seen the pommel decor you do and would like to know how it is applied? Anyway nice work, next time I get a sword I will consider you. |
I laquer the outside of the wood core to prevent it from water damage and warping. As far as the leather on the scabbard goes, I can make it shiny or dull upon request. If no request is made, I finish it according to how I think it would look best with the overall design.
With the pommel decor it depends on if it rests inside a pommel inset, or if it will be exposed to rubbing. Inside a pommel inset I use a high-epoxy, if it is exposed I use JB Weld.
I wanted to share some progress on a scabbard I started for Karl Knisley and his custom falchion sword. It's a unique project in the aspect of not only the shape of the blade, but one of the requested custom features of the scabbard is to duplicate the same design aspect that is etched onto the blade. The roses & thorns must be composed onto the scabbard leather in a aesthetic fashion. I'm looking forward to getting to that point, because of the unique tooling opportunity.
You seem to have a very nice fit and your work looks astounding!
You must be some kind of sorcerer...awesome work!
M.
M.
Impressive work and the photography sure makes the colours " rich " in that the glossy leather in some of them looks so good.
The designs are also very appealing.
Thank you everyone. I have another update. I have a pre-fit and most of the leatherwork is done except for the roses & thorns.
WOW that is amazing, and incredibly cheap! Other manufacturers are at least double!!!!! Will you do scabbords for other swords, i.e. Albion or A&A? Many swords I already own could use scabbords..... I will keep you in mind.
| Chase S-R wrote: |
| WOW that is amazing, and incredibly cheap! Other manufacturers are at least double!!!!! Will you do scabbords for other swords, i.e. Albion or A&A? Many swords I already own could use scabbords..... I will keep you in mind. |
Absolutely! Albion, Angus Trim, Arms & Armor, etc...I specialize in medieval / European sword types. If you have anything in mind let me know and I'll see what I can do for you.
Almost there. I'm really thinking to do any tooling below the suspension tie knot would detract from the overall look. I'm almost ready to call it good and begin the coloring.
Hi Brian-
Do you disassemble everything and dye the parts separately and reassemble?
| Nathan Robinson wrote: |
| Hi Brian-
Do you disassemble everything and dye the parts separately and reassemble? |
Yes. Each part of the scabbard is individually dyed, away from any of the other leatherwork.
Parts of the scabbard are also removed for tooling as well, and then placed back into position to see if anything more is needed, and that the suspension is properly fitted.
Once all the pieces are colored and the leather is finished, it is re-assembled for the final time.
Neat looking scabbard for the falchion, but I'm surprised the owner wanted a style of scabbard that predates the sword by so much.
Hello
Probably because, I have no idea, what a 15th century scabbard ,looks like :D I`ve never been
much, into the historical accuracy, aspect,of swords and the like.I`am more into the, fantasy ,angle.
But I beleave,that fashion, was the same then, as now..."If it looks good, it is good" :)
I actually brought up the question as to what falchion scabbards would look like, but we didn't really come to a consensus on that.
M.
M.
| M. Eversberg II wrote: |
M. |
True, but that suspension system dies out somewhere in the first half of the 14th century based on period art (effigies, brasses, iconography). The painting this falchion is based on is from circa 1480.
| Karl Knisley wrote: |
| Hello
Probably because, I have no idea, what a 15th century scabbard ,looks like :D I`ve never been much, into the historical accuracy, aspect,of swords and the like.I`am more into the, fantasy ,angle. But I beleave,that fashion, was the same then, as now..."If it looks good, it is good" :) |
Hear Hear! And it does look good!
Page 1 of 5
