Russ Ellis
Posted: Wed 19 Dec, 2007 7:03 am Post subject: On a particular Rondel |
Alright, so no sooner does one rondel dagger come in then another rondel project begins. I'm having another one made but the only picture I've found of it to this point is here on this very forum, and I need more information. Here's the rondel in question, it's the top one in the picture which I've linked to out of the "The Rondel Dagger" feature on this site.
Does anyone have any other pictures of that particular piece from other angles? Has anyone seen it in person? Do you have any insights as to the cross section of the blade? What material is the "cap" on the "pommel" or upper rondel made of? What form does the "cap" take? The maker and I have suspicions in all of these areas but a lack of concrete knowledge. I know asking about a particular piece is a hard order to fill, but I thought if anyone had that sort of information it would be someone here.
TRITONWORKS Custom Scabbards
Posted: Wed 19 Dec, 2007 7:26 am Post subject: |
Just a guess but the section of the blade is probably triangular with a flat or slightly rounded or faceted top,
There seems to be a breaking of the corners bevel in the middle top and file work closer to the guard: I'm probably just confirming what you already noticed.
Thickness of blade and distal taper ? I would guess also at a very thick blade at the guard but still fairly thick before the reinforced point, otherwise the reinforced point and main bevel junction would be a weak point that would defeat the purpose of reinforcing the point as a thin section here would bend easily.
If there is a useable edge i.e. sharp or butter knife dull is hard to tell?
Mathieu Harlaut
Posted: Wed 19 Dec, 2007 7:28 am Post subject: |
I have read somewhere that this dagger is at the Victoria & Albert Museum in London but not on display. Perhaps you could contact them directly.
If you wish, I have a color photo of the second dagger.
Russ Ellis
Posted: Wed 19 Dec, 2007 8:46 am Post subject: |
| Mathieu Harlaut wrote: | I have read somewhere that this dagger is at the Victoria & Albert Museum in London but not on display. Perhaps you could contact them directly.
If you wish, I have a color photo of the second dagger. |
Thanks for the responses guys. Mathieu, thanks for the leads, I'll see if I can follow up. I'll take any photos you've got.
Fabrice Cognot
Russ Ellis
Posted: Thu 20 Dec, 2007 7:40 am Post subject: |
| Fabrice Cognot wrote: | The grip/roundel material is horn.
As Jean said, the blade is of triangular section, thick but not too thick.
I made a dagger that was a mix of the two in 2006, using boxwood instead of horn, check this thread http://www.myArmoury.com/talk/viewtopic.php?t=11087
I alos have quite a lot of color pics of the second dagger if you'd like ; |
Nice job there on that dagger Fabrice, and thanks for confirming the rondel maker's suspicions. He too thought that the material in question was probably horn because the weight for steel or iron would have unbalanced the dagger. Now I need to ask him if he has ever worked with horn... I would love to see any other pictures you have.
Fabrice Cognot
Posted: Fri 21 Dec, 2007 6:12 am Post subject: |
| Russ Ellis wrote: | | Fabrice Cognot wrote: | The grip/roundel material is horn.
Nice job there on that dagger Fabrice, and thanks for confirming the rondel maker's suspicions. He too thought that the material in question was probably horn because the weight for steel or iron would have unbalanced the dagger. Now I need to ask him if he has ever worked with horn... I would love to see any other pictures you have. |
Remind me of that from time to time - I'm just as busy as usual, and tend to skip things Or just PM me your email addy and I'll send you the pics.
PhD in medieval archeology.
HEMAC member
De Taille et d'Estoc director
Russ Ellis
Posted: Mon 24 Dec, 2007 3:25 pm Post subject: |
I could be off my rocker, but isn't one or more of those daggers attributed to Maximilian I? Or maybe it's a similar dagger.
Russ Ellis
Posted: Tue 25 Dec, 2007 11:40 am Post subject: |
Unfortunately the only attribution I have seen for these two daggers is that they are Burgundian (both on this site and from a book about daggers and fighting knives). That would certainly not preclude them having belonged to Maximillian since he did have a somewhat tumultuous interest in Burgundy????
Posted: Tue 25 Dec, 2007 12:06 pm Post subject: |
| Russ Ellis wrote: | | Unfortunately the only attribution I have seen for these two daggers is that they are Burgundian (both on this site and from a book about daggers and fighting knives). That would certainly not preclude them having belonged to Maximillian since he did have a somewhat tumultuous interest in Burgundy???? |
His mother was Mary of Burgundy. I just checked and Max's dagger, dated to 1490, looks a little different.
Russ Ellis
Posted: Tue 25 Dec, 2007 8:53 pm Post subject: |
Drat. It would have been cool to have that attribution to the reproduction that's in the works...
