I was wondering if one of you knows if its necessary to do heat treating on axes or if it's just for the swords and knives.
any help would be appreciated.
| Etienne Hamel wrote: |
any help would be appreciated. |
Hi if you want to use it to cut wood etc then yes, the edge should be heat treated, A forge welded edge of carbon steel was used extensively during the viking age.
If the head is just for reenactment than you probably dont need to bother.
N
And if i do like Tony R.(I really loved your axe man i want to do it) is it necessary?
check this link if you want to know what i mean: http://www.myArmoury.com/talk/viewtopic.php?t=9757&highlight=
I too was impressed by Toni R's axe head and have started work on one in a similar fashion. I have come to the point where I want to reshape the hole for the shaft into a rounder section. My question is: If I start pounding on an old axe head without annealing it am I likely to snap it in two, or is it not likely to be that brittle?
having written this I guess the obvious answer is better safe than sorry.
Nick.
Nick.
