Posts: 5,981 Location: Birmingham, Alabama
Tue 22 Apr, 2008 1:58 pm
Khyber Knives
Tue 22 Apr, 2008 2:01 pm
Posts: 337 Location: Houston, Texas
Tue 22 Apr, 2008 2:46 pm
http://www.atlantacutlery.com/atlantacutlery/
Atlanta Cutlery use to have a similar knife for sale. You might give them a try.
See also: RUSSIAN KINDJAL
400318
or:
http://www.bytheswordinc.com/acatalog/Standard_Knives_Page_2.html
Posts: 967 Location: Michigan
Tue 22 Apr, 2008 7:43 pm
Well Hanwei will soon be releasing Tristan's sword from the Movie stardust....which follows along the same general lines (with some yhatagan/fantasy influences thrown in)
Dan
Posts: 224 Location: Pennsylvania, USA
Tue 22 Apr, 2008 9:14 pm
Hi Sean,
I also have admired these knives (short swords really) for some time. Over the course of the last year, I have acquired three of these large Kyber Knives. Mine are approximately mid to late 19th century and are wicked sharp and fast. Each is unique.
I have not seen much in the way of reproductions, but like many middle eastern/indo persian/ islamic edged weapons, great buys of originals do appear on e-bay from time to time. Some antiques in poor condition are sold without reserve and may suit your purpose as a project (if you can bring yourself to work on an original, albeit one in poor condition)
Short of that, if I come across any reproduction sources I will post it. I can't believe some Indian maker isn't turning these out.....
Best regards,
Terry
Posts: 123 Location: lawrence, kansas
Tue 22 Apr, 2008 9:36 pm
Do not these style of knives have a strange "T" shape on the spine of the blade?
Tue 22 Apr, 2008 9:43 pm
Not sure what you mean by "strange", but yes, they do have a "T" cross section, with the "T" being at the top the blade opposite the sharped edge. I have heard this referred to as the yelmen (SP?) and is a common feature on these weapons. Strenghtens the blade and looks quite cool in my opinion, but maybe I am the strange one :D
Wed 23 Apr, 2008 2:14 pm
Thanks for posting those pictures! I'm drooling already. ;)
If you try the By The Sword one, please share your thoughts on its quality. I'm trying to choose between that and a Qama for my next cheap fun Islamic short sword.
As to yelman, I've only heard that used for the "false edge" on Turkish pala, but I'm not an expert by any means!
Wed 23 Apr, 2008 2:27 pm
I was told that the T shape to the blade cross section was to stiffen the point of the blade to allow it to pierce
chain mail more easily.
Posts: 63 Location: New Hampshire, USA
Thu 24 Apr, 2008 2:09 pm
Terry Crain wrote: |
Not sure what you mean by "strange", but yes, they do have a "T" cross section, with the "T" being at the top the blade opposite the sharped edge. I have heard this referred to as the yelmen (SP?) and is a common feature on these weapons. Strenghtens the blade and looks quite cool in my opinion, but maybe I am the strange one :D |
Beautiful knives but I'm turned off by the thought of how that cross-section would affect cutting ability.
Thu 24 Apr, 2008 3:24 pm
Well much of the rest of the blade is thin or moderately thick, the idea being that the spine strengthens it like an I-beam (see Mr. Trim's new sparring design? same idea) while minimizing their thickness at the edge. Thus you get a thin but very tough blade, ideal for chopping through. By the time the T spine passes through, the cut is already wide enough to make its effect negligible, barring bad cutting angle and user error.
Thu 24 Apr, 2008 6:48 pm
Shayan G wrote: |
Well much of the rest of the blade is thin or moderately thick, the idea being that the spine strengthens it like an I-beam (see Mr. Trim's new sparring design? same idea) while minimizing their thickness at the edge. Thus you get a thin but very tough blade, ideal for chopping through. By the time the T spine passes through, the cut is already wide enough to make its effect negligible, barring bad cutting angle and user error. |
I understand how that would make for a very strong blade but it seems to me that it would be a trade-off for a potentially significant reduction in cutting ability on soft-targets. Cutting tests with this type of cross-section might make me reconsider that assumption of course.
Thu 24 Apr, 2008 6:52 pm
Hi Korey,
You wrote, "Beautiful knives but I'm turned off by the thought of how that
cross-section would affect cutting ability."
The T rib doesn't go all the way to the tip of the knife and wouldn't cause a problem either in slashing or stabbing while it would give a thin blade a lot of strength and rigidity. I think these are very well designed weapons.Bear in mind that these knives are from the Khyber Pass area, Afghanistan, and the Afghanis have been killing people ( invaders, each other, Hindus) since the time of Hannibal if not before.
Ken
Fri 25 Apr, 2008 4:51 am
Terry Crane....I meant "strange" as in a unusual feature that I have never seen before...I couldnt judge if you are strange or not....But I have been called it and some of my best friends are odd little people :D , so that is not too negative a word in my lexicon!
Theory: would the T-back allow them to block weapons that would normally damage a similar blade of that size/thickness? Not that this was a reason for such construction, but more of a happy accident.
And historically , what is the naitive metallurgy like? Do they have a rep either good or bad? Could the T-back have been a way for them to compensate for bad steel?
Fri 25 Apr, 2008 7:58 am
Hi Kelly,
You wrote, ""Do not these style of knives have a strange "T" shape on the spine of the blade?"
I just remembered that I once owned an old sword bayonet that had a blade that was nearly two feet long and it had a T cross section for all but six inches or so of the tip. My guess is that the bayonet was German in the general sense inasmuch as the script and the language of the engraving on the blade seemed Germanic. That T cross section must not be all that strange, I'm sure those bayonets and similar ones must have been made in the hundreds of thousands.
Its a great way to provide rigidity and still keep weight down in a blade.
Ken
Posts: 1,977 Location: Nipmuc USA
Fri 25 Apr, 2008 8:47 am
The AH prefix offerings linked are Deepeeka products and have a kind of dissapointing look to the blade crossections. I'm afraid that might be the result from any of the producers and exporters from the area. If one is happy with the overall profile, I guess they might suit. The HAnwei prototype seems to at least nod to the crossection. I know my yataghan has a pretty serioushollow to the grind that kind of mimics this to and extent but the cutting edges of these seem even thinner. Hard to tell from the pictures alone i guess.
GC
Fri 25 Apr, 2008 6:39 pm
I agree with Ken regarding the fact that there really is no issue with the T-back creating a problem with cutting ability or effectiveness as a weapon to be used for its purpose. Many eastern swords and knives have this feature including the Kilij, some Saifs and many Shamshirs.
There are two threads listed in this index right now which have many pictures of middle eastern swords with this feature. The Kilij in particular was known as a very effective weapon utilized by the Ottoman Turks, who knew a thing or two about warfare and the art edged weapon combat.
The Kyber Knife is generally a short sword sized weapon used to stab and hack. Its not a cutting exercise weaponby any means. The blades are very sharp and mine are quite light and lively with most of the weight in sitting in your fist, it has very little blade presence. ... That being said, they are very nasty , and feel quite deadly and as an unarmoured opponent, I certainly would not want to face one!!!
Sat 26 Apr, 2008 5:32 am
I agree that the Deepeeka offering probably isn't of the best quality. However, a slightly better photo from their website seems to show that they could possibly feature the T section (or it could just be a fuller I suppose).
Dan
Posts: 629 Location: Sweden
Sat 26 Apr, 2008 8:06 am
Dan Dickinson wrote: |
Dan
[ Linked Image ] |
I did wonder about that one. I kept wondering if it was an obscure real-life sword that just sort of slipped under my radar of if the propmasters made it up from multiple sources.
There's some clear yathagan inspiration there. Though, is it just me or does it also have a lot of scramaseax and butterfly sword influences?
Sat 26 Apr, 2008 6:47 pm
Looks like a khyber knife to me, down to the imitation koftgari on the blade. The only difference would be the tulwar-like handguard.
Very appealing blade all around!
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
