Forum Index > Historical Arms Talk > about black powder paper 'cartridges' Reply to topic
Peter Bosman
PostPosted: Mon 14 May, 2007 12:24 am    Post subject: about black powder paper 'cartridges'         Reply with quote
Splitting the thread from another topic.
Ideally a flintlock pistol for mounted use woukd have a lanyard to prevent it from dropping and a swivel for the ramrod but booth seem to be fairly late innovations.
Cartridge pouches however are very early thus cartridges were too.
Now I doubt wether http://www.civilwarguns.com/9508.html was a solution found by those early users and I also have my doubts about fiddling a wire through the vent hole but then I cannot realy envisage tearing a cartridge with my teeth etc without spillage or loss of things when on the move either...
I know some remark that the tactic was to ride out, shoot, ride back to load and in again but that is not how I see it. I have half a dozen trained and thus very keen horses and none of them will quietly stand for me to reload when there is a game on hand. I might as well do it at a gallop as that is a relatively easy movement.
Now, why did the riders not wear their pistol ramrod on a lanyard aroud their neck or such? or did they? Early 19th century riders sometimes did even for their carbines.
Ripp the paper, stuff the whole (lubed paper) cartridge in, give it a shove and go?!
Remember these guys were quíte inventive so they múst have thought of sómething!
Peter
View user's profile
Reading list: 7 books
PostPosted: Mon 14 May, 2007 3:26 am    Post subject: Re: about black powder paper 'cartridges'         Reply with quote
Well...it depends. In a military context, you probably wouldn't want to load when there are any nearby enemies since the enemy would usually be able to reach you faster with a charge than you can reload your pistol, even if you're doing it on the gallop. Military manuals as late as the 1850s still treated the pistol essentially as a weapon that could only fire one shot in any given encounter, preferably at very close range as you're charging to meet the enemy. And that's the reason why any sane cavalryman would have carried more than one pistol at any given time.
Your reasoning might be correct when used in the context of hunting, though, since there'd be less threat of the "enemy" seeing that you're occupied with the reloading process and then taking advantage of it. Still, are you sure it has to be done on the gallop? Wouldn't it be more practical to do it at a more sedate pace, like a brisk walk? It might also be a good idea to consider that hunting was generally a gentleman's pastime and the gentleman in question might be able to afford two pistols. I believe the cost in money would be very much offset by the practicality of being able to just pull the second pistol rather than having to reload the first all over again before going back to the chase.
Peter Bosman
PostPosted: Mon 14 May, 2007 3:53 am    Post subject: Re: about black powder paper 'cartridges'         Reply with quote
Not sure, that is why I am 'dying' to try. I have been fiddling with all sorts of mock action in the saddle and thínk I can easily do it at any pace over rough terrain even bút.... the proof of the pudding is in the shooting Laughing Out Loud
The point is that nóne of my horses are anywhere near 'sedate' when we are gaming yet I can VERY accurate 'kill' a mock bull with an estoc because thát is what they understand to be the game per example.
Anoher example is a ribbon'racing' contest like on tomorrows fiësta here. They will be very concentrated on a fast but straight gallop passing underneath the ribbons but they are a disáster during the wait and gathering for the next run. I can pick bóth my nostrils at the same time during the pass but no wáy I can use both hands when waiting 'sedately'.
If this was to be a pistol shooting contest I could easily shoot two-handed during the pass but would need to canter around the field to reload ór have an assistant occupy the horse ór dismount.
However, the proof....
Peter
View user's profile
Gordon Frye
Reading list: 15 books
PostPosted: Mon 14 May, 2007 5:12 pm    Post subject:         Reply with quote
Peter;
I've managed fairly handily to load from paper cartridge while mounted, by going through the standard steps:
1.)Place Pistol in your bridle hand
2.)Half-cock Pistol, set safety catch (if it's an English-lock)
3.)Open Pan (if it's not already open)
4.)Handle Cartridge with your right hand
5.) Tear Cartridge with your teeth by thumbing the tail of the cartridge out, and holding the thumb over the powder
(Spit the cartridge paper out of your mouth, as the powder tastes TERRIBLE! Eek! Hard to not get a smidgeon in your mouth when you tear, even when holding your thumb at the point where you wish the paper to tear)
6.) Prime Pan by pouring a very small amount of powder into the pan, just sufficient to fill it
7.) Shut Pan
8.) Cast about the pistol to bring the muzzle up, and place the butt of the pistol on your left thigh, lock facing outward
9.) Charge Cartridge into the muzzle (Cargen en el cañon)
10.) Draw Rammer
11.) Insert Rammer and Ram Home
12.) Remove Rammer
13.) Return Rammer
14.) Free your Cock (if it's on safety)
15.) Recover your Pistol to your Right Hand
16.) Present and Fire.
This is the manual for use with the cartridge. For using flasks, its a bit different (the following is straight out of Cruso, 1632, using wheellocks but with extra info on using English-locks)
1.) To horse
2.) Uncapp your Pistolls
3.) Draw your Pistoll
4.) Order your Pistoll
5.) Spann your Pistoll (when using a wheellock)
6.) Prime your Pistoll
7.) Shut your Pan
8.) Cast about your Pistoll
9.) Gage your Flaske (turn it upside down to fill the spout, then close the cut-off valve)
10.) Lade your Pistoll
11.) Draw your Rammer
12.) Lade with Bullet and Ram Home
13.) Return your Rammer
14.) Pull down your Cock (sometimes called dog on wheellocks)
15.) Recover your Pistoll
17.) Return your Pistol
For use with an English-lock pistol (or any flint-igniton pistol if you ignore the aspects of the safety)
18.) Bend your Cock (in the stead of no. 5.)
19.) Guard your Cock (place on safety)
20.) Order your Hammer (in the stead of no. 14)
21.) Free your Cock (remove safety)
As noted, I've managed to reload my pistols from horseback when using cartriges, but I haven't tried it with a flask though I have no doubt that it's manageable. The issue is, as you note, calming the horse down enough to do so. But I suspect with a major battle going on, and during the course of a long campaign, having a fairly tired horse would be of some benefit for once! I was informed by Daniel Staberg that in the course of the Battle of Wittstock in 1636, the Swedish Cavalry made between 8-10 Charges and that by the last few, the horses could barely stand on their legs (and the riders could barely stay in the saddle). I have no doubt that they were sufficiently steady at that point to allow the reloading of their pistols and carbines, though I'm sure they would have preferred to have had fresh, nervous horses!
Cheers!
Gordon
Gonsalo Jimenez de Quesada
George Hill
PostPosted: Mon 14 May, 2007 6:46 pm    Post subject: Re: about black powder paper 'cartridges'         Reply with quote
This fellow is using a prick to open the paper in the weapon, so the spark will penetrate. I'm brought to understand that they used prepared paper soaked in a solution which would make it inflammable, like flash paper, back in the old days, so you can could skip that step. My information was only for muzzle loading revolvers, so I'll make no guesses as to if it appeared earlier then that,.
Gordon Frye
PostPosted: Mon 14 May, 2007 7:08 pm    Post subject: Re: about black powder paper 'cartridges'         Reply with quote
George Hill wrote:
This fellow is using a prick to open the paper in the weapon, so the spark will penetrate. I'm brought to understand that they used prepared paper soaked in a solution which would make it inflammable, like flash paper, back in the old days, so you can could skip that step. My information was only for muzzle loading revolvers, so I'll make no guesses as to if it appeared early then that,.
Peter;
Well, that's how they work it with muzzle loading artillery, so I can see where folks might get that idea. But indeed, caplock revolvers work well with flash-paper cartridges, you're right. I hadn't heard of it being used for regular muzzle loaders though.
Gordon
Peter Bosman
PostPosted: Mon 14 May, 2007 11:14 pm    Post subject:         Reply with quote
Thanks Gordon, George.
Soaking the paper in something inflammeble. Good idea if risky, but then, with only 6 in a pouch no mayor explosion will result.
That would sure be a clever way to quickly load from the saddle.
The pistol I like móst as a rider unfortunately is about 150 years too late. I did aquire a superb McClellan-type saddle matching the guns I like but well, you can't have it áll Razz
Sofar no affordable luck on the wheellock. I did think about another thing though. I live real close to Marocco and have some maroccan acquaintances and flint lock pistols-guns are still being manufactured there in a rococo style which may be exactly right for me!
Still looking for a nice Colichemarde too Wink
During thís period btw, a manual on 'bien ecuyer' lists surprising arms for the mounted man. De Saunier was well seasoned on the battlefields of his times, for an ecuyer exceptionally so, was a duellist and this practical man uses a javelin, short lance, smallsword, sabre and pistol.
Nó mentioning of reloading, but then he and his french collegues were infamous for their rather direct approach Wink
Peter
View user's profile
PostPosted: Mon 14 May, 2007 11:32 pm    Post subject:         Reply with quote
The Polish husaria also made something between ten and fifteen charges against the Russo-Swedish infantry positions in the Battle of Kluszyn/Klushino. Most hussar enthusiasts would present this as a testament to the hussars' resilience, which I think is quite appropriate, but they usually forgot to mention the other side of the equation--that all those initial charges failed and only the last broke through, after the Polish infantry came to knock down the Swedes' and Russians' redoubt!
George Hill
PostPosted: Tue 15 May, 2007 11:11 pm    Post subject:         Reply with quote
Peter,
On the overall subject of risk, I do not think one is at too much greater a risk from a combustible cartridge then one is from the simple presence of the gunpowder. As long as both are contained in a fireproof container, one is as safe as one is going to get. This is why even for regular musket cartridges, the box closed after you took anything out. I would be more afraid of flaming wadding in a regular cartridge box then I would be of a combustible cartridge.
Peter Bosman
PostPosted: Wed 16 May, 2007 12:36 am    Post subject:         Reply with quote
Ha, I like the relativity-theories here Laughing Out Loud
You are right George in that dealing with powder needs common sense anyway.
Indeed Lafayette, a successfull cavalry charge does not need a repeat however... this does depend very heavily on the deifinition of successfull and thus the chosen strategy-tactics.
I relay like the mamluk manuals that portray the cavalry in a harassing role and only charging in the face of easy winning. The true 'light' cavaly.
This brings to mind what the numidian cavalry provoked when they met the roman units. They worried them and provoked breaks in formation. This latter being the 'success' aimed for and yes they did need to 'charge' various times before infantry would break formation.
Same thing realy as for 'heavies' or the polish hussars, only diffently executed Idea
The 'success' of cavalry thus depends heavily (pun intended) on the skill and disciplin of the opposing force. Thát brings us back to the mamluk instructions not to bother to actualy charge ínto infantry and play the more patient game which i think is the more rational way to employ cavalry.Mind you, that does assume this cavalry is very well trained.
Thát again is a factor that influances the strategy-tactics that can be used.
Peter
View user's profile
George Hill
PostPosted: Wed 16 May, 2007 1:36 am    Post subject:         Reply with quote
Very true.
Cool Cool Cool
As long as we are on the general subject of this, the pictures I have seen of properly constructed combustible cartridges, they have an interesting look to them. Whereas musket paper cartridges are more like a small wrapped package, the revolver version was nothing of the sort. It was more like the idea of a modern caseless round. It was almost like a solid lump of propellant was glued to the rear of the pistol ball. (Except of course the lump isn't slid, but a sack of powder.) You will have seen similar setups for cannon ammunition, which I understand is called "Fixed ammunition."
The cannon set up I have seen is a cannon ball, (solid shot) strapped to a wooden disk. The disk has a rim with a linen powder bag tied to it. The allows a single item to be rammed down the bore of the gun, rather then ramming a powder bag and a projectile separately.
AH! I have found a photo.
 Attachment: 46.3 KB
Peter Bosman
PostPosted: Wed 16 May, 2007 2:23 am    Post subject:         Reply with quote
Véy interesting 'bullets' George.
This all makes me think and rethink about what pistol to buy when (and if) the weapon permit ever comes off. Period, more practical or just fun? as it is all fun anyway and who will notice apart from you buffs?! The snag is I will know too Blush
Peter
View user's profile
