John H.
Posted: Thu 29 Nov, 2007 12:02 am Post subject: The Horseman's Axe (my first attempt)... |
I was inspired earlier this year by THIS thread from 'Toni R'. I already had an angle grinder, so I began casually searching for an axe to use as a starting point.
A few weeks ago I went to a local estate sale, where I found a very old double-sided axe that was in pretty bad shape (& affordably-priced as well). The handle was present but snapped off, & the axe-head itself was broken in the corner (I only have a crappy cellphone pic of the original state, as I wasn't sure I would be using this piece for anything):
Because of the damage on the axe-head, I decided to try my hand at creating a 'Horseman's Axe'. I figured that I could make use of the shortened piece of the original handle, & grind the head into a pleasing, yet functional shape. In addition, there seemed to be so many different designs (historically-speaking) with regards to the shape of the axe-head on these weapons, that I could use my imagination a bit. I probably drew up a dozen designs for the axe-head before I settled on this configuration (which is slightly different than any I have ever seen in ancient/medieval or even modern replicas). I shortened the handle to 24 inches, & re-installed it. I liked the natural color of the wood (hickory), so I just sanded off the old finish & cleaned it with a wood cleaner/treatment (which darkened it slightly). I'm pretty happy with the results:
Thanks for looking!
M. Eversberg II
Posted: Thu 29 Nov, 2007 12:11 am Post subject: |
That is one awesome axe.
M.
This space for rent or lease.
Gary A. Chelette
Posted: Thu 29 Nov, 2007 1:25 pm Post subject: |
Nice work. That must have been a lot of grinding!
Are you scared, Connor?
No, Cousin Dugal. I'm not!
Don't talk nonsense, man. I peed my kilt the first time I went into battle.
Oh, aye. Angus pees his kilt all the time!
Allen Andrews
Posted: Thu 29 Nov, 2007 1:41 pm Post subject: |
Thats pretty cool! Wicked beak
Faramir son of Denethor
Shayan G
Posted: Thu 29 Nov, 2007 1:50 pm Post subject: |
It has an exotic look, like a Bat-a-rang and an axe had a child. Nice design!
Posted: Thu 29 Nov, 2007 11:44 pm Post subject: |
I might add bevels to the beak on the outside and inside of the hook/beak. These could be fairly obtuse in angle for robustness
i.e. not very sharp, but the geometry would improve armour piercing qualities and also look good aesthetically.
Just a suggestion, but very nice work as it is now.
John H.
Posted: Thu 06 Dec, 2007 3:25 pm Post subject: |
Gary A. Chelette wrote: | Nice work. That must have been a lot of grinding! |
Aye. It took about 16 hours total (over 4-5 days), & I wore down 4 cutting wheels to basically nothing in the process.
Thanks!
D. Michael McIntyre
Posted: Mon 10 Dec, 2007 8:19 pm Post subject: |
Jean Thibodeau wrote: | I might add bevels to the beak on the outside and inside of the hook/beak. These could be fairly obtuse in angle for robustness
i.e. not very sharp, but the geometry would improve armour piercing qualities and also look good aesthetically. | I second that motion. This is very nice as it stands now, but this bevel you suggest would be the perfect finishing touch.
Etienne Hamel
Posted: Wed 12 Dec, 2007 8:32 am Post subject: |
Nice axe! you are getting me creative!
but i will probably do a double bladed beard axe or something like that.
Ross McCarthy
Posted: Wed 12 Dec, 2007 7:10 pm Post subject: |
Pretty good for a first attempt old son !
R. McCarthy
John H.
Posted: Wed 12 Dec, 2007 10:03 pm Post subject: |
Thanks for the positive comments everyone!
D. Michael McIntyre wrote: | Jean Thibodeau wrote: | I might add bevels to the beak on the outside and inside of the hook/beak. These could be fairly obtuse in angle for robustness
i.e. not very sharp, but the geometry would improve armour piercing qualities and also look good aesthetically. | I second that motion. This is very nice as it stands now, but this bevel you suggest would be the perfect finishing touch. |
I have no doubt that you both are correct about beveling the beak. However, all the grinding on this piece was done before I mounted it on the handle. I plan to do some more axes in the future, & I'll definitely be applying the suggestion to later pieces.
Posted: Wed 12 Dec, 2007 10:31 pm Post subject: |
John H. wrote: | Thanks for the positive comments everyone!
I have no doubt that you both are correct about beveling the beak. However, all the grinding on this piece was done before I mounted it on the handle. I plan to do some more axes in the future, & I'll definitely be applying the suggestion to later pieces. |
Probably easier to do on an unmounted head but it should be doable even mounted with a handheld angle grinder or dremel tool or workbench mounted belt grinder: All depends on your comfort level and skill doing this freehand.
Anyway, nice as is.
